[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@andi0138 Ich glaube schon das die Art des Anschluss bzw. der Sense-Pins einen Einfluss hat, ähnliche wie ein BIOS Switch mit unterschiedlichen Powerlimits. Das Beispiel mit dem 450 W silent Bios von MSI, da wirst du wohl nichts mit dem Afterburner überschreiben können. Zum Glück wissen wir wohl bald mehr.
Jep, meine 2 Corsair Kabel sollen auch heute kommen. Rechtzeitig zum Release :)
Bitte sag uns dann wie biegsam die sind und ob man da wirklich erst ab 3-4 cm biegen kann
Update
kfa/gainward/palit/zotac hinzugefügt.
Nochmal zur Verfügbarkeit, bei Caseking steht nur bei 2 Asus Karten ab 12.10 verfügbar, bei allen anderen nicht lagernd.
Also nicht gerade so vielversprechend, wenn die Angabe denn stimmt ....
Wenn man den vielen Techyoutubern glaubt werden über den Oktober die Händler noch mit Karten überflutet, also wenn du am Launchday keine bekommst, dann definitiv noch im Laufe des Oktobers
Genau, um dann kurz danach down zu gehen :d
E-Tec.at möchte jetzt 1500€ Anzahlung für Barzahlung bei Abholung :-)
Die wissen schon Bescheid, dass 2599€ für die Strix 4090 nur eine Backup-Bestellung ist…
um dann endlich vorbestellen zu können, um wenigstens Ostern 23 noch zu retten :fresse:
Ich will Niemand zu etwas verleiten, aber mit einer „zufälligen“ Magenverstimmung ist nicht zu spaßen :fresse:
Ich bin 48 arbeite seit ich 16 bin. Ich habe noch nie Krankgemacht wenn ich es nicht bin. Nicht mal als Schüler klappte das, da waren meine Eltern knallhart.
Ja ich bin heiß auf die neue Karte, aber die läuft mir nicht weg. Vielleicht gibt es wirklich genug das ich problemlos noch nach der Arbeit an welche rankomme. Und wenn nicht, Pech gehabt. Aber neue Lieferungen werden sicher nicht so lange auf sich warten lassen.
Selbst wenn man bei der ersten Serie keine bekommt bis zur Launch von AMD RDNA-3 Serie werden es genug RTX 4090 geben.
Die laufen auf keinen Fall weg. Ich glaube warten ist dieses mal taktisch klug. Ich werde noch den RNDA3 Release abwarten und dann schauen ob ich aufrueste. Wenn Nvidia dann nur 4090, die 4080 16GB macht keinen Sinn. Ich hoffe AMD wird eine bessere Aufteilung ihrer Karten haben, die 4080 ist mir zu weit von der 4090 entfernt und dafuer dann auch wesentlich zu teuer.
Warten kann man immer, wobei wäre echt blöd wenn man seine 4090 direkt November wegen RDNA3 wieder tauschen müsste :unsure:
Die RDNA3 soll auf dem Niveau der RTX 4080 16 GB liegen Gerüchten zu folge über der RTX 4080 12 GB und unter bis gleichauf mit der RTX 4080 16 GB.
Sprich an die RTX 4090 kommt sie nicht dran.:bigok:
Auch der Verbrauch ist ziemlich ähnlich
Die 4090 FE scheint ja kein Bios Switch zu haben, trotzdem gibt es wohl unterschiedliche Powerlimits 450/600. Ob man dies wohl mit den Sense Pins des neuen Steckers regelt?
Würde mich nicht wundern. nVidia hatte gesagt das die FE auf 600W übertaktet werden kann, wenn die Stromversorgung passt. Daher kann ich mir durchaus vorstellen, daß die FE die Sense-PIN ausliest um die Extra Leistung freizugeben. Meines Wissens hat das BIOS ein Hard-Limit wo Du nur durch flashen drüber rauskommst (600W) und ein Soft-Limit (450W), daß über Software verändert werden kann. Und das dieses Softwarelimit von den Sense-Pins abhängig ist kann ich mir gut vorstellen. Aber das ist auch nur meine Vermutung basierend auf dem was ich über die FE gehört habe.
Unsere Einkaufspreise für die MSI Karten sind deutlich gestiegen weil der Dollarpreis so kacke ist, man kann also davon ausgehen dass sich die aktuellen Händlerpreise nicht halten werden
Das klar die 6900XT war ja auch nicht schneller.
Das hatte man damals auch von der 6900XT erwartet und die kam an die 3090 ran und war je nach Spiel auch mal schneller. Denke das wird dieses mal wieder so sein. Die 4080 16GB ist zu weit von der 4090 entfernt, sprich hat wesentlich weniger Cuda Cores (4090 16384 Cuda Cores, 4080 16GB 9728 Cuda Cores, sprich die 4080 hat 40% weniger Cuda Cores)
Die 3080 10GB hatte nur 17% weniger Cuda Cores als die 3090 (3090 10496 Cuda Cores, 8704 Cuda Cores 3080, sprich die 3080 hat 17% weniger Cuda Cores)
RDNA3 wird 50% mehr performance pro Watt haben, heißt bei 300W TDP sollte sie 50% schneller sein als die 6900XT, wenn man jetzt bedenkt das auch AMD bestimmt auf 400W geht, dann sollte die neue 7900XT 75% schneller sein als die 6900XT und somit wieder in Reichweite der 4090.
In 3 Wochen wissen wir mehr, so lange sollte man noch aushalten können.
Ähnliche Themen
Antworten
7K
Aufrufe
587K
