[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich glaube hier ist der Windows Energiesparplan gemeint. Und wenn das so ist wäre es auch interessant ob der CPUAuslastubgsgraph Einbrüche zeigt. Könnte nämlich von Energiesparmodus wie C3-C10 kommen...
Könnten die 4090 Besitzer mal in Ihren "eventvwr.msc" ausführen und schauen ob ihr auch solche Meldungen habt vom Typ 4101 und 0? Wäre interessant zu wissen.
wenn ich heute Abend dran denke mach ich das :d
Die einzigen Treiber Resets an die ich mich erinner wurden aber durch OC/UV ausgelöst (zwei Mal in MW2 und beim ausloten in SpeedWay/Timespy). Seitdem war nichts mehr, und auf dem Desktop hab ich das bisher nicht gehabt/wahrgenommen.
auf wieviel Mhz boosten die FEs der FE Besitzer im Speedway hier im Thread? Meine taktet zwischen 2700-2715 hin und her. Kommt aber nach oben raus nicht mehr viel und bruscht auch für 2700 mindestens 950mV
Im Zuverlässigkeitsverlauf kann man das auch gut nachschauen. Ich habe die 4090 nun seit über einer Woche verbaut, insgesamt ca. 5 Einträge mit "Hardwarefehler".
Kann jeder gerne selber mal schauen. Hier flackert der Screen im Idle für ca. 10 Sekunden, danach ist alles wieder ok.
Ich denke mal, da kommen noch einige Treiber-Versionen und BIOS-Versionen, um das zu beheben. Vielleicht behebt das eine Gainward-BIOS ja dies bereits.
Hab gestern gesehen das für mein X570 Taichi ein Beta Bios rausgekommen ist wo von einem 4090 Unterstützung die Rede ist konnte aber leider nicht raus finden wo für genau .
Die Gigabyte Master 4090 wurde zumindest auch ohne das Bios erkannt!
Falls es wen interessiert .
Habe das Ereignis genau 1x und zwar, als BF2042 bei mir crashte, aber der Fehler ist mittlerweile seitens EA behoben worden.
Wäre doch interessant zu wissen welchen Boost die betroffenen Karten so an den Tag legen? Eventuell sind das primär die "OC" Modelle? Oder von Hand übertaktete Karten?
Betroffene Karten im Sinne vom Black-Screen im Idle?
Hier eine Gainward 4090 Phantom, ohne OC und ohne GS (alles stock unverändert).
Und sie boostet Stock wie hoch? das wäre auch interessant... Also Modell und Stock Boost Takt, wären nützliche Informationen denke ich.
Meine boostet auf ~2760 MHz und ist stable.
Das Problem tritt hauptsächlich im Idle auf beim Video gucken (youtube, twitch) oder surfen.
Meine Lösung die bisher funktioniert, ist ein negativer GPU Offset von -100Mhz. Manche berichten auch, dass das deaktivieren von Stromsparmachanismen ihr Problem gelöst hat, wodurch die Karte im Idle nicht mehr vollständig runtertaktet. Geht also in die selbe Richtung. Würde mich nicht wundern wenn der Boost Table auf manchen Karten nicht 100% stabil ist beim Einsatz von AV1(Videos) etc.
Also in Situationen in denen durchaus auch mal (wenn vielleicht auch nur kurz) in höhere Power States geschaltet wird, und dein negativ Offset, das bisher problemlos läuft spricht auch dafür, dass hier die Kurven etwas optimistisch von den Board Partnern gewählt wurden, da geht es vielleicht 1-2 Boost Bins zu hoch, weil die Temperatur sehr niedrig ist... wer weiß
Könnte hierbei der Curve Editor von Afterburner nicht Abhilfe schaffen?
Jein wäre die passendste Antwort. Denn wie man sieht hat man kein Einfluss auf die wohl in Frage kommenden Boost States im Teillast Bereich.
Wenn man jetzt aber ein negativen offset einstellt, zieht der sich weiter als im Curve Editor angezeigt, zumindest scheint der Offset auch Einfluss zu haben auf Dinge wie den GPU Video Takt:
Vermutlich kann das nur nVidia selbst fixen durch Treiber Updates und liegt weniger am Hersteller.
Ist alles noch ein Mysterium, klingt aber für mich schlüssig.
  • Danke
Reaktionen: hwk
Ein Profil mit negativ Offset für 2D und ne schicke Kurve/Profil für 3D. Kann man bei AB ja trennen.
TUF OC 4090 Win10 gerade nachgeschaut. Bisher noch keine wie oben beschrieben.
X570 Master neuste Bios Version vom Juli.
Das kann eigentlich nicht sein, da die Slots genormt sind. Es kann allerdings sein, das Slot 1 übersprungen wird und der PCI-E 16x Slot bei Slot 2 ist.
So wird es wohl sein. Beim Asrock ganz anders als beim MSI z.B. wie man sieht.
