[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hey Leute
Habt ihr euch mal die ganzen custom Designs angeschaut? Die sind alle vom Pcb recht klein…. Wäre es denkbar dass Nvidia nurnoch das Reference Pcb zulässt? Ich habe mal bevor ich darauf gekommen bin die Info von Alphacool bekommen dass sehr viel mehr Karten im Ref. Design wären als noch bei rtx 3000. Dass praktisch die Hersteller nurnoch über Kühler und bios entscheiden können. Es ist halt schon sehr seltsam dass selbst die Strix so ein mini pcb hat
Würde eigentlich auch sinn machen da eh alle Karten nurnoch den einen 12vhpwr Stecker besitzen…
Customspreise sind bisher in Ordnung. Hoffen wir mal, dass es auch so in Europa ist.
Jo, Um die zwei Mille dann bei uns. :oops:
Die kannte ich bisher noch gar nicht, Suprim Liquid X mit 240er Radi.
Viel Spass mit den Adaptern.
Wer 2k für ne Graka übrig hat, der wird doch nicht an einem Netzteil scheitern.
Da ist ja sicher die 16Pin-Seite des Adapters betroffen und nicht die andere Seite, in die man die Netzteilstecker steckt.
Von daher hälft das beim Netzteil beiliegende Kabel mit 16Pin-Stecker im dümmsten Fall auch nicht mehr an An/Absteck-Zyklen aus als der Adapter, der bei der Graka beiliegt.
Bei der 3000er Reihe war das Reference Design noch an die Höhe des regulären PCIe Slots angepasst. Da war es naheliegend für die Hersteller für ihre größeren Karten eigene PCB Designs zu entwerfen.
Bei der 4000er Reihe hingegen ist das Referenzdesign schon als Platine angelegt die die Höhe der PCIe Slotblende überragt und damit passend zu den schon bei der 3090 Ti verbauten Kühlern. Da werden einfach weniger Hersteller nen Grund gesehen haben ne eigene Platine zu entwickeln wenn sie sich schon mit dem Referenzdesign gut arrangieren können.
Ganz ehrlich wer baut seine Haufen 30* auseinander und wieder zusammen :ROFLMAO:
Das Design vom PCB war ja eigentlich schon mit der 3090 Ti bekannt und bewährt. Ich meine Igor hatte da Mal ein ganz positives Fazit. Bei dem steigenden Kosten für die Kühlung inkl vaporchamber usw. fände ich es logisch, auf das bewährte PCB zu setzen. Mit denn 660Watt sollte auch für Strix und Suprim genug Power vorher sein.
Das wäre ja auch grundsätzlich nicht schlecht…. Dann hätten wir es mit den Wasserblöcken einfacher
Das stimmt, aber wenn Inno3D oder Gigabyte am 12.10. eine fertige Wakü-Karte anbieten können ersparen ich mir dieses Mal den Umbau.
Da habe ich auch schon dran gedacht. Inno3d nutzt ja ordentliche Blöcke ( von Alphacool ). Trotzdem hab ich mal um sicher zu gehn einen Block vorbestellt…. Bekommt man notfalls bestimmt wieder gut verkauft 😅
Bin auch mal sehr gespannt, ob inno3d es schafft ihre ichill Karten am 12.10 in die Läden zu bringen.
Keine Ahnung, ob ich wirklich drauf Lust habe, bei inno3d um Erlaubnis zu fragen, ob ich den Kühler demontieren darf, weil zwischen VRAM-Pads und Kühler kein Kontakt besteht. :unsure:
Ich empfehle wieder diese hier zu kaufen:
Und diese dann auf die Backplate kleben legen mit einem kleinen 80mm be quiet Lüfter. Die Verbesserungen an der Gradzahl sind ein Traum für den Preis. Man kann jederzeit die Backplate im vollem Betrieb anfassen, ohne, dass es brennt :)
Ich denke nicht dass man die Backplate kühlen muss, oder liege ich da falsch?
Auf der Rückseite gibts doch keine Speicherchips wo man kühlen muss.
Die sind auch raus für mich.
Mir gefällt auch nicht , dass das Terminal aus Plexi ist.
Werde mir aber auch erstmal die Test´s zu den Karten anschauen und gucken ob FE oder eines der anderen Karten.
Finde den Vector Kühler von EKWB für die FE garnicht mal sooo schlecht.
Muss man natürlich mal im detail betrachten , aber so auf den ersten blick ganz ok scheinbar.
WC und AC werden wohl wieder Monate brauchen , weil die bekommen ja leider keine PCB´s im vorfeld.
Von Bykski kommt auch wieder zeitnah was. Hätte eigentlich auch gedacht es werden mehr Karten zu Anfang mit Block vorgestellt.
Alphacool tempert Acryl mittlerweile nahezu perfekt, da gibt es keine Nachteile mehr.
Bykski Blöcke vorbestellbar
Was hast du denn für ein Board? Kein Z690?
Gerade mal die coverage auf YouTube gecheckt. Gerade mal 6 Videos in den letzten 24 Stunden weltweit über die RTX 4090. Keine Sau interessiert sich für die Karte. Außer die 10 hier im Forum :P
Haben wir in DE noch zuviel Geld? :d
Ich warte da noch zwei Jahre mit dem NT´s.
Mir kommt erstmal die 4090 an die Adapter .
Corsair wollte da noch was machen und mal schauen ob da noch was kommt für die alten Nt´s.
Für den Microfit kam ja auch erstmal ein seperates Kabel produziert und angeboten.
Fände es aktuell zu schaden das gute AX1000 Titan einfach raus zu schmeißen.
[/URL]
Hab das AX1600i nicht mal 2 Jahre und ich kaufe nicht schon wieder ein NT nach nur 2 Jahren (nach dem Reinfall mit dem sauteuren Seasonic)
Da nehme ich Custom-Cables oder crimpe zur Not selbst :d
Ausserdem erspare ich mir den Aus-/Einbau und Verkabelung
Aber noch ist es nicht soweit. Vielleicht schaffe ich es diesmal die Serie zu überspringen :fresse:
Das glaubt ihr doch selber nicht :fresse:
Kostet halt ~2.000 Euro. (Jedenfalls UVP. Es klang allerdings so, als würden die Stückzahlen zunächst eher niedrig sein, so jedenfalls Jensen zu u.a. anwesenden Redakteuren und Redakteurinnen von Marketwatch, Reuters und dem Manager Magazin – der eher kleine Zahlen für 2022, größere für 2023 anklingen lassen hat), plus wahrscheinlich neues Netzteil
Na dann, gleich mal auf ca 2800-3000EUR Straßenpreis in 2022 für die 4090 einstellen. Scalper werden wieder in da hood sein. (y)
Angeblich wird doch schon seit Mitte August eingelagert…. Ich denke wer direkt zum Marktstart zuschlägt wird auch eine für ca 2000€ bekommen. Der Preis schreckt glaub eh schon viele ab 😅
Ohne jetzt hier Panik machen zu wollen, denke ich die größte Gefahr wird das scalping sein, leider/:
scalping geht eigentlich so dass man scheinbar günstiges wegkauft und dann teurer verkauft
jetzt sind die mistkarten schon viel zu teuer. was will der scalper da rausholen. ...
Ähnliche Themen
Antworten
7K
Aufrufe
590K
