Sparksnl
Urgestein
New CPU:
| Brand | Type | Socket | Ordering Part Number (OPN) | Batch Nr | Other number | Generation | Multiplier | Ext. clock | FSB | GHz | Cache | Stock voltage | Unlocked | BIOS used | OC MHz | OC voltage | post/boot | Cooler |
| AMD | Athlon XP-M 2800+ | Socket A | AXMJ2800FHQ4C | IQYHA 0431GPMW | Z445831H40127 | Barton | 16,0 | 133 | 266 | 2,133 | 512KB | 1,55v | yes | Epox Digital Bath ED | 2500 | 1,625 | boot | WC |
| AMD | Athlon XP-M 2800+ | Socket A | AXMJ2800FHQ4C | IQYHA 0431GPMW | Z445831H40127 | Barton | 16,0 | 133 | 266 | 2,133 | 512KB | 1,55v | yes | Epox Digital Bath ED | 2604 | 1,725 | boot | WC |
| AMD | Athlon XP-M 2800+ | Socket A | AXMJ2800FHQ4C | IQYHA 0431GPMW | Z445831H40127 | Barton | 16,0 | 133 | 266 | 2,133 | 512KB | 1,55v | yes | Epox Digital Bath ED | 2695 | 1,850 | boot/PI 1M | WC |
| AMD | Athlon XP-M 2800+ | Socket A | AXMJ2800FHQ4C | IQYHA 0431GPMW | Z445831H40127 | Barton | 16,0 | 133 | 266 | 2,133 | 512KB | 1,55v | yes | Epox Digital Bath ED | 2750 | 1,975 | boot/PI 1M | WC |
| AMD | Athlon XP-M 2800+ | Socket A | AXMJ2800FHQ4C | IQYHA 0431GPMW | Z445831H40127 | Barton | 16,0 | 133 | 266 | 2,133 | 512KB | 1,55v | yes | Epox Digital Bath ED | 2800 | WC |
Yes the 2100+ deserves a cold threathment. I might do the 2800+ as well, but I always thought that this cpu would come later in the year. You did see that I have 2 more 2800+ xp-m? 😁@Sparksnl
awesome CPUs! It seems cooling is the way to go!
Da klemmts halt beim DFI. Ohne Vmod ist auch bei einem scharfem Bios wie dem 619XT Feierabend. 253-MHz laufen mit 3.33V. Bessere Resultate würde man nur mit sehr guten BH-5 erzielen. Die sind aber alle vom Markt bzw. in Schuhkartons oder hinter der Couch oder im Schrank usw. (ihr wisst schon@Sparksnl
Yes, reaching ~2700MHz at 1,85V is damn awesome. I wish my CPUs were that good.
I still have my 3 new XP-M 2400+ from 2007 to test.
@The Sandman
32M / 260MHz / CL2 ist schon krass. Da kommen tatsächlich nicht viele Bretter hin. Dafür bekomme ich keine Vali >266MHz hin.
Mein ASUS A7N8X-E #1 dürfte nun komplett gemoddet sein. Die vier SMD Widerstände wurden nun getauscht. Ich muss das board noch testen (und noch einmal putzen).
I am counting 24 BH5 and 21 CH5 here.
I'm at ~10 AT-6 sticks, 4 UTT BH and 3 CH.That offer is 3 years old... I'm not sure it's still available. Besides that, i get email notifications for AT-6 in 256mb or 512mb sizes...bh5 on Kleinanzeigen today
So far there wasn't a single stick offered in 2 months.Mein ASUS A7N8X-E #1 dürfte nun komplett gemoddet sein. Die vier SMD Widerstände wurden nun getauscht. Ich muss das board noch testen (und noch einmal putzen).
Damit wird der Spannungsteiler im Feedback Loop für die VDimm niederohmiger. Hat den Vorteil das äußere Einflüsse nicht mehr so stark stören können und sollte in der Theorie eine sauberere Regelung geben.Habe den Sinn entweder nicht verstanden oder er wurde hier schonmla besprochen und ich habe es nicht gelesen.
Nun auch mit Dark Theme (Glühbirne oben rechts anklicken)die Bierbude im neuen Kleid.. Danke fürs hosten!
