[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dachte ich mir auch gerade, wenn ich schon so unverschämt viel Kohle hinlege, will ich auch alles rauskitzeln.
Hat jemand ne Empfehlung für ein stabiles 4.0 Riser Kabel?
Auf Amazon
Teuer aber 👍
Sicher das es dann kein Feature ist? Also das sich erst ab einer bestimmten Auslastung alle Lüfter drehen? Vielleicht soll das so? Es ist schon seltsam das hier zwei das gleiche Problem haben.
Ja im Idle sind die Lüfter aus, dann auf 30% ... dort sind sie schon gut am hämmern... ich nehme es auf
sind 3 verschiedene quellen die folgendes sagen: alles ab 3.11 andere sagen 3.11 + late nov verkauf und die anderen sagen 3.11 vorstellung und dez release.
Ja, deswegen hatte ich auch eine Formulierung gewählt die Unsicherheit ausdrückt. Ich weiss es auch nicht sicher was jetzt gilt, gerade weil es so viele widersprüchliche Angaben bisher gab.
Dear xxxxx,​
Your request for a 12VHPWR Cable has been approved. Once your parcel is shipped, we will provide you a tracking number. Meanwhile, if you have any questions, please contact support@seasonic.com
Thank you,
Seasonic
Mal gespannt wie lange das dauert :)
Same here, hab gleich am 12ten angefordert :)
@tigerstyle haha das Bild mit den Duplo kenne ich sogar noch
Ich finde die Verfügbarkeit hört sich wirklich ähnlich an wie 2020 zum 3000er release.
Die ersten 14 Tage gab es auch immer diverse Karten die auch verfügbar waren, Problem da waren die Preise und wenn die 3080FE 699€ UVP hatte waren halt viele nicht gewillt 900+€ für eine Custom3080 zu zahlen.
Erst nach 2-4 Wochen war die Verfügbarkeit praktisch auf 0 und jeder Drop war in Sekunden zu praktisch jeden Preis ausverkauft.
Ich selber hatte z.B. sehr schnell eine Gigabyte 3070 2X Vision für 549€ (damit nur 50€ über den FE UVP) und die hatte ich hier zum EK zum verkauf angeboten (weil ich auch eine 3070 FE hatte) und sie wollt zu dem Preis keiner haben da hatte ich sie wiederufen, einen Monat später hätte man mir die Karte für 800€ aus der Handgerissen.
ne der fordere(blende) macht deutlich wahrnehmbare geräusche. noch schlimmer ist das die kurve auf 30% min gelockt ist sprich du kannst nicht drunter gehen darum will ich von palit nen bios drauf machen (sind die gleichen karten) und schauen ob da kein lock drin ist. aber da dass flash tool nix erkennt 😡
Mhm oder Retoure...
@Orgh
Steht auch auf der Packung drauf falls du es irgendwo abholst.
Das Spulenfiepen meiner Suprim ist ja brutal. Evtl fällts mir erst recht auf weil die Lüfter kaum drehen.
Der ausländische Support von Asus ist auch wieder zum Haare raufen. Was die für Vorschläge machen... Wie ich mein Glück kenne ist die Karte ein Montagsmodell und ich kann jetzt erstmal warten.
Mhm oder Retoure...
hab den versender schon angerufen leider kein lagerbestand mehr zum austausch. haben aber 300 weiter bestellt unbekanntes lieferdatum haben uns erstmal drauf geeinigt erstmal 10tage zu warten wenn sie ware bekomme melden sie sich zum tausch
Interessant. Danke. Hatte gedacht das nur die Patchnotes fehlen.
also meinste warten auf neue version :/ ?
So zum Abschluss noch mal schnell den standard TimeSpy
Erzähl mal bisschen was zur Gamerock, ist es die OC oder non Oc Version? Was macht sie so an Takt, was sind die Temps etc. Ist aktuell meine Favoritenkarte :)
Also ist die nonOC die OC habe ich meinem Kollegen gelassen. Also sie hat max. 450W, gelockt da nur ein 3x-8PIN Adapter dabei ist.
Takt max @ TimeSpy so 3Ghz, ohne alles, also Stock boostet sie auf 2700Mhz konstant. Spulenfiepen kann ich aus 50cm aus dem gehäuse nicht wahrnehmen. Temps und Lautstärke einfach Top für solch eine Karte.
Würde sie wieder kaufen.
Beste Grüße
So selbes Setting @ max RT ultra und DLSS auf Performance . Ca. Doppelt so viel FPS als mit der RTX 3090 . Die PCI E Bandbreite liegt bei 3.0 jetzt statt bei der 3090 7-12% jetzt bei 18% . UHD passt der 10900k noch sehr gut .
Spulenfiepen ist intensiver als bei Timespy in CP2077 , aber hört sich ähnlich an wie meine 3090 Ref. Karte . Meine 2080 TI war um vielfaches schlimmer .
meine auch ... bist du dir sicher, dass das nur ein Lüfter ist? Ich habe nun alle nacheinander angehalten. Es scheinen alle zu sein. Ich habe allerdings KAUM Coil Whine
wie gesagt ist NUR der fordere (an der blende der) die anderen beiden sind fine
Oha 😲
Habt ihr mal versucht den Lüfter von Hand vorsichtig zu justieren?
Bisschen ziehen/drücken
is schwer denke mit dem handy keine chance. bei 100% hörst es zwar deutlich ist aber viel wind also auch kaum chance mit nem 08/15 mikro
Beste Grüße
Vielen Dank :) wirst du dir das Bios von der Gamerock Oc draufflashen?
Kann jemand mal mit Octanebench benchen?
Mindfactory zuverlässig und schnell wie immer.
Karte ist schon krass. ;)
Komme aber erst am Montag zum basteln.
