BIOS
Anleitung
7. Enter drücken
10. PC neu starten
OVERCLOCKING | TOOLS
800mv = 320 Watts
850mv = 370 Watts
900mv = 430 Watts
912mv = 450 Watts
UNDERVOLTING
800mv = 320 Watts
850mv = 370 Watts
900mv = 430 Watts
912mv = 450 Watts
AsusTUFMLCCMLCC
AsusStrixMLCCMLCC
EVGAXC3Mixed (1)Mixed (2)
EVGAFTW3Mixed (2)**Mixed (2)
GalaxBlackMixed (1)Unknown
GigabyteEagleUnknownPOSCAP
GigabyteGamingPOSCAPPOSCAP
MSIVentusMixed (1)Mixed (2)
ZotacTrinityPOSCAPPOSCAP
ZotacX-GamingUnknownPOSCAP
3090 TI Power Limit Übersicht
AsusTUF
AsusStrix OC LC516 W maximal
EVGABlack Gaming
EVGAFTW3
EVGAFTW 3 Ultra
KÜHLERTAUSCH | GARANTIE
ASRockKulanz5
Asus✓1✓1
EVGA✓2
Gainward✓3
Gigabyte
KFA²
MSI
Nvidia
Palit✓4
PowerColor
SapphireKulanz5
XFX
Quelle: Computerbase
MSI:
ZOTAC:
eingereicht werden."
Gainward und Palit
Aktuelle Referenzkarten
Zotac:
GALAX/KFA2:
Gainward:
Palit:
PNY:
INNO3D:
Die BP dient ja nicht groß zur Kühlung. Sicher kannst du damit am Anfang etwas wärme verteilen...
Aber da passiert nichts. Ist mehr für Stabilität und Optik
meine läuft auch ohne Backplate - mit Ghettomod Lüfter :d hab hier ein Bild gepostet.
Tomb Raider teste ich demnächst auch mal, bisher ruckelt hier nix irgendwie komisch
It's a shame, can't continue with the new MSI because the PC switches off in Timespy (NT too weak) : cry:
Which NT can you recommend to me? I already have one of the best in it, but it's probably not good (1000W Seasonic Prime Ultra Titanium (SSR-1000TR)
The older versions of the Prime Ultra Platinum / Titanium use the same OCP circuit as some of the earlier Focus lines and the X-1050 (and possibly SS-1050XP or SS-1000XP) lines, which were known to cause issues with Vega64 and may have problems with 3090's, especially modded ones. This problem was fixed in the newest One Seasonic revisions, called directly on the box "TX-1000" for Prime Titanium, and "PX-1000" for Prime Platinum. It's also worth noting that the PX-1000 also now has two more PCIE PSU plugs on the back and comes with two more PCIE 6 + 2 (8 pin) cables, as the old 6 + 2/6 + 2 into 8 pin single split cables are no longer included. These PSU's will not have any issues anymore.
If the box says TX-1000 or PX-1000, it is updated (2019/2020 year model). If it says Prime Ultra Platinum or Prime Ultra Titanium, it is the older model.
dafuq 🤣😂🤣😂
[ATTACH = full] 552012 [/ ATTACH]
Mine came yesterday.
It's very good stuff. It's like 2C better than Thermalright TFX (which beats regular Kryonaut after it cures for a few days), and 4C better than Kryonaut. This stuff is legit.
You also get the full 33 grams for $ 100 USD. That's 3.3 grams / $ 10 dollars which is actually a fair market price, since 11.1 gram syringe of regular Kryonaut was about $ 30.
So yes it's expensive but worth it.
For best application, just apply a large "X" line pattern to the GPU or a CPU IHS, rather than spreading, then apply four very small drops to each middle "quadrant" of your X for completeness. Screwing down the heatsink will create a perfect spread.
Kennt jemand eine Bezugsquelle für ein Custom Cable für die nv FE3090? Gerne passend für ein bequiet? Das schaut einfach bescheuert aus
Juhu, I'm a bit behind in the forum. What for a padmod at FE? Is there anything I should know?😮
This is from my own testing, the best FE backplate pad mod.
Use 1.5mm Thermalright Odyssey 12.8 w / mk or better pads (I am not sure if the Fujipoly 17 w / mk pads are suitable as they are WAY too expensive and tend to break apart after first application / disassembly).
Use the pads everywhere marked on the PCB. These pads work great and compress easily. 120mm * 120mm versions are available on Aliexpress but may need to be specially ordered from a USA or Europe supplier.
Ive done this Padmod becuase of a stuttering issue, and and posted pictures here. But i can say for me, its not needed, stock ist good.
Aber vermutlich nicht in z.B. weiß
Naja Spezialwünsche waren immer schon teurer oder ;) Musst halt auf Cabelmod warten..
Habe mich nicht infomiert weil mir das kostenlose von Seasonic reicht.. be quiet habe ich eben am Rande mitbekommen.
I own the 1300W Seasonic Prime Platinum, is this the newer better version or the old one ?
Buyed it a few weeks ago.
No issues.
As i can see in the der Bauer Videos, you need more of the Extreme paste for application than from the normal kryonaut ? So for mee, its more expensive.
My Colleague make good experince with the Alphacool Subzero Paste with 16 WMK (more than the Kryo Extreme)
old: Prime 1300 Platinum. new: Prime PX-1300. look here
Packaging Says Prime 1300 Platinum SSR - 1300PD
But there is no newer version out there..
Did not inform me because the free from Seasonic is enough for me .. I just noticed be quiet on the edge.
I own the 1300W Seasonic Prime Platinum, is this the newer better version or the old one?
No issues.
As i can see in the der Bauer Videos, you need more of the Extreme paste for application than from the normal kryonaut? So for mee, its more expensive.
My colleague make good experince with the Alphacool Subzero Paste with 16 WMK (more than the Kryo Extreme)
Can you take a picture of your PSU box?
Does it say Prime "PX-1300" on the box or does it say "Prime Platinum 1300" on the box?
The new version should *ONLY* say "Platinum" on the "80 Plus" square logo, like "80 Plus / Platinum". It should NOT say Platinum next to the product name.
I've done this Padmod because of a stuttering issue, and and posted pictures here. But i can say for me, its not needed, stock is good.
Well, special ;) requests have always been more expensive or just have to wait for Cabelmod ..
Stuttering issue !! That's the EXACT SAME ISSUE I HAD with the pure stock card (before I even opened it up for the first time!). It was most noticeable with "Fast Sync" enabled along with Rivatuner Statistics Server's Scanline Sync working with it. It was very obvious and very annoying.
The Pad mod completely fixes that. I noticed your pad mod is almost the same as mine too.
My Sturtering isses has not been fixed with the mod, but its gone with a 2070 super card..
Here the pictures
My Sturtering isses has not been fixed with the mod, but its gone with a 2070 super card ..
Here the pictures
That's the 2017 year version. It probably won't power trip due to the high total wattage, but the 1000W version of this may trip, and the 850W version definitely * WILL * trip.
This has the "Older" OCP Circuitry.
This one is the current version (purchased March 2020).
But at the Sesonic site Stands TBA, i think there is no newer 1300W Version out there..
You write about the 1000 Watts.
But at the Sesonic site Stands TBA, i think there is no newer 1300W Version out there ..
You write about the 1000 watts.
Yes I am aware.
I'm just saying this because another user with a "Prime Platinum 1000W" (smaller version of yours) * DID * have the shutoff issue. He had to use a lower power limit to avoid it. :)
The shutoff issue requires the PSU to be power cycled from the back.
My PX-1000 which is updated hasn't shut off yet, despite throwing 550 watts at it with a shunt mod.
Ich müsste mal eine Frage in den Raum stellen.
Ich habe für meine MSI RTX 3090 Ventus 2 Wasserkühler gekauft.
Einmal von Alphacool und einen von Bykski.
Jetzt kam als erstes der Kühler von Bykski.
Diesen habe ich montiert und mich gewundert das er gar keine Backplate besitzt.
Ich habe den Support angeschrieben und dieser meinte, das in der V1 keine dabei wäre. Erst ab der V2 im Januar wäre diese bestellbar.
Jetzt meine Frage. Kann ich die Karte auch ohne Backplate laufen lassen?
Erstmal nur ohne OC natürlich.
Ventus hab ich auch und warte immer noch auf mein Block von Alphacool(n):grrr:
Wieso machst dein original Backplate von Ventus nicht drauf, sollte doch gehen oder täusche ich mich da?
Wo hast du Byski Block bestellt?
Hab keine lust mehr auf Alphacool zu warten wenn Byski schneller geht würd ich es auch bestellen.
Kannst vielleicht noch berichten wie die Kühlleistung von Byski so ist?
@Thrawn. I recommend to contact the Seasonic Support...
Moin,
hab jetzt endlich meine Versandbestätigung von NBB für meine Zotac 3090 Trinity bekommen und wollte den EK Block bestellen, kann man die Conductonaut LM ohne Probleme bei den 3090 Katen benutzen ?
Yes I am aware.
Thanks for your help
I have no issues at all for the moment. Just not want a "bad version" of the psu.
I only oced the FE to 400 Watts, no problem.
Where are u from ?
Warum das ?
Und welche Karte findest du besser ?
Hi zusammen,
habe die Karten 3090 Strix OC und EVGA 3090 FTW3 nun einige Male aus und eingebaut, hin und her probiert... hier ein paar Ergebnisse...
zunächst ein paar Taktraten die die Karten 100% rockstable ohne Reset oder Fehler schaffen (= Port Royal Stress Test voll durchgelaufen, DOOM Eternal, Godfall, WOW, D3, Boarderlands 3,...)
bei 850mv schafft die FTW3 1875
bei 850mv schafft die Strix 1935
die Strix ist mit 900mv permanent über 2000 aber halt nicht in jedem Game
wenn ich die Strix"frei" laufen lasse und +150mhz einstelle kommt sie in diversen Games über 2145-2160 meist ist sie dann um 2100...
(Wow 4k, Settings 10 alles Max... aber da hat die Karte halt trotzdem nicht viel zu tun xD)
Gpu-z ist immer am 2. Bildschirm...
vermutlich ginge noch mehr wenn man das erzwingen will, aber das ist nur Selbstblendung, denn bei "harter" Belastung ist man wieder instant unter 2000
*hust* man kanns auch übertreiben... aber das ist nicht save... das rennt etwa ne Minute und dann ist das game Tot :d
Warum also nur 850mw... das halten die Karten in allen Games die ich bisher getestet habe -> mag stabile Taktraten...
Hier... echte Belastung mit "nur" 850mv.. neues Game... porno Grafik... arme Grafikkarte :fresse:
bei Godfall schwanken die Karten normal im Game zwischen 440w und hart am Powerlimit in der Base ist die Strix permanent bei 460w+...
In Boarderlands 3 sind die Karten bei 430-440w
so nebenbei die Strix säuft aus Prinzip 10-20w mehr...
bei 775mw schafft die EVGA 1725
bei 775mw schafft die Strix 1815
liegt aber vermutlich einfach am Chip und weniger an der Karte per se...
Kühlung...
bei identischen Werten drehen die Lüfter auch nicht groß unterschiedlich auf... 50-100rpm für die selbe Temperatur/Spannung/Takt
sprich die Lautstärke ist entweder nicht wahrnehmbar oder sehr laut und das bei beiden Karten.
Ja die Strix ist deutlich größer und der Kühler mächtiger, aber ganz ehrlich... das merkt man nicht wirklich bei 430w+ drehen beide Karten voll auf was die Lüfterzahlen angeht... laut=laut
einen großen Unterschied habe ich da damals von der Trinity 3090 zur FTW3 bemerkt... die wirkt im Vergleich zu den beiden Karten fast mickrig und da waren die Lüfter auch durchwegs um einiges lauter-schneller am drehen...
die Karte ist aber nicht mehr hier, daher kein Vergleich zur Strix möglich...
Sprich die Karten schenken sich wenn man ehrlich ist nicht sehr viel....
ALLERDINGS 😬
die Spannungswandler😱
ich hätt es nicht geglaubt... die Strix hört man einfach immer
es ist wie im Urlaub, wenn man eine Grille im Zimmer hat... nervig
vor allem wenn ich mir überlege... ich bau die Karte auf Wakü um... das Luftgeräusch ist weg, die Karte zirpt immer noch
nein danke
Zufällig war heute mein Bruder hier... habe die Strix dort durch einen Benchmark gejagt und er hat mich gefragt was das für ein störendes Geräusch ist...
die EVGA ist nicht unhörbar aber sie hat dieses Zirpen nicht, mehr so ein extrem leises ruhiges sssssss... keine Ahnung aber ICH HÖR ES NICHT
es ist quasi kein Unterschied zwischen Leerlauf und Belastung
ich muss mich extrem auf das Geräusch konzentrieren oder mit dem Ohr an die Karte gehen...
Fazit die Strix hatte einen kurzen 1 tägigen Gastauftritt in meinem Rechner und wird wieder schön verpackt...
@Thrawn. Ich dachte, du hättest Probleme mit dem Teil. Habe aber schon gelesen, dass du nur Sorge hattest ein schlechteres Produkt erworben zu haben. Aber wenn es läuft ist ja alles gut!
Ne keine Probleme, scheint momentan eh kaum was am Markt zu geben, geschweigedenn ein TX 1300..
Kann auch gut sein das das garnicht früher abschaltet wie die 1000er und einfach nur umgelabelt wird irgendwann irgendwann und die Technik sich hier garnicht ändert. Ist ein wenig undurchsichtig..
Nice to meet you ! Welcome in the German Hardware Nerd Corner :eek: :bigok:
