[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das sieht nicht gesund aus. Hast du das Kabel zuvor stark gebogen?
Ne gar nicht, Sitzt eigtl. sehr gut und Hat genug platz sich zu "entfalten" :d
Dann tausche ich das mal aus und schicke es zurück... wieder dieser Kagghässliche Adapter rein ^^
Jetzt kann er von Glück reden dass er draufgucken kann. Beim 4 Zack ist da idR ein Schrumpfschlauch oder Gewebe drauf, da siehst nicht was drunter abgeht
Tu dir selbst einen Gefallen und wende dich an den Hersteller von dem Kabel. Wenn du ein anderes hast, benutze ein anderes!
Hat jemand schon das Bios Update für die TUF gemacht? In den Release Notes steht ja mal gar nichts sinnvolles drin :(
Mach mal. Wenn die Melodie aufhört, packe ich meine wieder aus und behalte sie. Glaube ich nur nicht. So wie sich das liest, dürfte das die Inkompatibilitäten zu diversen Boards adressieren.
Ich denke, die Ursache ist die Verkleinerung der Kontaktfläche in der Steckverbindung. Diese entsteht durch das Herausziehen der Kabel, wodurch sich die Kontaktflächen verringern, dadurch erhöht sich der Stromwiderstand und dadurch entsteht mehr Wärme, oder besser Hitze :fire:
Das ist eine Möglichkeit, die andere ist ein Verbiegen der Hüsenartigen Enden in der Kabelpeitsche. Dadurch weitet sich diese Hülse und der PIn wird nicht mehr sauber umschlossen. Übergangswiderstand -> Hitze
Würdet ihr sagen das kann zum Problem werden? Konnte das einzelne Kabel ca. ~0.5mm reindrücken, fühlte sich jetzt aber nicht locker an. Lieber auf das Adapterkabel ausweichen und zurückschicken?
Du hast die Haltepins des Steckers (da sind kleine Nasen dran) sicher beschädigt und die arretieren nicht mehr (die sind überdehnt / umgeklappt nun). Die vertikale Biegung nach unten war zu stark bei dir und die Haltenasen der rechten Ader haben aufgegeben. Entweder ganz reinstecken oder besser gleich ersetzen.
Passiert oft mit Custom Kabeln. Bei denen schiebt man es meist wieder rein. Musst es aber selbst wissen, ist deine Karte. Ohne Adapter greift möglicherweise die Garantie nicht, wer weiß wie sie sich herausreden wollen.
Der Vierzack ist aber anders am Stecker aufgebaut, da mehrere Kabel gleichzeitig pro Pin im Stecker sitzen. Da kann man es nicht einfach wieder reinschieben.
Also meine Suprim X hatte am Anfang echt heftiges Spulenfiepen.
Jetzt 3 Tage später ist es so gut wie weg.
Als Test nehme ich immer den Heaven Benchmark in 1440p und Extreme Settings um viele FPS und
hohe Last zu haben.
Aus dem geschlossenen Gehäuse höre ich nichts mehr und ich habe ein Meshify 2 das quasi keine Dämmung hat.
Hat noch jemand eine Windforce bei Alternate gerade bestellt? Habe gerade mit Express noch für 1949 zugeschlagen aber steht jetzt auf "Bestellung kann nicht bearbeitet werden, da Artikel nicht lieferbar" :(
Den Pin da wieder einfach reinfriemeln ist Pfusch, aber nicht meine Karte.
Würde ganz rausziehen und die Nasen prüfen bzw ob nicht verbogen. Am besten neu und nächstes mal aufpassen.
Das ist ein Fehler, da der Preis schon angehoben worden ist auf 2150€...für 1950€ ist halt keine auf Lager...da kannste lange warten bzw wirst storniert...
hohe Last zu haben.
Entspricht genauso meinen Beobachtungen, dazu noch etwas UV und alles ist gut :)
Mein Case steht auf dem Tisch und ist ein Corsair ICUE mit Verglasung
hohe Last zu haben.
Sorry, aber das klingt für mich nach ner G'schichte aus'm Paulanergarten.
Hast du das wirklich 1:1 getestet und nun nicht irgendein Limit G/V-Sync an?
Der erste Test war auch nicht in kaltem Zustand und nun der Dauerlauf warm? Da werden die ja leiser. Hat aber nichts mit einem dauerhaft leiseren Zustand zu tun.
Ich trink kein Paulaner ;)
Soll ich ein Video machen. GSync aus über 500 FPS und ganz leises Spulenfiepen.
Hat also immerhin 1 min gedauert bis die TUF wieder ausverkauft war
Aber das der Asus Shop erst am 11.11 wieder neue TUF bekommt kann man damit dann schonmal als Falsch abstempeln ... nun warte ich auf die Leute die wieder Schreiben "war sicher ein Rückläufer" 🤣
50 Sekunden war sie bestellbar (8 Stück). Ging richtig schnell!
Naja dass der Preis sich während eines Drops ändert ist ja nichts neues. Sowas passiert in Shopsystemen ja automatisch wenn viele Bestellungen eingehen und sollte eigentlich nicht zur Sornierung der früheren Bestellungen führen. Die Karte jetzt zu stornieren weil sie die später für 2150 abverkaufen konnten wäre schon mies. Hoffe es ist wie die Tage bei den Gainwards, die auch diesen Status hatten und dann aber doch an die Besteller ausgeliefert wurden, als die Ware dann von der Anlieferung tatsächlich im Lager ankam.
Nachdem die TUFs ziemlich zum fiepen neigen ist es kein großer Verlust wenn man Leer ausgegangen ist 😄
Du verstehst falsch, die Produktseite hat 2150€ angezeigt, aber die Karte war danach im Warenkorb für 1949€, also ein Fehler im System.
Ich würde fast sagen Aktualisierungszeit zwischen Frontend und Backend....
Btw wo bleibt die FE?
