[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also das 600 Watt Bios macht meine SurimX richtig Beine:
das ist so ein armutszeugnis, dass man die Arbeit von einem Board-Partner erledigen muss. MSI spuckt halt einfach in die gesichter der treuen fans...
ich habe den thread verfolgt im msi forum... da redet man wirklich gegen eine Wand
Sollen se behalten den scheiss, einfach 400 Euro über UVP, hoffe die bleibt liegen
das musst du dir mal vorstellen. Diese H**de stornieren erst mal alle fe weg und scalpen danncmit der tuf non oc. denen gehört der Verkauf der fe unterbunden und sie sollten ein nischendasein führen... nbb der größte saftladen...
Ich habe mehr Core Takt und mehr Speicher Takt. Temps sind gleich. Aber du hast knapp 7% mehr Leistung.
JayzTwoCents meinte, dass die Error Correction greift, wenn der Speichertakt zu hoch ist und damit Leistung flöten geht.
Ich habe null Ahnung von OC, aber vielleicht hilft dir das weiter?
Sehe, selbst 1 Uhr Nachts deutscher Zeit am Wochentag geht ne UVP-Karte instant weg. Hatte vorhin kurz Hoffnung die Kfa2 bei Saturn einzusammeln. Njet.
Trotzdem wäre JETZT die beste Zeit für ein FE Drop :d Da hätte man bestimmt mal 5-10min Verfügbarkeit...
Das 12VHPWR-Kabel von be quiet ist bei Mindfactory mittlerweile übrigens auch ausverkauft und nicht mehr lieferbar. Hab gestern Abend meine Bestellung bei CU noch storniert und das dort geholt, dann hab ich zum Wochenende endlich wieder Ordnung vorne im Gehäuse und hinten nicht so viele dicke Kabel rumliegen. Das steht hier gerade noch provisorisch ohne Kabelmanagement und mit offenen Seitenteilen rum.
Aber Wahnsinn, wie verrückt die Leute nach einem solch simplen Kabel sind. Die Adapter erfüllen zwar ihren Zweck, aber das will sich scheinbar trotzdem niemand antun.
Ich frage mich wann mal das Corsair Kable hier ankommt...
3DMark hat jetzt ja DLSS3 drin. Ist schon lustig...
Da kann die "60 FPS reicht" Fraktion bald auf 8K umschwenken :d
Ich vermute fast der Bot funktioniert auf Saturn nicht bzw. nicht schnell genug. Gerade wieder auf den Alarm der TUF OC geklickt und schon nicht mehr bestellbar. Quasi direkt als die E-Mail kam bzw. 1 Minute nach detection.
... gleiches Spiel gerade wieder.
Was bringt das Bios Flashen denn eigentlich? Ich hab den OC Wert vom Werk aus dann übernommen. Aber selbst OCn ist doch da sowieso besser. Oder übernimmt man da auch was anderes Wichtiges beim Flashen?
Kann den LG C2 in 42zoll sehr empfehlen. 100cm sollten es aber sein zwischen Auge und TV.
Ich sitze 80cm vom 48" weg und er könnte meinetwegen noch größer sein. 😅
Guten Morgen
15 Seiten in 18h? Ihr seid nicht ganz sauber :fresse:
Normalerweise müsste man eine Karte nehmen und alle BIOSe durchflashen und gucken, wie die MHz von Hersteller zu Hersteller manipuliert werden.
TUF +0 MHz
Strix +45 MHz
Supreme
usw
Ich hab aber keine Lust :fresse:
Wichtig ist aber, dass man alle BIOSe mit der selben Karte durchtestet.
Und immer bei gleicher Temperatur!
Du schaffst das... :)
***** Gear Solid - FTW :d
Meine Suprim X kommt heute laut DHL, jedoch bin ich mir noch nicht sicher ob ich sie auch behalten werde.
Das Model gehört sicherlich zu den besten, jedoch ist sie keine 330€ besser als die ganzen 1950€ Modelle für meinen Anwendungszweck (UV/PL auf 300-350W, kein OC), sollte ich so ein 1950€ Modell abgreifen können in den nächsten Wochen geht die Suprim vermutlich zurück.
Da ist es sehr Hilfreich das ich die Karte bei Media Markt gekauft habe und ich dort Clubmitglied bin = 28 Tage Rückgabefrist anstatt nur 14.
Hab auch noch eine Suprim X bei Cyberport liegen. Weiß aber noch nicht, ob ich sie abhole. Mir reicht die Windforce eigentlich.
Die 4090er sind einfach schon als "standard" Varianten so abnormal schnell, das die OC für den "normalen" User nicht nötig sind. Bin mit der Palit, ob nun OC oder non OC (beide unter 2k), absolut zufrieden. Sellten so einfache zu nutzende Karten gehabt. Bisschen UV bei standard Boosttakt 2700 und man hat ne verdammt schnelle, leise, kühle Karte.
Beste Grüße
Case: Sharkoon TG6M im -->Angebot 59€. Da passt auch die Glasscheibe rein! :xmas:
Sag mal, funktioniert das mit der Soundkarte da knapp unter dem Kühler? Der Lüfter da drüber kann doch nix mehr ausrichten, oder? Ich frage deshalb weil das bei mir ähnlich sein wird, hab schon überlegt die Soundkarte über die Grafikkarte zu setzen. Aber wenns da recht warm wird (meine 3080 heizt gut nach oben) ist das auch nicht toll...
Und wie setze ich diese höher? :)
Da gibts nichts zum höher setzen.
Der Hinweis von mir hatte folgendes Ziel: Wenn Du Übertaktungseinstellungen variierst, dann schaue nicht nur auf den angezeigten Takt, sondern auch auf den effektiven Takt.
Grund: Es kann sein, das letzterer nicht so sehr ansteigt, wie ersterer. Damit steigt dann auch nicht die FPS-Leistung entsprechend an.
Ergo kann man sich dann eine Übertaktung, bei der so etwas spart, auch sparen.
Der Unterschied zwischen dem angezeigten und dem effektiven Takt kommt, soweit ich das von CPUs her übertrage, dadurch zustande, das die Grafikkarte Zyklen einschiebt, in denen nichts berechnet wird.
Warum sie das tut bzw. auf welcher Basis sie das entscheidet? Keine Ahnung.
Ist bisher imho auch stiefmüterlich bei Reviews und Co aufgefallen.
Das höchste der Gefühle ists noch, wenn einem Youtuber auffällt, das weniger FPS anliegen (Undervolting-Thema).
Den effektiven Takt hats ja schon bei Ampere gegeben. Nur wärs mir da nicht als so großer Einfluss beim Benchen aufgefallen.
  • Danke
Reaktionen: SH
Das kann schon sein. Ich habe es gestern auch nie geschafft bei Saturn eine Karte in den Warenkorb zu packen, obwohl ich instant geklickt habe, wenn die Meldung kam. Bei MediaMarkt hat es allerdings fast jedes Mal geklappt.
Bei EKA sind jetzt die 200 Karten deutschlandweit erreicht, die Anzahl von Arschlöchern die den Mangel befeuert wird immer schlimmer.
Aquacomputer scheint was für die Palit zu bauen:
Die haben die Karte im normalfall nur in House wenn sie einen Kühler planen.
Beste Grüße
Zwischen Graka und Soundkarte ist ein Slot frei, das wird nicht so heiß, geht ohne Probleme und die 4090 wird nicht so heiß wie die 3090.
Beste Grüße
Nein sie hatten es geplant weil sie dachten ist referenz, ist aber keiner, sie machen nur nen kühler für strix und Fe
Danke dir.
Also halten wir mal fest :) Es gibt User hier im Forum, die eine LN2 4090 easy schlagen. https://www.3dmark.com/compare/pr/1783443/pr/1767310#
Irgendwann wird der exploit schon an das Tageslicht kommen. Nutzen ja momentan schon 5-10 Leute. :)
Ah okay. Wäre für den ein oder anderen vielleicht interessant gewesen.
Beste Grüße
Das musst du dann mal so sehen, früher wurden solche Karten auch öfters von Minern gekauft, das ist jetzt aber hinfällig und trotzdem kaufen "normale" Gamer Karten um 3000+??!! Ist ja schon ein wenig krank.
Ähnliche Themen
Antworten
7K
Aufrufe
430K
