HWL News Bot
News
... weiterlesen
Leider gibt unser Exemplar im Stillen Modus bei kleiner Drehzahl ein leicht klackerndes Geräusch von sich. Dies wird bei Verwendung mit SSDs und in einer ruhigen Umgebung sehr schnell störend.
<scemd>
<fan_config period="20" threshold="6" type="DUAL_MODE_HIGH" hibernation_speed="UNKNOWN">
<disk_temperature fan_speed="20%10hz" action="NONE">0</disk_temperature>
<disk_temperature fan_speed="30%10hz" action="NONE">41</disk_temperature>
<disk_temperature fan_speed="50%10hz" action="NONE">46</disk_temperature>
<disk_temperature fan_speed="60%10hz" action="NONE">50</disk_temperature>
<disk_temperature fan_speed="99%10hz" action="NONE">53</disk_temperature>
<disk_temperature fan_speed="99%10hz" action="SHUTDOWN">61</disk_temperature>
<m2_temperature fan_speed="20%10hz" action="NONE">0</m2_temperature>
<m2_temperature fan_speed="50%10hz" action="NONE">52</m2_temperature>
<m2_temperature fan_speed="99%10hz" action="NONE">60</m2_temperature>
<m2_temperature fan_speed="99%10hz" action="SHUTDOWN">70</m2_temperature>
<cpu_temperature fan_speed="20%10hz" action="NONE">0</cpu_temperature>
<cpu_temperature fan_speed="50%10hz" action="NONE">65</cpu_temperature>
<cpu_temperature fan_speed="99%10hz" action="NONE">70</cpu_temperature>
<cpu_temperature fan_speed="99%10hz" action="SHUTDOWN">90</cpu_temperature>
</fan_config>
<fan_config period="20" threshold="6" type="DUAL_MODE_LOW" hibernation_speed="UNKNOWN">
<disk_temperature fan_speed="30%10hz" action="NONE">46</disk_temperature>
<disk_temperature fan_speed="50%10hz" action="NONE">52</disk_temperature>
<disk_temperature fan_speed="60%10hz" action="NONE">55</disk_temperature>
<disk_temperature fan_speed="99%10hz" action="NONE">58</disk_temperature>
<m2_temperature fan_speed="50%10hz" action="NONE">56</m2_temperature>
<m2_temperature fan_speed="99%10hz" action="NONE">65</m2_temperature>
<cpu_temperature fan_speed="50%10hz" action="NONE">70</cpu_temperature>
<cpu_temperature fan_speed="99%10hz" action="NONE">75</cpu_temperature>
</fan_config>
<scemd>
<disk_temperature fan_speed="20%40hz" action="NONE">0</disk_temperature>
<disk_temperature fan_speed="30%40hz" action="NONE">41</disk_temperature>
<disk_temperature fan_speed="50%40hz" action="NONE">46</disk_temperature>
<disk_temperature fan_speed="70%40hz" action="NONE">51</disk_temperature>
<disk_temperature fan_speed="99%40hz" action="NONE">53</disk_temperature>
<disk_temperature fan_speed="99%40hz" action="SHUTDOWN">61</disk_temperature>
<m2_temperature fan_speed="20%40hz" action="NONE">0</m2_temperature>
<m2_temperature fan_speed="50%40hz" action="NONE">51</m2_temperature>
<m2_temperature fan_speed="99%40hz" action="NONE">60</m2_temperature>
<m2_temperature fan_speed="99%40hz" action="SHUTDOWN">70</m2_temperature>
<cpu_temperature fan_speed="20%40hz" action="NONE">0</cpu_temperature>
<cpu_temperature fan_speed="50%40hz" action="NONE">60</cpu_temperature>
<cpu_temperature fan_speed="99%40hz" action="NONE">70</cpu_temperature>
<cpu_temperature fan_speed="99%40hz" action="SHUTDOWN">90</cpu_temperature>
</fan_config>
<disk_temperature fan_speed="30%40hz" action="NONE">46</disk_temperature>
<disk_temperature fan_speed="50%40hz" action="NONE">51</disk_temperature>
<disk_temperature fan_speed="70%40hz" action="NONE">56</disk_temperature>
<disk_temperature fan_speed="99%40hz" action="NONE">58</disk_temperature>
<m2_temperature fan_speed="50%40hz" action="NONE">56</m2_temperature>
<m2_temperature fan_speed="99%40hz" action="NONE">65</m2_temperature>
<cpu_temperature fan_speed="50%40hz" action="NONE">65</cpu_temperature>
<cpu_temperature fan_speed="99%40hz" action="NONE">75</cpu_temperature>
</fan_config>
im Grunde gleich zum 918+, schade, hatte auch auf mind. 2.5Gb LAN gehofft.
Tja, nur Gigabit, damit hat sich das NAS schonmal disqualifiziert.
