Sparksnl
I allready extracted it a while ago and noticed that the .IMA files are zip files. But thanks.
The .BMP files are pictures and the EZB files are partially readable as txt.
I used GRUB to make a bootable USB.
Edit: Strange that you get more then the .bin file. I only see it's bin file in LPB619XT.IMA
Edit 2: Ah I see WinImage opens more.
1.825V for 2.6ghz is an above avarage (aka decent) chip, but not a golden sample. I'd be happy with it nowadays.
