[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sehr tolle qualität. undervolting kann ich nicht, habe da nicht die kenntnisse.
ich werde dann wohl die strix einbauen lassen.
ich hoffe das liegt nicht an meinen neuen netzteil "
ASUS ROG Thor Titanium, ROG-THOR-1600T-GAMING, 1600W ATX"​
Die 3090 vorher hatte das nicht, aber da hatte ich noch ein altes Crossair 1600watt netzteil. sollte ich das alte einbauen lassen? da fehlen aber glaube ich adapter.
Wie handhabt ihr es eigentlich mit euren alten Karten (Turing/Ampere)? Hebt ihr die als Backup-Karten auf oder verkauft ihr die direkt? Bin mir nicht ganz sicher, wie ich es am besten machen werde. Der Wert der Karten könnte nach RTX 4080 bzw. RDNA3 Reveal noch einmal steigen (Wenn man sieht, was das für "Krücken" sind)...
Meine 6800XT MB ist beim Arbeitskollegen untergekommen :)
Habt Ihr die Hoffnung, dass sich die Fieb-Geräusche unter WaKü reduzieren?
Unter Wakü hört man es eher noch deutlicher, weil die Lüftergeräuche sonst noch etwas dafür Sorgen das fiepen zu dämpfen.
Gibt es Leute hier die eine 4090 trinity haben? Und Erfahrungen dazu? Habe eine 4090 trinity geschossen kann sie jedoch erst Donnerstag verbauen wenn der Rest da ist. Viele Grüße
Also die AMP Extreme AIRO (gleiche pcb mit weniger mosfets, gleicher kühler, leicht andere abdeckung/lüfter) ist ganz okay, lüfter könnten besser sein, aber dafür sind die spulen deutlich angenehmer. würde sie deswegen einer asus oder msi vorziehen, da die lüfter nicht ansatzweise so nervig sind wie laute spulen.
Habe hier etwas mitgelesen bez. spulengeräusche. Ich habe eine Supreme X und die macht so geräusche wie ein rasierer, wenn ich spiele.
Ist das dieses störgeräusch?
habe auch noch eine ungeöffnete strix. sind die besser?
japp und die asus karten sollen wohl auch recht schlimm sein, kann von karte zu karte aber immer etwas varrieren.
Sowas in der Art wäre mir auch am liebsten. Meine FTW3 3090 hat noch bis Oktober 2026 Garantie. Wenn man die an jemanden verkauft, ist die zusätzliche Garantie halt nicht übertragbar. Wenn ich niemanden in meinem Umfeld finde, behalte ich sie einfach als Backup-Karte. Ist dann irgendwann auch ein Relikt, weil sich EVGA ja aus dem GPU-Markt verabschiedet hat. ^^
ist einfach, gibt auch ordentliche Guides.
Ich verkaufe die meistens. Meine 3090 biete ich aktuell auch in der Bucht an zu einem ordentlichen Preis unter dem was sonst so geht. Aber aktuell wenig Interesse. Notalls wird die im Zweiterchner verbaut der irgendwann an meinen Neffen gehen soll. Sofern der überhaupt mal zum Zocker wird.
Diese Karte hat gefühlt jeder. Was jetzt alle einholt die eine verkaufen wollen. Dank Step Up und co.
Na das würde mich sehr interessieren ob die Strixx da besser ist !
Das Störgeräusch was du beschreibst könnte das Surren sein!
Es gibt meiner Meinung nach fiepen surren oder rasseln.
Surren hab ich auch schon in Kombi mit einem fiepen mal hören dürfen!
würde mir da wenig hoffnung machen, dass es mit dem anderen netzteil besser wird.
Ab Donnerstag kann ich endlich testen, welche 4090 es bei mir wird. Habe 3 Karten zur Auswahl und mache es rein von der Geräuschkulisse abhängig.
Könnt ihr mir einen Ratschlag geben, welches Spiel / welche Anwendung ich am besten nutzen soll? Habe leider die Woche nicht viel Zeit und möchte möglichst effektiv und schnell testen.
Da ich auf einem OLED spiele, der max. 120 Hz darstellen kann, überlege ich, ob ich einfach auf 120 fps begrenzen soll.
@MS1988
jop bei mir hat die Palit ja nur 450w festes Powerlimit, daher hast du vermutlich mehr points. Außerdem, beim Timespy zumindest, hast du auch einen besseren CPU Score. Der 5800X3d ist nicht optimal für 3dmark. Da auch kein OC möglich
Hat jemand eine Ahnung warum ich von der deutschen A Seite absolut nicht nach Österreich ordern kann?
A.at hat keine einzige 4090 im Programm
Echt zäh hier in Ö: A liefert nicht, MF auch nicht 🤬
Ich möchte endlich eine 4090 zu einem halbwegs fairen Preis
Und bei mir passen nur: FE, Palit, Gainward und PNY
Die Firma nutzte ich regelmässig für den Weiterversand nach PT. Funktioniert einwandfrei und die Preise sind günstig. Wurde genau für deinen usecase D/AT gemacht.
Bestell und teste doch noch 3 andere, da findest du sicher die beste!
Ja, ist aber nur bis 500 versichert, außer man macht das irgendwie über den logoix Schalter. Keine Ahnung wie das funktioniert, mit der regulären Paketweiterleitung, ist aber nur bis € 500 versichert
Jo drei Karten pro Woche sollten es schon sein :d
habe beim verkauf meiner 3080 auch dort hingeschickt. hat alles geklappt
Damit liegst du richtig.
Bei der Strix hilft auch nur testen, würde aber nicht zuviel erwarten. Meine Strix war noch schlimmer als die Suprims.
also ich finde, dass die gigabyte gaming oc aufjedenfall was spulenfiepen/rasseln angeht, definitiv besser ist als die suprim x oder der strix. bisher hat keiner, der eine gigabyte gaming oc hatte gemeckert.
Wie bereits geschrieben: ist aber nur bis € 500 versichert sobald die das der Ö Post übergeben haben, außer man macht das irgendwie über den logoix Schalter. Keine Ahnung wie das funktioniert, mit der regulären Paketweiterleitung, ist aber nur bis € 500 versichert.
Ist mir bei einer 2000 € Karte ein bisschen zu hoch das Risiko
Können die, die deutliche Spulengeräusche haben mal versuchen ob sich etwas ändert wenn ihr das Ingame Overlay von GFE abschaltet bzw. wenn ihr es bisher schon abgeschaltet hattet, wie es sich verhält wenn ihr das anschaltet?
Bitte wirklich mal testen. Kann ja sein, dass ich jetzt nach der ganzen Testerei echt einen an der Waffel habe, oder die Ohren stumpf werden. Schließe ich beides nicht aus.
Klingt komisch aber nach 7 Tagen dauerzocken macht meine Asus TUF non OC keine Fiep oder Rattergeräusche mehr mit Ausnahme wenn es an die 200,300 fps geht . Aber selbst dann ist es ein leises rasseln/fiepen.
Bim echt glücklich mit dieser GPU. Dank Metallgehäuse sehr hochwertig und stabil. Konnte die für UVP 1949,- ergattern.
Weiß jemand wieso dieses TUF non OC Modell nur bei Asus Eshop zu finden ist und nicht bei anderen Händlern?
die meisten händler listen einfach nicht was nicht verfügbar ist... geht wohl primär darum, dass die seiten nicht dauerhaft von zig 100 leuten gescannt werden.
Man sollte immer unterhalb der maximalen Aktualisierungsrate des Monitors bleiben, sofern man denn Gsync nutzen will, was auf jeden Fall zu empfehlen ist. Oberhalb von den 120fps funktioniert das nämlich nicht mehr. Für die perfekte Erfahrung auf dem OLED macht man folgendes:
Gsync- Ein
Vsync - Ein
Max FPS im Treiber: 117 oder 118 fps
Grafikeinstellungen im Spiel an dieses FPS Ziel anpassen, sofern möglich/nötig
Nur hier mit dem Displayport der Graka als der flackerte und meinen Monitor statt 120 FPS auf 85 stellte. Nach Gewackle und paar Neustarts ging es wieder...Ansonsten bis jetzt begeistert.
Im Sommer wenn die Leute in Urlaub fahren und mehr draußen sind bekommt man die 4090 bestimmt für 1500 - 1600€ und die 4080 für 900 - 1000€.
Und wenn du Pech hast bekommst gar keine mehr, weil China versucht Taiwan heim ins Reich zu holen, es Weihnachtet schon sehr, lecker Spekulatius. 😆
Meine Trinity boostet auch so hoch. 2805 @Stock. Bis 3050mhz getestet und noch alles stable. Finde die Karte auch Top. Spulenfiepen bei mir auch nicht wahrnehmbar in geschlossene Gehäuse...
jo bei mir das Gleiche, kann da auch nichts hören und die Lüfter haben noch massiv reserven. Hab jetzt zum testen mal ein bisschen rum gespielt und gut 3Ghz sind für die Karte wirklich gar kein Problem. Weder wird sie zu laut noch zu warm. Cyberpunk 2077 und Modern Warfare 2 laufen damit ohne Probleme. 3d Mark habe ich mit diesen "Alltagssettings" auch nochmal laufen lassen...
