[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das ganze RGB blink blink mit Plexi Cover und immer näher rückenden Komponenten auf dem PCB sind doch für die Wakühersteller ein Segen. Der Materialeinsatz ist im Vergleich zu früher zum großteil lächerlich geworden. Die Baseplate aus Metall ist teilweise winzig. Nur mal zum Vergleich:
Für so ein Plastikbomber 160€ aufzurufen mit Chinafertigung ist da fast schon dreist.
Anhang anzeigen 800171 Anhang anzeigen 800172
Naja andere nehmen dafür auch weit über 200 inzwischen.
Der Kramm muss Kühlen und brauch kein Schicki Miki Gold Baren sein dafür gehe ich den Schmuckladen.
Früher hat man einen Aquacomputer für knapp um die 100 bekommen.
Oder einen Watercool.
Plant hier denn jemand mit der ICHILL zum Launch?
Ich habe aktuell den drauf .
Finde bisschen Plexi und weiße Beleuchtung ganz nett.
Man kann halt auch reinschauen , wenn man die Karte ausbaut ob alles ok ist.
Tja. Ich bin ja auch ein Acetal-Fan. ALC wird wohl erstmal nix liefern (in absehbarer Zeit).
PS: Außer dieser Industrial-Line Geschichte aber da sind die Anschlüsse hinten ("komisch hinten")
Ja, wobei ich immer noch Bauchweh aufgrund des Herstellers habe. Klar, was soll schon passieren mit einem ab Werk montierten Wasserblock. Nur in doch mal auftretenden Garantie/ Gewährleistungsfragen, sehe ich Schwarz.
Die iChill Frostbyte interessiert mich. Die einzige Karte (m Moment) die schon einen Wakü Block montiert hat.
Ja, deswegen überlege ich. Eigentlich will ich FE + Watercool. Wäre insgesamt vermutlich auch etwas günstiger als direkt die ICHILL jetzt zum Launchpreis. Allerdings kommt der Watercool-Block auch erst in 5-6 Wochen (ok, vielleicht auch Ende November nächstes Jahr...) wohingegen man die ICHILL direkt vom Start weg in den Kreislauf einbauen kann und sich Selbstmontage spart.
Allerdings keine Ahnung, was Inno da für einen Block verwendet. ALC vermutlich? 2°C mehr oder weniger interessieren mich aber herzlich wenig. Bei >600mm² dürfte das generell gut genug zu kühlen sein. Solange die nicht beim PT knausern...
Das dürfe dieser Block sein. Klingt für mich erstmal ganz vernünftig. https://www.alphacool.com/detail/index/sArticle/30435/sCategory/20539
Die Platine ist ja Referenz Design von Nvidia. In der Vergangenheit war das nicht besser oder schlechter als die Founders Edition. Powerlimit, Spulenfiepen usw. muss man dann vor Ort sehen.
An FE und Watercool dachte ich auch zuerst. Aber da weiß man ja noch nicht wann die Kühler fertig sind und bestellbar sind. Das ist das was mich am meisten an Aquacomputer und Watercool stört, die kommen immer zu spät mit ihren Produkten auf den Markt. Und ich habe auch nicht mehr die riesen Lust auf selber umzubauen, wenn es was fertiges gibt greif ich lieber dazu.
Und da ich eh nicht übertakten werde sind auch mir 2-3 Grad mehr egal. Hauptsache dank Mora 420 wirklich leise.
nvidia verweigert explizit die Garantie bei Kühlerdemontage. Ich hatte nach knapp 2 Jahren nun 3 defekte 3090FE die auf Wasser umgebaut waren und in einem Server liefen. Bei 2 wurde die Garantie verweigert, 1 ist durchgegangen. Eine gute Quote sieht anders aus.
In welchen zeitlichen Abständen hattest Du die Karten eingesendet und welche wars, die getauscht worden ist?
Bei der 3090 war ich Vorbesteller und mein Block kam ein Tag vor Heilig Abend (ja noch im Jahr 2020) :d
In der kalten jahreszeit könnte ich ne weile verkraften .
Folgende probleme gab es schon.
Von Haus aus Pads vergesssen oder zu dünn.
Demontieren und wechseln nicht erlaubt.
Risse im Plexi . Kunde selber schuld.
Wird eine Karte eingeschickt erhält der Händler Credits um eine neue Karte sich auszusuchen .
Der Kunde bekommt dann meist nur einen Wertanteil und nicht den vollen Kaufpreis oder bekommt auch keine Austauschkarte.
Hier kommt auch bisschen der Händler mit ins Spiel , aber gute Händler gibt es ja kaum.
Also muss man Stress machen , sonst wird man verarscht .
Daher schon schwierig mit Inno3d.
Bei Asus zb. schicken die eine Austauschkarte oder erstatten den Händler den vollen Kaufpreis zurück und diese leietet
den an den Kunden weiter. So zumindest auch eigene Erfahrung mit Asus und Monitor.
Wie oft hat man schon eine Defekte Grafikkarte? Ich bin inzwischen über 30 Jahre PCler und hatte erst einmal eine defekte Grafikkarte. War eine Asus und ja da ging die Garantie Problemlos.
Wohl nicht sehr häufig. Wenn es dann aber doch mal soweit kommt, ist das Geschrei groß.
Lasst alle die Frostbite im Regal liegen, bekomm ich eher eine:d
Service für Komponenten und Displays ist was komplett verrchiedenes bei Asus, nach 30 Tagen ist Schicht mir Erstattung oder Austausch gegen neues Gerät.
Ich habe mal den Fehler gemacht mir mit Auspacken und Test von einem Asus Display etwas Zeit zu lassen.
Der erste Austusch war ein zerkratztes Refurb Gerät, erst nach Terror gabs dann einen neuwertigen Austausch.
Wegen mir kannst du alle haben, :LOL:
Wegen der icill kommt es bei mir auf das PT an, wenn die auch 600 Watt hat ist Sie auf jeden Fall in der engeren Auswahl, sonst die Suprim oder Strix Und später Wasserkühler.
möglichst billige herstellung mit einem maximum an plastik triffts eher
der qulitätsanspruch heutzutage ist bei vielen aber quasi nicht vorhanden
darf halt nix kosten ne
Mal dran gedacht, dass Qualität jeder auch bissl anders definiert? Für mich muss der kühler funktionieren und mir ist Wurst ob der aus Plastik oder polierten Einhornhoden besteht. Ich hab das Teil nicht um irgendwem meinen PC zu zeigen und zu sagen "Guck was ich für ein Hecht ich bin" sondern damit die Karre kühl bleibt. Scheint bei dir, auch was ich so aus dem Auto-Topic in Erinnerung habe, halt ein wenig anders zu sein. Und ob du es glaubst oder nicht, ich nutze ein paar Teile von Alphacool und habe 0 Probleme. Bei allen Herstellern kannst du was haben, so what. Aber jahrelanges haten, obwohl man vielleicht im Zweifel nie ein entsprechendes Produkt hatte, geht halt besser, ne? ;)
Btw ich bin gespannt auf die 4090 und ob ich widerstehe 😅
Ähnliche Themen
Antworten
7K
Aufrufe
585K
