[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Für die 3090 gab's ein Update um rBar zu ermöglichen.
So, hatte hoite schon 2 Mal schwarze Bildschirme, beide Male nur am Hauptmonitor. Konnte nur noch den reset Knopf drücken.
(An der Graka hängen 1xDP Hauptmonitor 3440x1440, 1xHDMI Telemetriemonitor, 1920x480).
Mal das oc rausnehmen, aber daran wirds eher ned liegen. Beide Male wurde es am Desktop schwarz.
Anscheinend gibt es für die MSI Suprim Liquid X ein 600W und 530W Bios - falls noch nicht bekannt.
Overclock Forum:
Not. Simply, MSI suddenly changed the bios from 600W to 530W in Suprim Liquid X for unknown reasons, some people who were lucky got a 600W bios card, but most people got a 530W bios card.
Hier das Posting und Link zum 600W - ohne Gewähr:
#2,729
Bios:
link
Ich habe meine Trio X mal ein Stündchen laufen lassen. Die Spulen haben zum Schluß genauso geschrien, wie zu Beginn.
Lass ich jetzt tauschen. Wenn nichts besser wird, wandert die in die Bucht.
Meine Trio X geht morgen deshalb zurück. Ich behalte meine Gamerock OC. Die hat fast kein Fiepen (geht bei der Trio X schon ab 80FPS los) und auch das rattern der Lüfter ist fast verschwunden.
Ja, ist aber nur bis 500 versichert, außer man macht das irgendwie über den logoix Schalter. Keine Ahnung wie das funktioniert, mit der regulären Paketweiterleitung, ist aber nur bis € 500 versichert
Transportversicherung "Safety First"ab 8,25 EUR(7,50 EUR bis €500 Versicherungssumme +0,75 EUR pro weitere €100)
kuckst du: https://www.logoix.com/cgi-bin/preistabelle.pl#table_anchor13
Da kann man anrufen/mail schreiben. Wenn ich das Geld für eine 4090 hätte, würde ich das klar über die abwickeln. Die Karten hier kosten meist 200 mehr.
Wenn du den Core übertaktet hast kann es schon daran liegen (theoretisch aber auch am VRAM), es geht ja die ganze Curve hoch.
Das betrifft zwar den Idle state nicht, aber wenn die Karte durch irgendwas in den Power State wechselt wenn auch nur kurz, kann das auch einen Treiber reset/crash auslösen.
Komischerweise sind 20 loops port royal kein Thema. oO
Aber k, gibt nicht ne sichere Methode OC auf 100% proof zu testen.
Hat Galaxy/KFA auch keinen Endkunden-Support mehr?
Hatte da noch gute Erinnerungen mit meiner GTX 670. Ich musste mich bei denen registrieren und bekam eine RMA-Nummer und musste die Karte auf meine Kosten einsenden.
Oft sind es Szenarios mit niedriger Last und Temperatur, die dann vllt auch noch zu ein paar "Boost Bins" höherem Boost führen und Probleme machen können :/
Ich würd das Mal Stock testen ob es da auch passiert wenn nicht war es wohl das OC, und Stabilität lässt sich eher schwer beweisen kann immer was geben das plötzlich Auftritt, für modern warfare 2 musste ich auch von 0.9V auf 0.91V hoch um Stable zu sein 😅
Hat jemand die INNO3D GeForce RTX 4090 iCHILL X3 und kann über die Karte was sagen?
War gestern die einzig verfügbare Karte für fas 2.400 Euro
Hatte eigentlich gehofft eine MSI Suprim zu kriegen aber die Berichte im Nachhinein bezgl. Spulen ist ja echt nicht gut. Dann bleibe ich jetzt final bei der Gainward, die nervt im Grunde gar nicht, nur halt beim Hochfahren das leichte Summen aber egal, kann damit glücklich werden. So extremes Fiepen würde mich dann doch deutlich mehr nerven.
WTF wie kann man dafür gegen 500€ bieten
Das Ding wird vorsichtshalber als defekt verkauft. Absolute Bastelkarte und so wie die aussieht war da nicht einfach mal nur der PC beim Transport runtergefallen. Verbogen ohne Ende, Abdeckunge fehlen. die war 100% auseinandergebaut.
Moar ist wohl nicht drin. GPU auf ca 2880MHz, VRAM als Kompensation auf 12500MHz. (y)
Werde die Karte trotzdem behalten. Die Leistung ist einfach so oder so extrem. (y) (vs 2080Ti von der ich umsteige)
Quake II RTX: 37 vs 130fps. Can da nur noch den Kopf schütteln. (y)
Nochmal, weil sie so good aussieht:
MOAR!
Aus 1120 bin ich. How rain. (y)
Und du?
mich stört die TUF nicht, bezogen auf Spulenfiepen.
Mit Undervolting bekomme ich eh nix mit.
Anscheinend Game stable habe ich jetzt 2400 MHz bei 0,875v.
Speicher läuft mit ungefähr 1000 MHz aktuell, da ich erst einmal die GPU testen möchte.
Anschließend gucke ich, ob der Speicher bei 1500 MHz auch wirklich Game stable sind.
Aber eins nach dem anderen.
Mich auch nicht . Also sobald ich die KH nutze auch ohne Sound höre ich nichts .
Ohne KH höre ich ein leises Surren , aber finde es recht human .Ändert sich auch bei hohen fps nicht sonderlich.
Hatte da durchaus schlimmere Karten , aber denke ist auch Glückssache .Finde die Lüfter von der TUF ziemlich gut . Machen keine unangenehmen Nebengeräusche .
Asus hat meiner Meinung nach gute Arbeit mit der TUF geleistet .Lediglich hätte man bei den Pads das so konstruieren können , dass man 1mm Pads verwendet statt die dicken ,aber alles im grünen Bereich . Habe von der Seite geschaut bei der Karte und scheinen alle ordentlich aufzuliegen .
MOAR!
Wie ist das mit den Lüftern bei Dir?
Also ich habe mir mal die Anzeige durchgelesen, hatte die schon vorher gesehen.
Die Karte war in einem PC drin und der PC wurde ohne Sicherung im PC transportiert. Sie ist warscheinlich aus dem Slot gefallen und hat einiges abbekommen. Anscheinend ist der rückseitige Lüfter dadurch kaputt gegangen. Die Karte selbst soll noch laufen.
Solange die Platine noch in Ordnung ist, kann man den Kühler für 100-200€ auf Ebay nachkaufen, von Leuten die eine Wakü drauf gemacht haben.
Bei einem Preis von 900-1000€ auf Ebay, wären also alles unter 600€ noch ein Schnapper...wenn man aufs Schrauben steht...
Energiesparoptionen auf "Ausbalanciert" gibt Ruckler in speed way.
Energiesoptionen auf "Höchstleistung", keine Probleme moar.
Habt ihr das auch?
Dieses Phänomen hab ich schon seit 2080Ti Zeiten, seitdem laufen alle meine Karten auf Höchstleitung im Treiber.
