[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der kritische Aufbau und das ist ja der Kontakt des Steckers, ist per Definition gleich. Was besser sein kann ist der Zug und Druck der über die Kabel auf den Steckerbereich wirkt, weils nicht so eine wirre Geissel ist. Aber ein Schwachpunkt ist das da drin. Ohnehin irre mit wieviel Ampere da über die Spielzeug Kabelchen gegangen wird. Wenn ich denke im Car Hifi nutzten wir damals für 600W gleich mal 20mm² Kabel (manche noch mehr).
Wenn ich hier jedoch mitlese, neige ich gerade dazu, die Karte zu behalten😅
Was meinen die Gentlemen und Ladys dieser Runde?
Meine TUF ist auch eine Banane. Keine Ahnung was da schief gelaufen ist, aber sie macht keine Geräusche und geht über 3 Ghz, darum wird sie behalten. Nach dem Wakü-Umbau soll es mir eh egal sein.
Geheimtipp: 4090 Silent Banana
Glück gehabt 🍀
Konnte eine 4090 Phantom (ohne GS) für 1949€ bei Alternate ergattern.
Wo genau liegt den der Unterschied zur GS Version, bissel mehr Takt bei der GS und dat war’s?
Meine Gaming OC läuft nun seit ca. einer Woche ohne Probleme. 2 der Lüfter eiern etwas, aber ansonsten kann ich mich nicht beschweren bisher.
Ganze 4 Jahre Garantie gibt's ja sogar drauf! Hab mir auch eine gesichert, bin gespannt aber lasse die noch im Karton bis zur Enthüllung und Benchmarks der RX 7900 XT.
90Mhz Boost weniger und kein 500W BIOS.
Ich betreibe meine mit 0,875v bei 2400 MHz. Maximal verbraucht man so 280w und dennoch hat man Leistung ohne Ende.
Da sollte es aber locker noch bis unter die 200 Watt gehen je nach Game mit FPS Limit und wenn mit Raytracing dann auch mit DLSS On! Berichte mal.
Verbrauche bei meinen Asus Rog Strix RX 6900 XT LC meistens keine 180 Watt in 4k und 60 FPS. Bei über 80 FPS je nach Game schon eher. Aber auch keine 250 Watt.
Ok, also absolut vernachlässigbar.
Wollte eigentlich die TUF wegen 2x HDMI, aber das lässt sich bestimmt tauschen.
Mal sehen was mein 700 Watt Netzteil nun sagt (ATX ist erst im Dezember mit den neuen Seasonics geplant die dann endlich raus kommen).
hat wer ne Idee warum meine 4090 FE instant crasht wenn ich versuche einfsch nur mit Volt Slider voll auf und Powerlimit voll auf nen Bench laufen zu lassen?
Ein ATX3.0 Kabel wird ja nichts ändern da das Problem ja der Stecker ansich ist. Oder eher im Gegenteil das Problem wird noch größer weil dann hat man den kritischen Stecker an 2 Stellen und nicht nur an einer!
Aus Technischer Sicht frag ich mich wie das überhaupt sinn macht der Stecker hat kleinere Kontakte bekommen und soll damit nun das doppelte an Watt Übertragen wie die alte Generation. 2x PCIE darf nur 300 Watt und hat aber die selbe Anzahl an Steckkontakte nur in einer größeren Dimension.
Klar man kann nun mit Material und Klemmkraft noch was reissen aber das Material wird nicht groß anders sein also bleibt nur die Klemmkraft und dann ist man bei dem Problem das wenn es nur mal was schräg reingedrückt wurde oder zu oft rein und raus ist die Klemmkraft dahin und dann geht das ganze nicht mehr.
Nunja, ein Pin der nur ein Kabel hat und nicht 2-4 ist deutlich unanfälliger.
Der Stecker der RTX 3000FE war genauso, aber da hat man eigentlich keinen Mucks von gehört...
Das ein 8-Pin nur 150W kann stimmt so nicht. Corsair hat seine 8-Pin (bzw 6-Pins) bis auf 300W gespecct. Deswegen gibt es von denen auch einen 2x8-Pin auf 12+4-Pin Adapter. Von dem laufen nur 12 Kabel +2 Sensor vom Netzteil zum 12VHPWR Stecker.
Am Ende wird es einen Ansturm auf Cablemod geben, wenn der Wickel-Adapter verkauft wird...
Gibt es eigentlich gesicherte Erkenntnisse, wieviel Speed es kostet, ECC einzuschalten?
Ach ich konnte nicht Widerstehen. Gainward GeForce RTX 4090 Phantom für 1949,- eben bei Alternate bestellt :d
Sollte am 03.11. AMDs Super Preiswunder kommen, kann man die immer noch zurückschicken ;)
same here
vor ner stunde ging ne Bestellung durch
mal sehen ob die dann auch ankommt
Hi, ist evtl. noch ein Cookie über oder bin ich zu spät? Danke im Voraus!
Hab aktuell keine mehr, aber lässt sich ja immer wieder fangen so lang sie nicht ausverkauft ist.
Welche Karte möchtest du denn haben?
gleich gut wie alle Anderen...
3.5 zoll kühler mit vapor chamber wie ne msi suprim
und ob sie fiept sieht man erst wenn sie da ist
Hi zusammen, eine Frage die vermutlich andauernd hier gestellt wird.
Gibt es eine grobe Vorahnung wann und wo der nächste Drop erfolgen wird?
Wie sucht man denn richtig nach ner Karte? Gibt es da wieder einen Bot hier?
Da ich beim Homesetup erstmal Vorhandenes nutzen möchte, weil weder zweiter Block noch zweite TUF 4090 zeitnah zum guten Kurs realisierbar, plane ich gerade einen etwas abenteuerlichen Loop mit einer 4090 TUF ABP Block (bestellt - auch, wenn nicht unbedingt nötig, da Abwärme über BP vernachlässigbar) und 3090 Strix mit ABP Block (weil vorhanden) in Kombination wie folgt einzusetzen. Terminals sind leider leicht versetzt. Freue mich über regen Austausch, Einwände oder Verbesserungsvorschläge.
Mainboard crosshair viii hero Wifi, O11D XL (ja, ich weiß - langweilig :-) ), Reflection2 Distro, Vector2 CPU Block, 3x P360M Radiatoren etc.
Tubing mit Quantum Torque Fittings. 14er Tube
Wenn hier unerwünscht, schiebe ich den Beitrag in's Wasserkühlung-Forum.
Falls dir eine GS über den Weg läuft, wäre ich nicht abgeneigt. :)
