[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was hier immer für eine Panik geschoben wird. 😅 Wenn man bei Einzelfällen das Produkt nicht mehr nutzen will dürfte man gar nichts mehr benutzen.
Aber verständlich wie das ausgenutzt wird, sowas gibt halt auch gut Klicks.
Vielleicht hat der Dude auch ein Leben, was es nicht zulässt hier ständig im Forum zu idlen. Wäre aber eine zu einfache Annahme. Besser direkt Steinigen. (y)
Also wenn mein Rechner verschmort stinkt und der PC ausgeht, dann gehe ich nicht pennen, sondern schau mir das direkt an... aber warten wir mal auf nen response :d
Warten wir mal ab. Ich wär auch so dass ich da sofort schauen wollte. Aber kenn auch einige die könenn das :)
Im Zweifel natürlich immer erst steinigen :ROFLMAO: Aber wenn der Dude mit seinem Leben es schafft hier was in den Raum zu werfen, dann wird er es auch schaffen dies zu untermauern.
Wäre natürlich shice wenn das alles nur erfunden wäre. Aber es ist immer so: wenn die ersten Fälle in deinem Dunstkreis einschlagen, trifft es härter.
Stell dir vor, mein aktuelles wurde im April 2012 gekauft und funktioniert noch 🥹
Ebenfalls meinen vollen Respekt !!!
Dann hast du ja auch ein Paar ATX Standard Anpassungen ausgelassen und trotzdem ist alles gelaufen!
TOP!
Leute nur nochmal zusammenfassend ...
Wenn ihr halt jetzt ein Netzteil braucht, dann sind auch die aktuellen Marken Netzteile absolut in Ordnung!
Ob 3.0 oder nicht ist für die 4090 noch für die aktuellsten CPU und MB Generationen wichtig.
Wer keines braucht soll ja auch keines kaufen!
Wer noch Warten kann soll warten ... aber wenn ich halt lese, das hier manche ihr 650Watt Netzteil, welches vielleicht 10 Jahre alt ist, für Ihre 4090 verwenden, dann bekomme ich "In Eurem Interesse" Angst!
Das Argument, ich mach das nur weil ich auf ATX 3.0 warte ... nicht besonders Sinnvoll ... wie schon gesagt muss jeder selbst wissen.
Es muss halt nicht auf Teufel komm raus ein ATX 3.0 sein.
Also was jetzt wohl am meisten hilft, Ruhe bewahren :geek:
Was wissen wir:
Das lt PCIE-Gremium die Stecker schon bemängelt wurden.
  • Das es wohl bei hohen Leistungsaufnahmen und geknickten Kabel zu Problemen kommt.
  • Das die Stecker bei 500-600 Watt Leistungsaufnahme wohl doch schon sehr heiß werden können
    Das fast alle Karten-Hersteller ihre Karten nicht an das 600 Watt Powerlimit fahren, obwohl Board, GPU und Kühler definitiv mehr abkönnen. --> Warum?
  • Die Kühler können bis an die 900 Watt-1000 Watt Wärme abführen
  • Die Voltage ist auffällig gedrosselt
Jetzt Spekulation und 1+1 Zusammenzählen.
Viele Karten können durchgängig hohe Leistung liefern, dieser Dauerbetrieb erzeugt bei hohen Wattages Peaks sodass prinzipiell mehr als 600 Watt durch die Stecker geblasen werden.
Dies hat zur Folge das es unter Umständen (Kabel-Knickung) zur Schmelze kommt.
Eigentlich wäre ein zwei 12Volt Stecker Design vermutlich besser gewesen,
dann hätte man auch deutlich mehr Watt durchblasen können, Kühler und Board-Design geben es her, gerade bei den stärkeren Partner-Karten sind die Kühler unterfordert
Schlussfolgerung: Dieser liederliche Stecker, ein günstiges Bauteil, ist der eigentliche Flaschenhals.
Was nun:
Erst einmal nur die Originalen Kabel verwenden, keine MOD oder Drittkabel im Falle einer RMA
Und die Karten nicht über das 100 Prozent PT betreiben.
Versuchen Ruhe zu bewahren ist wohl das beste und hoffen, dass sich Nvidia rasch mit einer Lösung oder zumindest Handlungsempfehlungen äußert.
GameStar hat das Thema ja auch aufgegriffen und gerade ein Update gebracht.
Offizielle Reaktionen der Hersteller​
  • Nvidia hat sich uns gegenüber inzwischen geäußert, wenn auch nur sehr knapp. Man kennt den Fall demnach und steht mit dem betreffenden Reddit-Nutzer in Kontakt, um weitere Informationen zu erhalten. Im übersetzen Wortlaut lautet die offizielle Antwort folgendermaßen:
    Wir untersuchen die Berichte. Wir stehen mit dem ersten Eigentümer in Kontakt und werden den anderen für weitere Informationen kontaktieren.
    Die Karte hatte bisher also offenbar mehr als einen Besitzer.
  • Corsair gibt an, dass sie die Probleme in den eigenen Tests nicht nachvollziehen konnten. Man habe in hunderten von Stunden unter angemessener Last kein Verhalten dieser Art beobachten können, weder mit 12VHPWR-Adapter noch mit nativem Anschluss. Die im Bild unten zu sehende Biegung des Kabels im ersten bekannt gewordenen Fall schätzt Corsair auf den ersten Blick auf Basis der eigenen Tests als unproblematisch ein, allerdings mit dem Hinweis versehen, dass man individuelle Fälle nur mit der genauen Hardware wirklich testen und beurteilen könne.
Und wann er das macht ist ja wohl seine Entscheidung und nicht die mancher Forenteilnehmer…
Warum wurden nicht zwei Anschlüsse verbaut und die Last verteilt?
Zum Thema Netzteile...mein letztes ist 10-11 Jahre alt.
Es war ein 660W Seasonix-X Gold und wird noch genutzt, zuletzt war ein 11400F mit 3090FE dran. 400W OC kein Problem...
Bis ich ein SFF PC gebaut habe, da musste wegen der Größe ein neues her.
Aktuell läuft das 10 Jahre alte mit dem 11400F und einer 3060.
Ich vermute das von 100.000 Adaptern einige halt nicht 100%ig in Ordnung sind. Beim Testen sind die durchgegangen wie alle anderen auch, aber sie sind empfindlicher als andere beim biegen...
Da kan man noch soviele Kabel testen...solange man nicht DEN EINEN bekommt gehen alle durch.
Aber mal ehrlich ich hätte keine Lust einer von 100.000 die eine GPU mit Überraschung bekommen...
Auf Ü-Eier stehe ich nicht.
Hier, noch ein wenig Öl ins Feuer: "That happened to my 4090. I just got mine a couple of days ago. Prebuilt Cyberpower PC with 4090 in it and now I have to return it because the power connector melted."
markierte Antwort
Verständlich, ich hoffe auch das ich nicht betroffen sein werde. Und natürlich wird sicher nicht jedes Kabel das Produziert wird auch 100% getestet. Aber trotzdem gut das nVidia und andere sich dem Thema annehmen.
Heißt es nicht von Seitens Leuten die Kontakte haben, das die 600-900W Karten in Nvidias Labor abgefackelt sind?
Könnte natürlich ein Hinweis darauf sein, warum man die Titan Karte in Frage gestellt hat.
Also für dich wäre das auch vollkommen okay, wenn sich hier weitere "User" melden die von abgerauchten Karten berichten ohne Proofs zu liefern? Na dann mal Gute Nacht :rofl:
Manche von uns müssen auch arbeiten. Warte doch bis morgen ab, dann können wir ihn immer noch lynchen :d
Genau und jetzt fragt mal warum?
Am Board Design oder an der GPU wird es nicht liegen
Eher am Stecker...
Wie gesagt zwei Stecker wären für hochleistungs Betrieb besser geeignet
Ähnliche Themen
Antworten
7K
Aufrufe
588K
