Ah yeah I do have a watercooled system so I guess that will handle the additional heat. I'm not sure though I understand this correctly, "with only 233W there is no way to use higher V", why is that? Am I missing something? Wattage depends on the ampere and voltage input?
Regarding the temps, below 60C on the junction, when the card was aircooled it sometimes reached waaaay above that limit... why do I need to keep it below 60C?
Thanks for the explanation on how to save the settings, I'll try that :d
EDIT: Just enabled the TDV but my GUI still looks like this, any ideas?
EDIT2: Thanks, I'll download that version
i think Youcan give to the card 1150mv (like stock6800xt) and more power if you have watercooled card i think about 300W (+15% give to Your card ~ 350W) than check oc , how max clock You can set in watman ? if You rise only volts , power limit will by limiting Your oc
@Sylwester.
Willst du noch testen, ob und was für einen Unterschied TVmin / Hystersis auf die max GFX Voltage hat?
6800nonXT
the 2593...2600MHz-Setting is doable with 1050mV in the TDV-Section (probably effectivly 2570MHz)
there is no need for 1150mV
but but but
Watts first, check if the Watts go higher with that 300W per MPT and PL+15@Wattman
if not
you have loosed the possibility to reach that high V
6800nonXT
the 2600MHz is doable with 1050mV
but but but
if not
you have loosed the the possibilty to reach that high V
probably yes i dont have this card
@Sylwester.
i will , but i fight today to find the way to broke clock limit for 6800xt , and probbly i must reinstal windows , because now is getting crayzy , i wrote this post from second system on my pc :ROFLMAO:
1 year ago the first driver was with 1050mV-MPT-Limit and so the MHz/V are known
(for good cards@h2o, ... look at the threadstarter or andybuc last year-setting)
gurdi says 1,05V was enough with his golden sample ref
eaglone@2600MHz-Setting with the old driver (watercooled without LM)
@GerryB
Meine Karte lief mit den Treibern von Anfang des Jahres auch mit 1025mV auf 2600mhz . Hat sich erst ,so glaube , ich mit den Treibern im Frühjahr verändert . Ab da war es dann nicht mehr möglich über +,- 2550mhz zu gehen . Werde heute noch mal 6800 LE anschmeißen ,mal sehn was mit dem Voltmod noch möglich ist . Meine alten MPT Einstellung habe ich durch einen Windowscrash aber alle verloren , deshalb war es gut ,daß Du nochmal was gepostest hast .
aus praktischen Gründen würde ich DPM2+3 gleichsetzen, damit net schnelle Wechsel instabil werden
(die kurze Zeit wo evtl. mal nur DPM2 anliegt spart net wirklich viel W und Temp in Games und beim TS)
edit: die komischsten Stellen sind oft das Ausblenden aus dem Test XYZ oder der Demo oder Szenenwechsel
... kann leicht sein, das dort mal kurz ein Rückfall auf DPM2 passiert
@ShirKhan
Ja das ist DPM3
DPM2 war auf 1.425
@GerryB
Auch ein Ansatz werde das testen(y)
Anständigen Score in TS kriegst du nur mit stabilem VR ,der hohe Takt nützt nichts wenn der VR nicht skaliert.
VR ist gerade das Kürzel wofür? Einfach Video-RAM, also Grafikkartenspeicher? Oder was Spezielleres?
Genau Grafikkartenspeicher.
1,462V bei MVDD DPM 3? Oder auch bei den niedrigeren DPM-Stufen?
Hier geht es um VDDCI ebenfalls für DPM 3?
Mit welchem VRAM-Takt kommt ihr dann mit FT2 durch TS?
2150 FT1 ging instant, auch bei 800mV VDDCI
1900-1947 ist die strap für FT2 ~ braucht zumindest 900mV, 950 sah so aus als ob es probleme machte
Es scheint performance technisch beides aufs selbe rauszukommen in TS, aber in games ist FT2 ein hauch besser
Leider ist TS etwas "zu schwach" laut meiner Erfahrung, was stability testing angeht
Core clock technisch passt es (naja wobei FS & FSE nie auf dem tackt rennen)
Aber memory technisch ist Unigine Heaven zb einfacher "fehler" darzustellen sowie spiele wie APEX & Warzone
1950-1997 geht noch , aber verschmiert texturen
Streched/artifacts
EDIT: Zb sowas
Generell brauchte es 1.21Xv SOC damit es lief
Soweit bevorzuge ich 1900 (1898Mhz) FT2 über 2150 FT1
Aber es "failt" schneller nahe 55-57c Memory Junction
EDIT:
Momentan peak ich halt die 500W kostant mit der leicht angepassten curve
Und renn somit 1150Mhz SOC only
Es kann leider nicht sein ganzes potential entfalten, allerdings half die curve bei der frequency "consistency". Weniger bei dem stromverbrauch :d
So ab 2620-2630 scheint die Probleme zu machen (65c hitze, air cooler)
2711Mhz strap liegt an, mit 2461min
Min kann ich erhöhen, aber sie wird schon warm genug, da braucht es nicht noch mehr frequenz
Ansonnsten theoretisch kann man das Daily'n , wenn SOC min-max hat. FCLK wird viel strom fressen aber das sind auch "nur" 40-45W mehr im "idle"
Das geht noch.
Zu boost schaltet die Karte auch nur ab etwa 70%+ last
Versuche einen Bykski oder Alphacool Wasserblock kaufen zu lassen ~ aber noch weiß ich nicht ob er mit den 230€ extra kosten mitspielt
(Alphacool Pro AIO schon da, quick connects ready aber es gibt nur befühlte blöcke für Ref-Editions)
Block+Schläuche+Rad+Fluid = 276€ :rolleyes2:
Wurde nun endlich EK's Nickel Plating improved ?
Der Quantom Vector für die Devil sieht ansich gut aus
Aber irgendwie nicht besonders der fan von Corsair/EK's ehmaligem Standpunkt zu "fluid compatibility/warranty" und Nickel Plating (dünnheit) welches beginnt sich zu lösen :unsure:
Leider gibt es nichts von TechN oder OptimusWatercooling
Well Gentlemen, I'm sweating today, hand, foot, brain on the wall :eek:, at some point after get last record, the computer began to go crazy, at first I thought it was Windows, but on the backup system on second ssd same thing 😵‍💫, ALL my settings caused the driver restarts , whatever i set, I think to myself "I beat the card ", chip degradation as in the bank :cry:. I shuffled the drivers, settings in the motherboard bios, nothing, my pants are full to the brim, I crashed the card like nothing, in the meantime I tried another mpt file, nothing. I'm totally bummed, I threw away 1200 euros :wall::wut:, finally I threw away all the mpt logs, based on the pictures posted here I recreated the files based on a new base file ripped once again from the card through gpu-z and it start work again :banana:
F. ..k but I was sweaty, adrenaline like I was jumping off a bridge with a rubber from my pants
I'm writing this to point out that if something starts to go wrong with the oc, it may be worth rewriting the settings to a fresh file.
ps.
I don't wish you the nerves I had today, when it didn't work I prayed "if the card doesn't turn out to be broken I won't overclock anything anymore, nothing ever again" but when it worked back, of course "under stress people talk such nonsense":fresse:
sounds like the L!ME-effect
Good Luck with the new MPT-File!
Mensch...mach kein Schei...
Jetzt wo ich wenigstens von weiten deine Rücklichter sehe kommst Du mit sowas :heul:.
Mal sehn was der Winter bringt. Luft ist halt nichts für Benchrekorde.
WTF !!!
Yesterday's problems were not an MPT file error, it was a virus, it became active yesterday after 10 pm then I had problems, now I have removed it and the old mpt is working
Yes CCleaner ist a Virus.
Jetzt wo ich wenigstens ...
Wow, 19,5k@air ist ja mal wirklich seeehr gut, hätte ich net für möglich gehalten! >=3080Ti@stock
(aber noch net in der Luxx-Liste oder bei PCGH eingetragen)
und Das ganz ohne Klimagerät-Modd ala J+H
Ist schon angeschmissen . Der Voltmod funktioniert , komme bis jetzt noch nicht auf meine alten Punkte . Muß alles wieder komplett ausloten . Habe meine Doku für die LE beim letzten Windowscrash verloren .
Look at the Benchmark-Threads, there you will find a information how much Watt are needed with only 1025mV.
and
If you want to go above that you need some mooore Watt.
W=VxA. without enough W there can not be more V
edit: the picture is the very best 6800 and this is a special Edition of Powercolour with better VRM`s,
like the bigger modells, ... so Andybuc can easily use mooore W then you.
(this is a older Benchmark-Run without the new TDV-Tweak of Sylwester)
I see, thanks for that reference! I'll try to finetune my OC now.
I did try to push this and 1150mv is possible, my temps at 1100mv never goes beyond 72C when running Time Spy.
So thank you guys for all the help here, I played around with the settings and boy is it possible to go beyond the stock performance :d
Started out with my previous OC limits
Went for a random raise of the voltage just to try things out
Tried 1050-1100mv
Finally pushing to 1100 min/max and that maxed out the adrenalin settings, so really noo point trying to raise the voltage further without altering with the overdrive limits (which I still don't know how and if it works?)
Hab vorhin auch mal FT2 probiert auf meiner 6900xt
1960 ft2 geht @1.4v, leider ist das bei mir aber etwas langsamer als 2150ft1 in TimeSpy
Echt zum kotzen die Taktsperre. 2250 läuft easy, aber leider streikt dann ja der Rest der Karte :(
Mvdd (DPM1-3) auf 1400 und unter Frequency bei DPM 3 950 (statt 1000)
Screen kann ich grade nicht liefern, bin auf Arbeit :rolleyes2:
Dann läuft der Vram auf 1.4v und im
wattmann hat man einen Frequenzbereich von 1900-2150
Thanks für your findings and the good documentation!
(you have a card with very good VRM`s, that can do 330W asic at 350W Limit = nice)
Its a little Surprise to me :
1050-1100 = 1037mV effectiv (may be very nice at 24/7)
1100-1100 = 1057mV effectiv ( so I will try 1056mV in TDV for my card)
I seems to go not more so straight with the eff.Volt at the highEnd.
.... so really noo point trying to raise the voltage further without altering with the overdrive limits
You can have a look at the setting of Andybuc. This was with the 6900 bios load in the mpt.
= higher fclk
But in the frequency tab and at Voltage you must change the values to the origin 6800 values.
(I think the new 6900 values in the curve tab are working without need to change to the origin 6800)
You can find some 6900 bios here:
edit: surprisingly in the todays run Andybuc did´nt change the values Mhz+Volt
He let the values @6900 or 6800bios!?
Die größte Sammlung an BIOS Daten findeste bei Techpower
Die o.g. Bios`sind die "Reviewer"-Exemplare mit der GFX-Curve. (ala Shirkan)
(bei TPU sind 90% aller Bios`ohne Curve, nur dumb mit Wert 0 0 0)
btw.
Der gute Score von DaHell war mit W11, ... scheint besser zu laufen als vermutet. (@INTEL)
Well guys one brave😈 6900xt guy needed, I uploaded the mpt file from the 6900xt bios, I adopted the 6800xt settings but there is something else not included in the mpt file that we can't see which in the 6900 bios won't let my card exceed 2100 flck and this card does it with a finger in the hole (hdmi or dpwhatever You like 🤭), so there is a chance that uploading the 6800xt file to the 6900xt will unlock higher flck
Just don't all throw Yourselves at each other. One desperate man is enough.
btw.
hö? ich hab'ne ref von der amd site vom 25.02.2021 und meine curves sind ebenfalls beide ausgefüllt, nicht mit nullern sondern mit zahlen. reviewer sample kann es nicht sein dann?
Scheint aber laut s.log keine Veränderung zur letzten Beta gegeben zu haben, dann kann man sich ein Wechsel eigentlich sparen, oder?
