[Sammelthread] AMD K7 - Sockel A (462)
Crazy Epox! 1M Pi dürfte nicht mehr gehen, oder?
Ich glaube langsam wirklich an 290er nF2...
270+ means vmods and also death on NF7... dropped a post on hwbot.
So which BIOS and settings were used? Where can I find that post on HWBOT?
(I did not have much time this week and was busy with my CH5F-Z)
I have more then enough boards which I can test before I go to my best boards. And... I already destroyed my best board so what else can happen...
I use NB and DDR mods already.
For which motherboard are these tools?
I was looking for a tool to change FSB in Windows. Most tools like setfsb didn`t have the right clock generator (CY28372OC) for my ASRock K7S8X (3.0). Finaly I found a useful tool to change FSB...
tools:
cheepomemtweak: change memory settings in Windows for K7 SIS Chipsets
setfsb: change FSB, well known
clockgen: change FSB, well known
setfsbU14beta2_L7S7A2: special version for L7S7A2 (SIS746)
cpucool-8-1-0: not sure of all funktions, but there is a FSB change tool with a lot of clock generators like NF2. I can use this tool for my K7S8X
I was looking in some old backups... And I found Tictac's Hotmail email address. I just mailed him to test if this still works.
Nice! If you get a response, ask him about NF2 datasheets.
  • cheepomemtweak005.zip
  • setfsbU14beta2_L7S7A2.zip
  • setfsb_2_3_178_134.zip
  • ClockGen_1.0.5.3.zip
  • cpucool-8-1-0.zip
Thanks, I will let you know if he gives a response.
@The Sandman Which BIOS settings work best for this?
Any of the experimentals or just out of the box?
Edit: @digitalbath I use 8RDAVCORE as wel..
  • 8rdavcore-0.8.8-dev.zip
digitals and Infras bios and a combination of all these 22xx 44xx values you can set in the tweaker helped a lot. For 3D benches you have to raise the agp latency using 8rda vcore. The Board was capable of booting 260+ (1.5V vdd) itself without all of these values. The "final kick" was the vmod.
Nothing compares to mine. Word :fresse:
yes, I'm a smart mark... soo
2x 8RDA6+ Pro + 6x NF7(S and non S) + 2x AN7
Other mainboards:
From which: 1x NF7, 2x Ultra B, 2x A7N8X, 1x GA7N400 Pro2, 1x K7N2 Delta L, 1x 8RD3+
And I have more from other motherboards elsewhere...
Edit: I forgot about a few sis Socket A mainboards I have, somewhere...
edit2: correct 1 picture
Was alleine der Kram kostet um die alle auf max. FSB zu modden... :fresse2: Zu meiner Schande muss ich gestehen, das bei mir auch noch drei Boards auf ihren Satz Solidcaps warten.
Hehehe....aber ich kann dann guten Gewissens sagen, falls mal ein Board verrecken sollte: "Naja, nicht so schlimm, nehme ich halt das nächste" :d
That is why I learned to solder that good quickly after years of not soldering...
Edit:
For those wondering. There are some nf3, nf4, am2 and am3 (+ 2 crosshair formula z), s775, asrock z87 formula (brand new), 3x 486, k62+ boards etc... as well.
273-MHz NF7
dann kommst du ;) (ja, nicht böse gemeint)
Direkt aus der Schachtel und unter 250-MHz bis in Win ist Schrott! I Mean it.
Krempel
Ich bin bitter
Einige dicke Backen :shot:
