[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
25-50€ rum kostet diese
You must have an order with a minimum of 69,90€ to place your order, your current order total is 24,90€.
weil ich das jetzt für 70€ bestelle?
Endlich die TUF OC etwas ausgetestet:
Die Geräusche der Spulen nehmen mit der Zeit (erste 4-8h auf 50°C) wirklich immer weiter ab. Jetzt ist es nur noch ein mittleres Sirren/Surren und kein Rasseln mehr. Wie n Netztrafo nur lauter und mit mehr Oberwellen.
Takt der TUF OC:
Stock 2680 MHz (380-420 Watt)
900 mV 2610 MHz (~320 Watt)
700 mV 2280 MHz (~240 Watt)
Getestet mit Port Royal und Speedway – aber in 4K mit erhöhter Qualität. Die Standardbenchmarkläufe erzeugen viel zu wenig Last, da reagiert sogar Anno 1800 empfindlicher...
Bin sehr zufrieden mit der Karte, auch wenn's bei der Chipgüte auch ne TUF non-OC hätte werden können.
Kann man eigentlich irgendwie noch unter die 700 mV gehen? Nur mit negativem Offset – aber dann bekomme ich ja nur den auf den originalen Boost Steps basierenden Takt, richtig?
Obwohl, irgendwann macht wahrscheinlich ein Framelimiter + höherer Boost Sinn. Ohne Auslastung kein Verbrauch, mit hohem Boost weniger Latenz. Oder wie würdet ihr für "Gurkenspiele" ohne eingebautes Framelimit vorgehen?
Mmhh, nach ewigem Rumprobieren muss ich konstatieren, die letzten 30 MHz bis zur 3 GHz Marke schafft meine Karte einfach nicht 100% stabil. Muss ich mich wohl mit abfinden, auch wenn es psychologisch weh tut nicht die 3 vorne zu sehen :fresse:
Also meine Suprim X schafft +175 mhz Core stabil und +1520 mhz Speichertakt.
Komme auf auf knapp 28003 Punkte bei Port Royal. Sollte reichen :D
Wie ist eigentlich die FE bezüglich Spulenfiepen? Bzw. gibt es Custom Modelle, die weniger betroffen sind?
Ja die meisten mit nur 50/55A Phasen und auch etwas weniger Powerlimit. Die Karten die zu Anfang kaum jemand wollte sind aktuell Potentiell besser als FE, MSI oder Asus was das Fiepen angeht. Sind zumindest meine erfahrungen.
Bei Asus lohnt sich das Testen im Silentmodus bzgl. Spulenfiepen und mal etwas länger laufen lassen. Gefühlt wird es bei TUF und Strix Karten besser bei MSI fast schlimmer.
Meine MSI hört man kaum noch durch das geschlossene Gehäuse.
Kann gerne mal ein Video aufnehmen.
Kann sein ich hatte 4 Suprim X … 2 extrem laut 2 ging so (eine war am Anfang ok und wurde nach 30min Test plötzlich lauter) … kommt halt immer drauf an welche Last und wieviel FPS. Meine habe ich alle im offenen Aufbau getestet, alles andere Silent … Selbst bei 100% Lüfter der 4090 konnte man das Rasseln und fiepen bei denn MSIs im Ansatz noch hören. D.h. Aber nicht das ich dir nicht glaube. Gibt bestimmt welche die nicht fiepen.
Also meine hat am Anfang echt laut gefiept und ich wollte die auch schon wieder verkloppen, aber dann habe ich mal ein paar Stunden gebencht und dann 2-3 Std.
den Icestorm Benchmark im Loop laufen lassen. Seitdem ist die Karte kaum noch zu hören.
Ich muss schon ganz nah an Gehäuse gehen, damit ich irgendwas höre. Weg ist es nicht ganz, aber so gut wie.
Takt der TUF OC:
Wie kommst Du überhaupt auf 700mV? Ich kann meine nicht unter 865mV undervolten. Mach ich was falsch? Neue MSI AB Version? Oder womit arbeitest Du?
Die aus diesem RUN
War Anfangs leise und wurde dann leider lauter … war bislang die beste. Spannend selbst mit wenig Takt war die Karte wenn man sich die FPS angeschaut hat beim Benchen ca. 1-2 FPS schneller jetzt ist das Einhorn wieder bei NBB .. mir war fiepen und rasseln zu nervig ;-)
Takt der TUF OC:
Nene das geht nicht Non-OC boosten schon alle über 2700Mhz :shot:
Mit UV kannst du das Fiepen noch mal einen Ticken minimieren. Bei Games ohne eingebauten Framelimit kannst du doch einfach ein Framelimit im RivaTunerStatistics setzen.
In Gurkenspielen wie zum Beispiel Dark Souls III taktet die Karte von alleine nur bis 660Mhz hoch und verbraucht 70W. Es gibt kein Grund auf unter 700mv zu gehen, falls das überhaupt gehen würde.
obs jemals strom übers mainboard only für die grafikkarten geben wird? ist ja auch kein problem 400watt durch ne cpu zu jagen
@Mendokusaay mit Import Gebühren 44,90€. War mir dann beim Preis der 4090 auch egal^^. Habe das hier gekauft für mein EVGA PSU:
https://eustore.cablemod.com/produc...ibute_pa_pci-e-cable=16-pin-to-4-x-8-pin-pcie
Gedauert hat es ca. 3 Wochen. Habe kurz vor Release der 4090 bestellt.
Wirklich…
Macht bei der Karte den Kohl auch nicht mehr fett ^^“
Darf man das Kabel knicken 🤔
Eigentlich schon oder weil ist ja wie ein normaler Strang den man da sonst an klemmt
Finde da nirgends ein Hinweis
Werde ich mir heute Mittag bestellen für meine MSI Trio
Hm okay, den RivaTunerStatistics Server habe ich immer weggelassen weil "damals" mein Lieblingsspiel damit immer abgestürzt ist. Vielleicht ist das Programm die letzten zehn Jahre ja noch nachgereift. :d
Konkret hatte ich in Taur und Railgrade fast Volllast auf der GPU weil halt unendlich fps generiert wurden...
Jetzt mal ehrlich: die die hier irgendwie schon 7,8.9 Karten durchgetestet haben müssen doch checkout Bots benutzen. Gefühlt geht das ohne nicht mehr. Ausser natürlich bei den Händlern die eh schon extreme Preise aufrufen.
Homeoffice und Patte aufm Konto ohne zu überlegen zu bestellen. Außerdem ständig alle Tabs im Blick eventuell mit autorefresh auf mehreren Monitoren 😅
neee. Weil so mach ich das auch und scheitere am Checkout. Und sorry, so langsam bin ich dann auch nicht.
