[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Welche Version davon Nickel Plexi oder Nickel Acetal mit ABP oder ohne ABP?
Nickel Acetal, ohne ABP!
eine active backplate kann man sich bei der 4090 sparen da alle RAM Chips auf der Vorderseite der Karte sind.
Bei mir geht leider nur ne Fe rein...klar andere passen auch, aber dann passt kein 12VHPWR Stecker mehr rein, wegen der AIO...
Habe gestern meine Suprim X erhalten und gleich den PC in das 7000d umgebaut + neue AIO. Eigentlich hatte ich mir den Umbau auf das Wochenende gelegt, da der Umbau + die ganze Verkabelung der AIO usw. mich letztendlich 4h Arbeit gekostet hat. Nachdem alles verbaut war dann die Ernüchterung, die Lüfter der Suprim sind nicht in Ordnung. Die Karte hatte normales Spulenfiepen, was für mich in Ordnung gewesen wäre. Jedoch haben die Lüfter ab 50% ein sehr hohes, schleifendes Geräusch von sich gegeben, ähnlich einem Zahnarztbohrer. Habe die Karte daher heute Morgen leider wieder zurücksenden müssen. Hoffe die Rücksendeabwicklung geht schnell und ich bekomme mein Geld dann wieder, um wieder auf die Suche zu gehen :(.
Wo ist der Unterschied zwischen Nickel Plexi und Nickel Acetal? Ich dachte, dass das nur bedeutet, dass die Platte oben "hübsch" durchsichtig (Plexi) ist oder schwarz (Acetal)?! Backplate ist in beiden Fällen Nickel, nicht?
Die Qualitätskontrolle bzgl lüfter ist aber auch echt zum kotzen. Such meine tuf hat ein ganz leises Geräusch bei einem der Lüfter. Ist aber nicht zu hören wenn das case auf dem Boden steht und geschlossen ist. Somit mir wurscht
Backplate ist immer Acetal. De Block ist entweder oben Acetat oder plexi
Ich war auch wirklich enttäuscht, da meine 3090 Ti so etwas nicht hat. In der normalen Fancurve hätte man es wahrscheinlich selten gehört, da die Lüfter selten über 50% gehen aber für eine 2,5k Karte, war das für mich nicht akzeptabel :(. Hatte aber auch Bedenken, dass die betroffenen Lüfter auf Dauer einen Schaden nehmen können.
oben ist aber eben immer unten 😆 ausser Du verbaust vertikal
Wären das jetzt 2 oder 3x Standard 120er dann könnte man die einfach fix austauschen indem mir asus einen neuen schickt. Das würde die rma Abteilung und die shops entlasten.
Es müsste dahingehend einfach mal was bei den Herstellern passieren, damit man auf den Kühler seine eigenen Lüfter der Wahl verbauen kann und nicht Lüfter für Centbeträge, deren Lager etc. sehr minderwertig sind.
Cablemod kriegt es doch auch hin und das ist im vergleich zu nvidia ein Furz im Wind.
Das sollte für nvidia kein kunstück sein da innerhalb von wenigen Tagen Abhilfe zu schaffen wenn sie denn wollen.
Nvidia könnte mit cm in Kontakt treten und jedem 1 Kabel for free schicken der eins bestellt.
Das wäre die Ad hoc Lösung. Dazu müsste nvidia halt hergeben und die Eier haben und sich entschuldigen für den bockmist aber dass passiert sicher nicht 😆
Falls ihr euch immer wundert, warum MM und Saturn immer wieder die gleiche Karte in einem kurzen Zeitfenster als verfügbar anbietet.
Es gibt Leute oder eventuell auch Bots, die den Kauf bis zum PayPal Checkout bringen. Dann ist die Karte erstmal "reserviert" und geblockt. Wenn man den PayPal Checkout quitet ohne die Karte zu kaufen, wird diese wieder verfügbar im System. Dadurch ist die Karte wieder verfügbar.
Du stellst aber auch echt übertriebene Anforderungen an eine Karte die grade mal günstige 2k€ gekostet hat. 💩
Ja, ist REF, aber es wird nicht alles abgedeckt. Der ALC Block ist also zu 100% nur für Inno3D
Siehe hier:
#28
Sorry aber ich sehe da nichts was nicht abgedeckt ist. Sieht genauso aus wie bei der Inno3d X3 OC.
Sie hätte sicher so einen gehabt. Aber wenn nvidia das jetzt anerkennt, dass das Ding Schrott ist, wird man das stoppen können
Eher nicht, die werden eher bis dahin einfach einen überarbeiteten Adapter beilegen.
Wird die 4080 auch so einen Adapter haben?
Meine Vermutung: Man wird auf ATX 3.0 Netzteile setzen für die neuen Karten, denn warum sollte man weiter mit einem Adapter rum fackeln, wenn die Netzteile verfügbar sind.
Konnte endlich ne KFA2 bei MM schießen. Bin gerade erst von ner F5-Session aufgestanden dann kam eine Telegram-Benachrichtigung rein und ich hab mich prompt wieder auf den Stuhl geschmissen um die Bestellung durchzuboxen. Gefühlt wird da immer wieder eine Karte freigegeben und man muss eben in dem selben Moment ready sein. Karte bereits im Warenkorb und hinterlegte KK hilft vermutlich.
Ergibt irgendwie garkeinen Sinn. Du glaubst doch nicht ernsthaft das jeder der eine 4080 will auch ein neues ATX 3.0 Netzteil kauft. Auf was für Ideen kommt ihr denn manchmal. Das ganze wird schlichtweg kostengünstig gemacht und es wird ein neuer Adapter beigelegt der optimiert wurde. Dann ist der Fisch geputzt.
Die Käufer selbst können ja dann selbst überlegen ob Sie den neuen Adapter nutzen oder einfach selbst ein Adapterkabel kaufen vom Netzteil Hersteller.
weil viele der potentielle Kunden kein ATX 3.0 Netzteil haben oder kaufen wollen, Nvidia wird weiterhin einen Adapter beilegen.
