[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
finde die windforce ganz schick. schlicht und ohne schnörkeleien
guckt euch diesen brummer an :lol:
die slotblende verschwindet fast.
Das wäre so knapp 2.3K in Euro, also wie erwartet :unsure:
Ach, da hat er es her:
Following is the full list of cards that are listed with preliminary prices:
Gigabyte GeForce RTX 4090 AORUS Master - £1999 ($2258 US)
ZOTAC GeForce RTX 4090 Trinity AMP Extreme AIRO - £1898 ($2144 US)
Gigabyte GeForce RTX 4090 Gaming OC - £1859 ($2100 US)
Palit GeForce RTX 4090 GameRock OC - £1859 ($2100 US)
Palit GeForce RTX 4090 GameRock - £1829 ($2066 US)
PNY GeForce RTX 4090 VERTO EPIC-X RGB 24 GB - £1829 ($2066 US)
ZOTAC GeForce RTX 4090 Trinity OC - £1829 ($2066 US)
Gigabyte GeForce RTX 4090 Windforce - £1799 ($2032 US)
Inno3D GeForce RTX 4090 iChill X3 - £1799 ($2032 US)
ZOTAC GeForce RTX 4090 Trinity - £1759 ($1987 US)
Inno3D GeForce RTX 4090 X3 - £1679 ($1897 US)
PNY GeForce RTX 4080 VERTO EPIC-X RGB 16 GB - £1269 ($1433 US)
PNY GeForce RTX 4080 VERTO EPIC-X RGB 12 GB - £949 ($1072 US)
:LOL:
Preise sind natürlich inklusive Steuer, VAT ist in UK 20%.
Ca. 36-43 FPS
Edit @Dwayne_Johnson
Kleiner Vorgeschmack :)
2-3x so schnell als eine 3090 TI in Cyberpunk.
Wenn die Angaben nicht schöngerechnet sind - wow :oops:(y)
GIbt ein paar Haken. DLSS 3.0 erhöht den Inputlag.
Am besten hier mal lesen bei CB
TGP der FE lässt sich wohl auf 600 Watt erhöhen.
Mit dem beiliegenden 3x 8PIN eigentlich zu hoch...Eventuell kann man sich einen 4x 8Pin nachbestellen
Die Dicke wird für Manche kein Problem sein - aber vielleicht die Höhe :fresse:
Wird ein Wagen... äh GPU-Heber mitgeliefert? :haha:
Also, wenn die (NV u.a. Hersteller) immer noch die Buchsen wie eh und ja platzieren, muss man sich fragen, ob sie noch alle haben :rolleyes2:
Das beigelegte Kabel scheint ja bissle brüchig zu sein:
„4x 8-pin-to-12VHPWR cable (Limited service life with up to 30 connect / disconnects)“
haha. Hast du das auch bemerkt? Ich hatte das sogar Videocardz heute geschickt gehabt und die haben eine News draus gemacht :)
"Many thanks to SH1988 for the tip!"
Falls noch nicht bekannt !
Das PCB der GeForce RTX 4090 Founders Edition ist wieder äußerst klein gehalten, um dem Kühlkörper einen maximalen Platz zu geben. Die Stromversorgung wird über den neuen 16-Pin-PCIe-5.0-Anschluss (12VHPWR) sichergestellt, der Founders Edition wird aber auch ein 3×8-Pin-Adapter beiliegen. Wer Nvidias Flaggschiff übertakten möchte, kann das Powerlimit auf bis zu 600 Watt erhöhen
Quelle CB
Mit DLSS 3.0 nur bedingt Aussage kräftig der Takt !
Bei entsprechender Load denke ich wird es am Powerlimit hapern!
  • Danke
Reaktionen: SH
"Wer Nvidias Flaggschiff übertakten möchte, kann das Powerlimit auf bis zu 600 Watt erhöhen"
Schade damit ist die FE bei mir raus. /:
Wie sollen 600 Watt über 3 Stromanschlüsse gehen? Soweit ich weiß, geht 175 Watt per Anschluss und 75 Watt über PCIe - das wären dann 500 Watt. Oder liege ich falsch?
Zu wenig? 😄
find die FE eigentlich am interessantesten aber weis nicht ob ich mir die Kühlerdemontage zutraue
516W ist die Spez. für 3x8Pin+PCIe
Maximal werden es wohl 675 W sein bei der Serie oder Mod Bios oder Hardmod!
Mit 2 *PCie 5.0 16Pin hat man bisher ja noch keine Karte gesehen!
Ich denke mal bei Vollast Szenario reichen 600W vielleicht für 2500- 2600mhz
Spiele die nicht so viel ziehen dann wohl etwas mehr !
Hat die Strixx nicht ein zweites Bios mit 660 Watt?
+33% PL ist schon mal gut. Bei der 3090FE waren es glaube nicht mal 10%, oder?
Die 8pin Stecker sind nur für 150 Watt zertifiziert. 4x150 = 600 + ~75Watt vom Slot. Daher gibt es bei MSI und anderen ja auch den schon gezeigten 4-in-1 Adapter.
+14% waren es, 350Watt auf 399Watt, bei der 3090Ti FE+0%, 450Watt
PCIe 12Volt sind max. 66Watt
Aber ist ja eigentlich egal ob 3x oder 4x 8Pin der 16Pin Stecker ist ja nur für 600Watt spezifiziert
Zu wenig? 😄
War bei der 3080Ti easy !
Vorher vielleicht ein Tear Down anschauen dann sollte das von der Hand gehen!
Jup bei der FE liegt nur ein 3*8Pin bei !
Bei der MSI Suprim hat ich ja den 4*8 verlinkt!
60W mehr ist halt schwach da kriegst vielleicht 60. -90 MHz unter Vollast dazu !
Normal müsste die Strixx da bis 800W gehen finde ich erstmal nicht so Prall!
Jedoch wer möchte die Ganze Zeit die Karte bei 660W laufen lassen das ist Maximal was zum Benchen wie ich finde !
Im Alltag werden die meisten ehr ein undervolting Profil anlegen und versuchen unter 400W zu bleiben!
Eine Karte mit richtig ernst gemeinten OC Genen hab ich noch nicht gesehen!
Eventuell gibt es ja ein 1000W Bios oder so😀
@Thunderburne Danke, ich glaube auch das sollte erstmal gut passen und gibt einigen Spielraum. Einen 2x 16pin Stecker hatte ich auch schon mal gesehen, auf einer Galax 3090 Ti HOF
Jup hab da auch noch die Hof in Erinnerung gehabt Danke!
Die Karten welche jetzt gezeigt wurden scheinen auch alle das gleiche, kurze Reference PCB zu haben. Was mich im Falle der Asus Strix eigentlich wundert, aber vielleicht ist ja gut genug uns spart Kosten.
Hier in dem Artikel steht das mit 600W für die FE!
Neuer Stromstecker und deutlich schnellere Reaktionszeiten​
Das PCB der GeForce RTX 4090 Founders Edition ist wieder äußerst klein gehalten, um dem Kühlkörper einen maximalen Platz zu geben. Die Stromversorgung wird über den neuen 16-Pin-PCIe-5.0-Anschluss (12VHPWR) sichergestellt, der Founders Edition wird aber auch ein 3×8-Pin-Adapter beiliegen. Wer Nvidias Flaggschiff übertakten möchte, kann das Powerlimit auf bis zu 600 Watt erhöhen – zumindest nach Spezifikation würde dies aber nur noch über den 16-Pin-Anschluss funktionieren.
Also 600W wird schon gut sein denke mal da wird es Custom geben die schon bei 516W abriegeln werden bei den günstigen Varianten!
Ich fand die 3080Ti FE damals mit den 400W auch okay .
Nix für Rekorde ab Maße ausreichend fürs Gaming!
Ich denke mal das wird jetzt bei der neuen Serie nicht anders sein je mehr Watt desto weniger oben rum drauf!
Da wird es auch nen Sweet Spot geben!
Gute Frage ich glaub zu Rog Strix hab ich was mit 24+3 Spawas gesehen und die FE hat glaub ich was mit 20+3 weis nur nicht mehr wo ich das gesehen habe.
Apropos Leistung: Diese Gaming-Karte ist ein absolutes Monster, deshalb hat ASUS ein 12+4-Phasen-System mit 70 A starken Power Stages eingebaut. Mit zwei Power Stages pro Phase, die die GPU mit Energie versorgen, ergibt sich eine Gesamtzahl von 24+4. Der digitale Controller an Bord bietet eine höhere Präzision bei der Leistungserkennung sowie eine bessere Stromumwandlung und -verteilung für weniger Rauschen und Signalstörungen.
Hab grad wenige Zeit nach 4090-Infos zu schauen...
Wann sollen die ersten 4090 zu kaufen sein?
Das PCB der Gigabyte ist ja wohl schon mal deutlich höher.
Die Gewinnspanne ist für die AIBs vielleicht so gering, dass sich einige R&D für ein Custom PCB sparen und ein Referenz oder nur geringfügig modifziertes Referenz PCB her nehmen.
Inno3D ist bei den eigenen Karten schon häufig so vorgegangen und die Schwester Zotac bei den günstigen Karten ebenfalls.
Das fände ich schon ein Argument. Meine 3080 Suprim läuft hier mit 0,95v und auch unter Last immer über 2Ghz. Braucht dafür aber auch zwischendurch mal 370W und mehr um den Boost aufrecht zu halten. Das wäre mit einer 3080 FE so nicht gegangen. Deshalb wäre mir das schon wichtig beim Nachfolger genug Spielraum zu haben.
Hmm, ich peile denke mal wieder ne Strix an. FE hat wieder dieses abgesägte PCB 🤢
Was ich euch sagen kann, dass die 2850 noch lange nicht ausgereizt sind. Wie schon vor Wochen erwähnt, rechnet mal mit 3050-3100 mhz bei gutem OC. :)
Es gab ja schon den leak mit leichtem OC und 3015mhz
WAS EIN KLOTZ! :)
VidoeCardz.comLengthWidthHeightVolume
Gigabyte RTX 4090 GPU Size
RTX 4090 AORUS MASTER358.5 mm162.8 mm75.1 mm4,383 mm³
RTX 4090 GAMING340.0 mm150.2 mm75.2 mm3,825 mm³
RTX 4090 WINDFORCE331.0 mm150.0 mm70.0 mm3,476 mm³
RTX 2070 Mini-ITX170.0 mm121.5 mm42.1 mm871 mm³
RX 6400 Low-Profile182.0 mm69.0 mm36.0 mm452 mm³
Lol, keine der gigabytkarten passt horizontal ins lian li o11 evo
Ähnliche Themen
Antworten
7K
Aufrufe
589K
