[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, bei Mediamarkt und Saturn gibt es absolut keine Chance. Und alle anderen Shops scalpen ja mittlerweile mehr oder weniger
Gerade wieder sehr schön. Erst die KFA2 bei MM, danach bei Saturn. Beide hatte ich direkt gesehen, also nicht über den Verfügbarkeitsthread. Kannst komplett vergessen. Wenn die ihren Shop nicht härten, kannst selbst auch nur noch mit Bot dein Glück versuchen. Denen ist es egal. Hauptsache verkauft.
sind hier im luxxforum, wer sich 12 karten oder mehr kaufen kann, dann kann ich mit MEINER EINEN Karte auch mal den Sch...z rausholen
Wenn es Dich befriedigt. Nur zu! Und die Vielkartenkäufer lassen einfach Ihre Kreditkarten oder Firmenkonten glühen. Beeindruckt mich nicht im geringsten.
Er hat das Kabel locker reingelegt....das sieht man an dem 90°C gebogenen Kabel...
Ein Fall von Hauptsache den PC zu gedrückt...
Ah okay, danke. Gab es schon Tests ob die Safe sind?
Klar, die sind anders aufgebaut als die von Nvidia. Die vielen Schwachstellen gibt es dort nicht im Stecker.
Den habe ich für die FE
Ich weiß nicht ob ModDIY BeQuiet Kabel hat, weil die einen propietären Stecker haben.
Man bin ich froh das bisher alle die ein Foto gemacht haben eine Karte wie Suprim, Strrix oder Tuf hatten. Alle haben den Vierzack Adapter. Gut das ich nur einen Dreizack bei meiner Karte habe. :banana:
Ich glaube das macht keinen Unterschied
Ich habe auch Dreizack und ja. ..bisher wurden wohl immer nur die richtig dicken Brummer Karten damit geschmort
@Neue_adapter
einwandfreie adapter müssen erstmal designt und produziert werden. man müsste die folie gegen eine platte mit ausreichender stärke ersetzen, was mit sicherheit nicht so einfach möglich ist. aufgrund des begrenzten platzangebots im stecker. und selbst wenn das alles machbar ist, so muss es in massen produziert und verschifft werden. das dauert ewig. unglaublich aufwendige logistik. naheliegender wäre ein rückruf aller karten und geld zurück an den kunden - resdesign.
tobi
EKWB hat gerade meinen EK-Quantum Vector² FE RTX 4090 Wasserblock versendet 😊
Man muss aber schon etwas realistisch an das ganze rangehen, auch wenn es einfach ist das ganze auf den Adapter zu schieben. Es macht denke ich schon einen Unterschied wie man mit den Kabeln umgeht und was man mit der karte macht. Es ist schon ein Unterschied ob ich zwischen Karte und gehäusewand 10 CM habe oder nur 5 CM und auch ob ich die Karte auf Standard laufen lasse oder übertakten muss bis zum geht nicht mehr. Das sind schon auch alles Faktoren.
Man sieht ja sehr gut an den bisher unter 10 Fällen das keiner sagte was mit der Karte gemacht wurde. Man kann das schon etwas beeinflussen.
Hatte gestern mehrfach random Blackouts (oder Treibercrashes?) beim YT schauen über den LG OLED. Hatte jemand schonmal solch ein Problem?
Ich hab das noname Kabel von Amazon. Schaut soweit ok aus. Un hat halt jeden Pin ein 16AWG und nicht pinne zusammen gelötet. Denke sofern die Kontakte nicht anders und schlechter sind wird das den selben job machen wie die bequiet, corsair etc Lösungen.
Zu Saturn und MediaMarkt ich konnte dort mehrere Karten bestellen. Ausser! Die KFA2 das war mir unmöglich habs lange versucht. TUF super easy war am einfachsten, Gainward auch einfach, Strix schwierig, Zotac auch einfach. Ich sass den ganzen Tag mit F5 vor dem PC. Die Karten sind teils schneller verkauft als der Verfügbarkeitsthread aktuallisiert. Viele Karten tauchen im Thread nicht auf weilzu schnell weg. Also wer viel Zeit hat kann ohne Bot bei MM aufjedenfall kaufen. Ausser kfa :)
Die KFA2 gab es bislang nur bei MM/Saturn, oder? Mist, dass die Karte exklusiv bei Läden vertrieben wird, wo man nicht gescheit bestellen kann.
Jetzt mal ehrlich: die die hier irgendwie schon 7,8.9 Karten durchgetestet haben müssen doch checkout Bots benutzen. Gefühlt geht das ohne nicht mehr. Ausser natürlich bei den Händlern die eh schon extreme Preise aufrufen.
Nutze keinen Bot nur Telegram für die HWL GPU Verfügbarkeitshinweise.
Dem stimme ich zu. Destkopbenachrichtigung an und durchs Home Office halt direkt kaufen. Am besten schon automatisch auf allen Webseiten eingeloggt sein. Bis auf die FE hat das bisher immer gut bei mir geklappt.
Ja nur dort bis Dato... Die wollte ich eigentlich auch, bis dann gestern plötzlich die FE anklopfte. Jetzt schau ich mir die FE erstmal in Ruhe an und hoffe auf einen positiven Ausgang ala @Slipknot
Die Frostbitekarte sollte heute oder nächste Woche auftauchen. Gibt es noch User hier, die daran interessiert sind? :)
Hattest du sie bereits im Warenkorb? Ich hab sie reinlegen können und dann war bereits der Kassen-Button ausgegraut.
Ja, hatte sie heute morgen beim ersten Drop in den Warenkorb gelegt und kurz bevor der Luxx Verfügbarkeitsbot angeschlagen hatte war sie bereits bestellbar.
Aber hatte auch mehrere Versuche gebraucht, da sind derart viele Bot´s dran.
Bei MMS auch im Warenkorb öfter mal F5 drücken (nur nicht hämmern sonst gibts Bot Protection). Der Button kommt manchmal trotzdem wieder. Das gleiche gilt auch für das bezahlen.
Schonmal im Markt vor Ort versucht eine Karte zu bestellen?
Keine Ahnung, ob das möglich ist aber Fragen kostet ja nichts.
Mfg
Kiryu
Ich war letztens nachfragen im MM Cottbus, Aussage von denen, wenn ich die nicht online bekomme, dann gar nicht, entweder wollte oder konnte der MA nicht Vorort bestellen...
Bestell ruhig mal eine und teste sie für uns. :)
