[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es sieht für mich so aus als wäre der hintere Teil dea Kühlers verbogen, Heatpipe und Backplate. Aber das PCB sieht auf dem Foto gut aus. Weswegen Du wahrscheinlich auch keine Probleme hast (bisher).
Das PCB ist deutlich kürzer, verbogen scheint nur der hintere Teil zu sein, Heatpipes und Backplate. Das PCB siehgt aber gerade aus und steht möglicherweise sogar nicht mal unter Spannung. Es kann also auch gut sein, daß diese Karte viele Kahre völlig anstandslos laufen wird.
Trotzdem stimme ich Dir aber insgesamt zu, das Risiko, daß sich Probleme erst später zeigen ist durchaus da und bei dem Preis kann das weh tun. Deswegen ist wie gesagt Minimum mit dem Händler umgehend darüber zu sprechen. Am besten wäre natürlich ein Austausch, aber ich kann echt verstehen daß man das aktuell irgendwie nicht möchte, es könnte dauern bis Ersatz da ist und das hat dann vielleicht deutlich ärgerlichere aber weniger sichtbare Mängel. Bei optischen Mängeln war ich in der Vergangenheit auch immer sehr zurückhaltend mit Reklamationen. Aber vielleicht kann man mit dem Händler ja auch vereinbaren, daß man den Austausch zu einem späteren Zeitpunkt vornimmt wenn sich die Liefersituation bessert. Ich kann so oder so nur die Daumen drücken.
Habe bei mindfactory angerufen und Fall geschildert. Er meinte Reklamation an Reklamation@mf. Da kommt direkt nur die Möglichkeit für RMA per Einsendung. Also nix mit warten bis was verfügbar wäre. :(
Alter. Ist das ein Brummer. Ihr dürft lachen.
Ich bekomme mein Gehäuse nicht zu.
REIN .. ist kein Problem. Aber durch den dämlichen Strom-Stecker (der ja auch mit Wakü an seiner Stelle bleibt) und dem nicht biegbarem Kabel.
Keine Chance.
Brauch ich wohl das (sauteure) Ding vom Bauer, um ein 90° Winkel zu bekommen.
Einmal lachen bitte 🙂
Bin irgendwie froh dann doch das Thermaltake genommen zu haben, da ist der vertikal Mount dabei gewesen.
Beste Grüße
Bei mir ist die Suprime X ins Corsair 680X eingezogen, es mussten wie erwartet zwei Frontlüfter dran glauben ;)
Du hast es echt getan... ne Intel CPU und ne NVidia GPU!? ... muss ich mir Sorgen machen? Alles ok bei Dir? ;-)
Keine Chance.
Wo hast Du die TUF nochmal her?
wirklich, 37000 graphics score? Meine hat da 30.500, online findet man für timespy aber noch nicht viel. Port Royale gibts einige Daten online, da kommt sie so auf 26k meine hat mit nem harten OC an 27 gekratzt. Deswegen glaube ich eig. nicht dass meine hier underperformed?
Keine Chance.
Das Kabel darfst du doch biegen. Nur soll man das nicht machen, wenn der Stecker in der GPU ist. Und es ist ja nicht der 4zu1 Adapter.
Und das 90° ding von der8auer ist warscheinlich auch zu dick. :D
Ihr redet von Timespy und Timespy Extreme ;)
Ja, der Score ist Timespy (normal). Wobei er auch definitiv im extreme keine 30K Graphicscore haben kann ;)
Bei mir sieht das unter Timespy Extreme stock (PT 108%) so aus:
Falls jemand nen 4x8PIN abzugeben hat, bitte melden.
Will nur mal was Testen.
Beste Grüße
Okay RDR2 war in Sachen Spulenfiepen bis jetzt wohl einfach worst case. Bei allen anderen Spielen (Dying Light 2, Cyberpunk, Division 2, FH5 etc.) ist das trotz gleicher FPS (100+ FPS) teils erheblich anders. Wenn ich das Case dann mit neuem Adapter auch komplett schließen kann und mit Ton spiele, sieht die Sache sowieso anders aus. Habe bei der TUF nun auf den Quiet-Modus umgeschaltet. Total geil, dass die Temps so niedrig bleiben und die Karte einfach total leise ist. Ein Unterschied wie Tag und Nacht bzgl. meiner vorherigen Karte (Palit 3080 gaming pro). Auch wenn das Case natürlich momentan ein Stück offen ist :d
Nochmal zu Cyberpunk: Ich glaube ich habe hier bei der Location "Tom's Diner" und um den Markt herum einen CPU-Bottleneck sobald viele NPCs da rumlaufen. Sehe direkt wie die GPU-Auslastung und FPS runtergehen. Die gleiche Location zu einer anderen Tageszeit ohne NPCs und GPU-Auslastung ist bei 99%. Ich nutze einen Ryzen 3900X. Könntet ihr mal testen was für eine GPU-Auslastung ihr da habt? Ich spiele in 4K mit allen Settings auf Anschlag und DLSS quality. Ich hatte mir gestern den Ryzen 7 5800X3D bei MF bestellt. Mal gucken, ob das dann einen Unterschied macht.
Keine Chance.
Jetzt stell dir vor, dass die Aorus Master noch 2,1cm höher ist. Da würde dein Case selbst mit abgezogenem Stecker kaum/garnicht zu gehen :haha:
Genau deshalb hab ich von abgewinkelten Steckern geschrieben... ;)
Da ist die Palit deutlich kompakter muss ich sagen.
Beste Grüße
Caseking.
Strixx bestellt. Mail mit "leider kein Bestand". Mit Mike gequatscht und gefragt was noch kommt. Bestellung auf TUF geändert.
Am nächsten Tag bei CK gewesen wegen neuen Tischen. Der Typ am Tresen meinte "wir haben Strixx OC", in meine Bestellung geschaut, stand noch auf Strixx OC.
Gefreut.
Doch TUF bekommen.
Mich störts nicht. 200 Euro weniger und der Wasserkühler ist der gleiche wie für die Strixx.
Meine suprim ist auch da, nachdem ups es gestern nicht geschafft hatte.
Bin leider aber etwas überfragt mit dem beiliegenden Adapter. MSI empfiehlt alle 4 Stecker separat anzuschließen. Nur habe ich bei meinem Corsair rm850 nt keine 4 sondern nur noch 3 separate Anschlüsse. Kann ich einen mit y anstecken?
Nee, die Schlechteste habe ich, aber selbst die ist noch für alles mehr als Ausreichend.
Beste Grüße
Die hätten das ruhig weiterlaufen lassen können. Dein Geld hatten sie ja schon
Und bei der nächsten Welle wird sie zugeschickt
Ich persönlich bin eigentlich froh das sie gleich storniert haben, mich hat nur genervt, daß sie einem keine Mail dazu schicken. Ich wollte entweder die FE oder eine ganz bestimmte Custom, sonst nix. Nur wenn NBB hätte garantieren können, daß diese Woche noch eine Lieferung FEs kommt, hätte ich die Bestellung aufrecht erhalten, sonst hätte ich direkt storniert und wäre auf die Jagd nach meiner Custom gegangen (wie gesagt, ich fahre hier aus Prinzip nicht mehrgleisig und bestelle in mehreren Shops gleichzeitig). Das automatsiche Storno hat es daher für mich leichter gemacht.
Meine Custom steht jetzt im Start-Paketzentrum und sollte vielleicht morgen, wahrscheinlich aber eher Montag bei mir sein. Ich habe ab übernächster Woche Urlaub und wollte, falls ich mich für einen Kauf entscheide (was bis zur letzten Stunde wirklich offen war), bis spätestens dahin eine haben, ansonsten hätte ich bis Jahreende gewartet. Wochenlang auf eine FE zu warten bevor ich aufgebe und auf die Custom gehe, wäre für mich daher eh keine Option gewesen. Aber ich sehe schon das es für viele andere möglicherweise eine gute Option gewesen wäre.
Ah. Mit Gewalt geht alles.
Aua, der Biegeradius wäre mir zu eng aber ich verstehe dich. Meines habe ich auch schon vorgebogen aber erst 4 cm hinter dem Stecker oder so, mein Gehäuse hat kein Problem in der Tiefe, nur in der Länge wegen dem AGB meiner WaKü, Ich habe das Kabel einfach ein wenig warm gemacht und dann vorsichtig an zwei stellen gebogen (einmal in Steckernähe und ein weiteres mal dort wo es dann unter den Lüftern Richtung Netzteil muss. Alles Trockenübnungen bisher, ich bin echt gespannt ob mein simulierter Einbauplan A den ersten Kontakt mit dem Feind überlebt :D
Kannst auch Y nehmen, die sind so Genügsam, da passt das schon. Meine hat z.B. nur 3x8PIN auf 12PIN und schafft ordentliche Punkte
Beste Grüße
Grüßt euch hat wer auch das Problem das seine Gainward RTX 4090 Phantom Lüfter Geräusche macht ? Bei mir ist es der erste Lüfter von Rechts der sich komisch anhört aber mehr nach Motorgeräusche also ob der Motor ein Defekt ist ?
Also meine TUF singt schon ordentlich vor sich hin, hab alle vier 8 Pin dran, glaube nicht, dass es mit drei in irgend einer Form besser wird 🤣
im X71 hätte ich sogar noch etwas platz..
tobi
