[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nach Weihnachten werden die Preise fallen. Im Januar geben die Leute noch ihre Gutscheine und Geldgeschenke aus und dann beginnt die Talfahrt. Im Sommer wenn die Leute in Urlaub fahren und mehr draußen sind bekommt man die 4090 bestimmt für 1500 - 1600€ und die 4080 für 900 - 1000€. In zwei Jahren zu der Zeit bekommt man dann die 4090 Ti im Mindstar für 1100 - 1200€
hatte Zittern und Bauchweh
Nach Weihnachten werden die Preise fallen. Im Januar geben die Leute noch ihre Gutscheine und Geldgeschenke aus und dann beginnt die Talfahrt. Im Sommer wenn die Leute in Urlaub fahren und mehr draußen sind bekommt man die 4090 bestimmt für 1500 - 1600€ und die 4080 für 900 - 1000€. Nächstes Jahr zu der Zeit bekommt man dann die 4090 Ti im Mindstar für 1100 - 1200€
Klar, ich zock in der Zeit mal weiter. :)
Deine Glaskugel ist kaputt :)
Kann schon Feedback zur Gigabyte 4090 Gaming OC liefern.
Pro:
Sieht in echt deutlich besser/wertiger aus als auf Bildern.
Stock 2775Mhz@1,05V, 2850MHz@1,1V. Erster Test läuft sie bei 3100MHz@1,1V stabil.
RAM bleibt deutlich kühler als zB bei einer TUF. Macht +1750MHz ohne Bildfehler.
Für mich das wichtigste: Spulenfiepen ist vorhanden aber auf einem gutem Niveau. Mit geschlossenem Gehäuse unterm Tisch hör ich sie nicht. Top! Absolut kein Vergleich zu den MSI oder ASUS Karten die ich hatte. Die KFA2 ist aber nochmal etwas leiser.
Cons:
Lüftersteuerung ist Out of the Box nicht gut. Lüfter läuft erst bei ~34% an. Karte regelt die Lüfter zu schnell hörbar hoch.
Paar Lamellen des Kühlers haben etwas Grat Rückstände.
Wer die Karte auf Wasser umbauen will, absolute Empfehlung.
Kühler aber schwächer als ASUS TUF, Strix oder MSI Suprim X, Trio X. Mit Lüfterkurve manuell anpassen gehts aber gut klar.
kühler insgesamt schwächer aber dafür bessere vram temps?
Korrekt. Lüfter müssen etwas höher Drehen für die Verlustleistung wegzschaufeln.
Die Kontaktfläche des Kühlers zum RAM scheint aber sehr gut zu sein. Der bleibt durch die Bank Kühler als bei allen anderen Karten die ich hatte.
Mal kurz nen Miner auf der 4090 FE laufen lassen ohne da jetzt iwie tiefer in die Settings zu gehen. EtcHash soll ja ähnlich ETH sein. Also die Mem Temps ähnlich ausfallen.
Mit +1500MHz auf Memory und nichts weiter geändert, auch Lüfterkurve @Stock und geschlossenem Gehäuse kam sie nach ca. 15 Min auf 92°C Mem Temp und max 70°C GPU Temp.
Da schien dann Ende zu sein.
Ich denke das müssten gute Temps sein wenn damals die Leute extra die Pads getauscht haben um nicht in die 110+°C zu rennen^^.
Super ärgerlich , es kommt bei MM eine Karte rein und ist sofort weg, definitiv Bots
habt ihr ocler neben dem oc auch das PT gesenkt oder gebt ihr der karte alles?
Wer will die 4090 denn in einem bzw zwei Jahr haben 😄😄😄. Da spar ich bereits auf die 5090
Also ich höre nach der 4090 auf mit dem upgraden. Das habe ich mir schon bei der 3090 geschworen :)
Richtig so. Also wenn ich mein aktuell alter nehme, und jede 2 Jahre ne neue graka nehme bin ich bei +- RTX 26900,wenn ich aufhöre zu zocken 🤩🤩🤩
Hi, hab nur die Zotac Trinity ergattert. Mit dabei ist ein 3x8pin Adapter. Könnte ich auch einen 4x8 Adapter dranhängen und damit ein 600w Bios flashen?
Also wenn die Karte NUR ein 3 pin Adapter beiliegt, würde ich nen Teufel tun da 600Watt durch zu jagen 🫠
Irgendwie geil, mein 1000W Netzteil kommt aus der RMA zurück soeben und als ich das Paket öffne fehlen komplett alle modularen Kabel. Gute Arbeit...
bei RMA niemals Zubehör mitschicken, wird einem idR aber auch so gesagt. Die haben ihr eigenes Testequipment/kabel. Alles, was da rumfliegt, kommt im Zweifel - außer dem Produkt, das getestet wird - nicht wieder zurück.
mal sehen ob die die kabel wiederfinden ansonsten eine runde cablemod :d
Sollte doch auch für 600 Watt ausgelegt sein oder nicht? Stock macht die Trinity 19429 in TSE. Find ich eigentlich echt gut für den Billigheimer. Spulenfiepen bis jetzt nicht wahrgenommen. Mal schaun was da Taktmäsig noch geht.
Das sollte aber bei keiner 4090 ein Problem sein ....
Würde aber rein theoretisch funktionieren?
Ähnliche Themen
Antworten
7K
Aufrufe
585K
