[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hab' nach der Empfehlung gestern meines noch etwas runder gestaltet, schöner ginge nur noch wenn ich das Netzteil ausbaue und links auf den Schreibtisch stelle um eine gerade Linie aufrechtzuerhalten.:-)
Das getrolle hier heute ist unbezahlbar…..
2 Kabel und 1 Karte ist abgeraucht und gefühlt jeder 2. hat Angst das gleiche Schicksal zu erleiden oder bashed seitens Nvidia, weil man sich eh keine 4090 leisten kann 🙃
Irgendeine Sau muss ja immer durchs Dorf getrieben werden, Hauptsache Panik und Klickzahlen… letzte Gen war es die lächerliche Kondensatoren Nummer. Muss man sich wohl mit abfinden, im Internet ist es mit Rationalität nicht weit her.
Ich glaube ich bekomme kein Vertical Mount in mein Silent Base 800 rein.
Man kann nur hoffen, dass Nvidia in Kürze einen zertifizierten Stecker nach reicht, der um 90 Grad abgewinkelt ist und nicht so teuer ist.
Da hätte ich eher den Wunschpreis von 0,00€ für!
Ja bei mir ging's einfach nach dem Neustart und nachdem ich Die Stecker Mal alle raus und richtig fest wieder rein hab. Vor allem der an der GPU
Ohoh, nur noch 27 verbleibende Steckzyklen :lol:
Die FE scheint immer attraktiver. Die ist nämlich auch nicht so breit, dass die Steckerakrobatik so ausarten muss.
Wenn die PCI-SiG bzw. ATX einen Stecker designt/normt und für 600 W freigibt würde ich als nVidia nach positiv verlaufenen Tests (bei 600 W, nicht 900...) keine Gedanken machen.
Man muss ja festhalten: Die ATX 3.0 12VHPWR-Stecker schmoren an der Netzteil- UND GPU-Seite. Demnach ganz klar: Stecker/Terminal sind Schuld und nicht der Adapter. nVidia ist Schuld, dass sie das Steckerdesign (das ein Anderer freigegeben und erfunden hat) und die Adapter ausgesucht und nicht genau genug getestet haben. Bei der scheinbar eher niedrigen Quote gehe ich aber von einem Fabrikationsfehler aus, mit einer angenommenen Quote von 1 in 33.000 kaum vorhersehbar.
Trotzdem kommt es jetzt darauf an, Maßnahmen zu finden die das Vertrauen in den Stecker wiederherstellen oder eine Alternative zu bieten.
nVidia zu bashen ist einfach, Brandgefahr ist kein Pappenstiel – aber irgendwas ist immer und irgendwas wird ganz sicher auch dagegen unternommen.
P.S.: Das fehlende Feedback für's vollständige Einrasten fand ich auch sehr unglücklich. Hab auch dreimal geguckt bis ich mir sicher war, dass er ganz drin war und die Klammer eingerastet ist.
Für diese Behauptung trägt allerdings derjenige die Beweislast, der ein solches (fehlerhaftes) Verlegen vorträgt.
Oftmals wird (verständlicherweise) nach Bildern gefragt und anschließend dieses Argument angeführt. Welches der hier gezeigten Bildern/ Builds entspricht der empfohlenen Biegeradien? Selbst den Nvidia-Build könnte man demnach kritisieren:
Wenn man jetzt Gründe suchen will, könnte man behaupten, dass eine gewisse Last/ Widerstand auf dem Stecker lastet und dass das Kabel suboptimal verlegt ist. Nach den Empfehlungen ist es jedenfalls nicht verlegt.
Immerhin laufen 99%+ ohne Probleme.
find ich persönlich jetzt nicht so wild..
Das ist genau der Punkt. Es gibt weitaus "schlimmere" Beispiele und die Systeme laufen trotzdem. Mir ging's nur darum, dass man nicht gleich den Teufel an die Wand malt, weil ne Biegung oder ein leichter Knick in dem Kabel ist. Zumal sich das in vielen Beispielen kaum besser verlegen lässt.
Jetzt postest du noch ein Screen vom Schriftverkehr seitens Nvidia (costum-Karte direkt zu Nvidia schicken ?!?!) wie von dir behauptet und ich nehme dir die Trollkönig-Krone wieder ab!
Wenn interessiert wem du welche Krone abnimmst…WTF
Weiß jemand gerad warum es so wenig strix4090 Drops gibt? Bin schon ewig auf der Suche
Eigentlich wollte ich heute vernünftig dokumentieren was passiert ist und wie der Händler reagiert hat, damit andere auch etwas davon haben.
Aber nach den Kommentaren habe ich keine Bock mehr mich zusätzlich zu dem Ärger und dem Schaden auch noch zu rechtfertigen.
Naja, was erwartest du? Ist halt ein "heiß" diskutiertes Thema und die Leute sind sehr neugierig und ungeduldig. Logisch, dass da einige Kommentare aus der Reihe tanzen.
Wobei ich nicht mal finde, dass die Kommentare sehr aus der Reihe getanzt sind. Waren die üblichen Blödeleien und Witze, aber nichts unter der Gürtellinie. Wäre für mich noch lange kein Grund in eine passive Trotzhaltung zu fallen. Aber nun gut, jeder jeck is anders pflegen wir in Köln zu sagen^^
da finde ich die Person die sagt dass das Kabel schlecht gebogen war schlimmer
Ich hoffe du meinst nicht mich, ich habe gesagt es ist stark geknickt, weil es auf dem ersten Bild so aussah, die rangezoomte Variante entschärft das deutlich.
Abgesehen davon hab ich nicht gesagt, dass das die Ursache war.
Allgemein sollte man sich nicht immer gleich angegriffen fühlen, zumindest hab ich die Absicht nicht und wenn doch dann merkt man das schon deutlicher 😅😁
Nein nicht du
  • Danke
Reaktionen: hwk
Genau an dieser Stelle solltest du jetzt ein Foto hochladen, andernfalls macht dich dieser Kommentar nur noch unglaubwürdiger.
Man könnte meinen das Nvidia hier ne Menge User Finanziell Sponsort bei dem ganzen Fanboymaterial hier :ROFLMAO:
Waaassss du hast ein Schaden an einer Nvidia Karte das kann gar nicht sein wo ist die Beglaubigte Kopie der Aussage vom Bürgermeister von Berlin eine Nvidia Karte geht nicht kaputt das hast du falsch eingebaut und generell bist du ein Troll. Weißt du wieviel Geld ich für die Karte bezahlt habe die ist perfekt Fehlerfrei !!
