[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das heißt, es ist kein Fehler? Dann sind 93,8 Powerlimit? Warum komme ich dann nicht auf 100? Liegt das an den Adapterkabeln? Es sind alle 4 Stecker am Netzteil angeschlossen. Netzteil ist ein Corsair HX 1500I W. Treiber habe ich schon mehrmals mit DDU neu gemacht, hat aber nichts gebracht. Gibt es noch mehrere mit diesem Problem?
Hier im Forum gibt es jemanden der mit der Asus Karte so ein Problem hat.
Sorry hab im Eifer des Gefechts schnell geschrieben
LG
Ach du kannst nicht auf 100% ziehen...jetzt dämmerts.
Ich glaub ich hatte das bei meiner Suprim auch am Anfang. Hab den PC ausgemacht, nochmal an allen Stecker gecheckt, ob die auch wirklich alle fest drin waren auch den an der Karte selbst und hab drei vier mal den BIOS Switch hin und her bewegt. Dann PC wieder an und es ging, aber keine Ahnung was es jetzt genau war, die Stecker an Karte, am Adapter, an der PSU selbst waren alle fest eingesteckt.
Also einfach nochmal alles checken und vielleicht auch nochmal den BIOS Switch betätigen. Kannst ja testhalber mit dem Silent BIOS mal hochfahren und schauen was der AB sagt.
Und an der CPU kann es nicht liegen :)
Der erste hat einen 10900K mit 5,3GHZ laufen.
Ihr Cheater! 😂
Edit: Auch bei OC wird bereits spekuliert, dass Leute ein Driverexploit oder ähnliches gefunden haben um höhere Punkte zu bekommen:
Wäre ein TUF 4090 OC Besitzer so nett sein Performance Bios zur Verfügung zu stellen? :angel:
kannst du mit nvflash sichern..
x:\nvflash64.exe --save xyz.bin
Q und P unterscheiden sich nur durch eine andere lüfterkurve.
tobi
Mal was von einem Flash noob. Einfach ist es glaub ich zumindest 😄. Aber jetzt mal eine Frage.
Schalter steht auf Gaming Bios zb. Ich Flash nun das BIOS. So nun ist da was schief gelaufen. Stelle auf quiet bios und boote. Geht ja weil original bios ist. WIE bekomme ich nun das defekte BIOS auf dem Gaming bios wieder zurück geflasht?
PS ist nur ne trockenfrage, ist nix passiert
@Brainscan1979
Du schaltest auf Performance-Bios. Rebootest Deine Kiste. Steckst das Monitor Kabel an die interne Graka von Deiner CPU und schreibst was laufendes.
Alternativ gibste vorher schon Deinen Destkop frei, bootest durch ohne Bild und machst das dann per Remote Desktop.
Alternativ steckste irgend ne Graka aus Deinem Schrank in irgend einen freien PCIe-Slot und steckst an die das Kabel.
@Brainscan1979
Hab keine interne graka 😄 hab nur den KF
Du kannst mit dem Normalen funktionierenden BIOS Booten und im eingeschalteten Zustand den Schalter umstellen. Anschließend flashen.
Das BIOS wird nur am Anfang geladen.
Kann im Betrieb umgestellt werden zum schreiben.
Ich bin ja echt auf morgen gespannt mit dem 13900 ob da auch was tut in Sachen CPU Limit und UHD. Hatte eigentlich nicht vor von 12900 upzugraden
Der "Adapter des Schreckens" macht die schöne Ansicht zunichte. :d
Das kostenlose Seasonic 12VHPWR Cable wurde genehmigt und kommt sicherlich erst im November, solange bleibt das Kabel erstmal dran.
Interessant.
Habe gerade auf meiner Backup SSD ein frisches Windows installiert. Und siehe da im AB habe ich ne andere Default Curve nun als im alten Windows
Jetzt habe ich bei 1.05v 2775mhz statt 2760mhz und bei 1.1v 2865mhz statt 2825mhz
Wofür? Es ändert sich nichts.
Falls die Curve im Idle anders ausfällt, liegt an der Temp.
TUF OC auf TUF kannste dir sparen.
Dann nimm lieber das Strix.
Interesse!
Strix Silent läuft sauber.
Strix Performance macht Probleme (Treibereset).
Tuf OC Performance möchte ich noch vergleichen.
Also auch mit einem FRISCHEN Windows Knack ich die 11k nicht.
Egal 😄😄😄 aber dafür auch immer noch 240/1800 Stable 🤩
Habe heute Nachmittag eine KFA2 bei Saturn bekommen. Ist schon im Versand.
Ja, ins Meshify 2 Compact.
Kann dir am Wochenende aber auch sagen, ob ich die GameRock ins Meshify 2 Compact bekomme. Wünsch mir Glück :)
Heute angekommen 🥳
Gib dann bitte mal bescheid, ob die Lüfter deiner Karte auch so laute Motorgeräusche haben.
  • Danke
Reaktionen: SH
Ähnliche Themen
Antworten
7K
Aufrufe
588K
