[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die FE ist so begehrt, weil Nvidia die wohl auch selektiert. In Jayz2Cents Video schafft die FE einen höheren OC Takt, als seine Strix. Dazu ist sie noch die Karte mit den kleinsten Maßen und passt daher in viele Gehäuse. Am Ende geben sich die Karten alle wahrscheinlich Max. 5% Leistungsunterschied, wenn man sie nur zum Zocken nutzt.
Ach ja, und die ganze Folie ist auch noch drauf
Lg
Oder es war einfach Glück?
Kann mir nicht vorstellen, das es da wirklich einen Selektierungsprozess gibt...
Sehr gut zu NV, gut zu ASUS und ganz zum Schluss kommt Zotac?!
Hat Plague Tale denn jetzt auch schon DLSS3 und RTX ab Release? Oder muss man da auch erst auf einen Patch warten?
Naja die FEs sind auch in den Benchranglisten gut vertreten.
ich will auch ne FE :(
Bei mir wird GFE wohl nicht anspringen mit der 4090, habe meiner Freundin jetzt ne 3090TI FE reingehauen und den ganzen Tag irgendwelche Games am idlen.. vllt bekommt sie ja den invite :fresse:
Die FE bekommt die besten Chips. Bei Asus werden die Guten aufgehoben laut Gerüchten. Und andere Hersteller kaufen warscheinlich nicht so viele gute ein . Nvidia sagt warscheinlixh wenn du zwei gute Kisten kaufen willst musst du auch eine schlechte kaufen .
Dat ein Game anno 2022 sowas nicht hat ist echt nervig. Ich für meinen Teil mag Filmkörnung überhaupt nicht und schalte es immer sofort aus.
Geht mir auch so. Da muß ein Patch her das man das abschalten kann.
ausserdem bekommen die Influencer immer selektierte Samples.
Meine ist bei +1000 bisher auch nicht abgeschmiert.
Und zum Thema Speichertemps der TUF, nach 2h Far Cry 6:
Natürlich gibt es Anwendungsfälle in denen die höher ist, aber weit weg von problematisch :d
Zu den speichertemps. Es kann aber dennoch sein, dass ein vram modul bei mir nicht gut die wärme leitet und deshalb bei 1000+ crasht.. Der sensor zeigt ja nicht für jedes ram teil die temp an.
Der Mediamarktdrop war ja auch reichlich schnell weg
RTX ist nicht dabei DLSS3 dafür, siehe meine Screens mit Zwischenbildberechnung auf der letzten Seite.
Das ist schade. Nach den Infos bisher zu DLSS3 macht das ja am meisten Sinn, wenn man unterhalb der Vsync Range bleibt, also 120Hz. So wie es aussieht ist es ja ohne RTX kaum möglich dies zu erreichen mit einer 4090. Karte hat einfach zu viel Leistung lol. Also dann lieber nativ oder DLSS2 Quality
Wenn es schon um Plague Tale geht. Hatte jemand schon das Problem dass in den Grafikoptionen DLSS Frame Generation als Option komplett fehlt?
Auf 90PL + 145 CoreClock und + 800 Mem waren die Temps bei 65/66°C Core, HotSpot 72/74, und 72°C Mem bei ~400W (statt ~440W @Stock). FPS sind dabei gleich wie @Stock
Auf 72 PL + 145 CoreClock und + 800 Mem sind die Temps gerade auf 60°C Core, 67°C HotSpot, 66°C Mem bei ~320W. Ca 4-5 FPS weniger (71 statt 76)
Wie sind die Temps @Stock bei der Master im geschlossenen Gehäuse mit normaler Durchlüftung (nicht alle Lüfter auf Turbo eingestellt XD)? @Thunderburne
PL 133, +145 +1500 ergibt 570W und 78°C Core, 88° HotSpot, 84°C Mem, 56% Lüfter (mit angepasster Lüfterkurve auf ~75% (ab 70% störendes Rauschen bei meinem Model): 73°C Core, 83 HotSpot und 78°C Mem). De Default Lüftersteuerung scheint eher auf silent optimiert zu sein und nicht auf Temps.
Im Vergleich zu den 320W sind es ca. 10 FPS mehr in Metro Exodus (von 71 auf 81 FPS). In dem Fall wenn man die 10 FPS mehr braucht (was hier doch schon was ausmacht) kostet es ca 250W mehr. im Vergleich zu Stock 440W wären es von 76 FPS auf 81 FPS ca. 5 FPS und 130W mehr.
Du kannst Dein Powertarget so weit runterziehen damit du nicht 120fps überschreitest. Da spart man echt ne menge strom. Ich nutze aber lieber dlss2. Fühlt sich flüssiger an und hat weniger artefakte und zudem eine konstante Framerate.
/edit: Cookie ist weg
Pp 0% diggi. 2k. Glatt. Das ist gut 😄
Rein da
Zotac Cookie ist weg.
Hatte MMS gegen Ende der letzten Gen nicht diesen cartbar Mist abgeschafft? Nicht das der Cookie wahnsinn bald wieder anfängt.
Hab bei Mediamarkt und Saturn noch ne Strix im Warenkorb geparkt, schauen wa mal :d
Ja, wurde mal abgeschafft. Per POST Carten lässt sich die TUF OC aber nicht, kriegt man direkt nen Ban:
Ich meine mich zu erinnern dass es irgendwann geändert wurde dass die Artikel nicht nur "IN_WAREHOUSE" sein müssen sondern auch "is_in_assortment" auf true sein muss.
Ich denke da hat jemand in der MMS IT einfach vergessen die TUF OC freizuschalten (also "is_in_assortment" nicht auf true gesetzt). Gestern hatten ja diverse Shops nen TUF OC Restock, da kam wohl auch bei Saturn Ware rein.
Ähnliche Themen
