Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
AMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Chipset
X570
Memory
3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
Graphic
Integrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support
3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage
3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LAN
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Bluetooth
Bluetooth® 5.0
Audio
SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports
3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
Accessories
User's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS
256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic
1 x HDMI 2.0
1 x DisplayPort
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
Storage
Supports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN
1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFi
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth
Bluetooth® v5.2
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB Ports
AMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O Ports
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
Accessories
Cables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
BIOS
Form Factor
ATX Form Factor
Note
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
Chipset
X570
Memory
Graphic
Multi-GPU Support
Expansion Slots
AMD X570 chipset
2 x PCIe 4.0 x1
Storage
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
LAN
Anti-surge LANGuard
Audio
Audio Feature :
- Sonic Radar III
USB Ports
3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
Special Features
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
Accessories
User's manual
1 x Supporting DVD
BIOS
Form Factor
ATX Form Factor
Note
Chipset
X570
Memory
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Graphic
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
Expansion Slots
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
Storage
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
Supports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Bluetooth
Bluetooth® 5.0
Audio
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
USB Ports
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
Special Features
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
1 x DisplayPort
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports
1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
Accessories
User's manual
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
BIOS
Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note
*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
Sound setzt aus oder knistert
Immer wieder USB Disconnects
Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
USB Disconnects
Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
USB Flashback funktioniert nicht
Bitte folgende Punkte ausprobieren:
- Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
- Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
- Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
BIOS/UEFI Downgrade
Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
Ist der Chipsatz Lüfter regelbar?
Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
Chipsatz Temperatur zu hoch?
Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
Rechner bootet nicht, wenn eine Soundkarte verbaut ist
Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Also wenn man 5000 U/min nicht heraushört, da bin ich mal ganz klar davon ausgegangen, dass der Rest vom System für mein Empfinden laut sein muss.
Ich höre selbst 2500 U/min vom Chipsatzlüfter deutlich aus meinem System raus. Wenn die restlichen Komponenten nun lauter wären würde ich dies natürlich auch nicht heraushören.
Aber wenn du mit der Chipsatzlüfterlautstärker zufrieden bist freut mich das für dich. Hilft mir hier nur nicht weiter...
Meinst du die Drehzahl verändert sich durch einen neuen Lüfter? Ich hätte behauptet, dass das eher mit Temperatur bzw Bios verknüpft ist und nicht der Lüfter selbst steuert.
Mich stört nicht mal so sehr die Lautstärke sondern die Frequenz.
Das klingt für mich wie gesagt eher nach unterschiedlichen Güten der Lüfter was das Geräusch angeht. Also unterschiedlich laut bei gleicher Drehzahl.
Ich hab einen offenen Bench, da hör ich so ziemlich alles raus, aktuell nervt mich eine leichte Vibration der Platine im Netzteil, die temperaturabhängig kommt und geht.
Aber den Chipsatzlüfter höre ich nicht - wohl Glück gehabt.
Wenn ihr mit einer Drehzahländerung Linderung habt, okay, Mea Culpa, ich bin von meinem Lüfter ausgegangen.
Die ganze Kühlerkonstruktion ist beim X570-I eher ungeschickt, Kühlerfinnen parallel zur Graka, liegender Lüfter... War wohl die billigste Variante.
Quer zu den Steckplätzen laufende Finnen und ein Lüfter, der stehend zur CPU hin die Luft abzieht, wäre wohl besser gewesen. Hätte, hätte, Fahradkette.
Mein Windows Jetzt (1909 - Build 19363.836) hat gestern nach paar Wochen ein Update gemacht und seit dem ist die CPU zu 99% über 4000MHz und 1,3V + Teilweise springt der auf 1,448V ohne da ich was mache.
Bios
Version 1407 kein OC und auch nichts anderes im Bios umgestellt bis auf D.O.C.P wegen Ram. Hat vielleicht einer von euch sowas schon beobachtet?
Hmm so ein bisschen rumprobiert und einzige lösung ist es auf Energiesparmodus umzuschalten. Dann Taktet die CPU auch runter. Bei Benchmark Taktet die dann auf 4200 MHz bei 1,63V Spannung.
Komisch ist das es vorher auch bei Ryzen Balanced funktioniert hat.
Installiere mal diesen Energiesparplan: Energiesparplan V4 Dann taktet er bei leichter Last nicht mehr unnötig hoch und bleibt deutlich kühler im Idle.
Hi. Ich habe mir heute meinen ersten Desktop PC selbst gebaut. Es funktioniert auch alles super, bis auf eine Sache. Nämlich kann ich über Aura Sync nur meinen RAM finden, sonst nichts. Weder meine RGB-Lüfter, noch meinen Wraith Prism CPU-Kühler noch mein Gehäuse und auch nicht das ROG Symbol auf dem Board kann ich über Aura Sync ansteuern. Ich habe die aRGB Lüfter von uphere mit dem dazugehörigen RGB Hub gekauft und wollte alles über diesen Steuern. Also hab ich den Hub ans Mainboard angeschlossen und meine Lüfter und die LED Beleuchtung meines Gehäuses über den Hub mit dem Mainboard verbunden. Den CPU Kühler hatte ich erst nur über den USB-Anschluss auf meinem Mainboard an dieses angeschlossen und er hat von selbst seine Farbe geändert. Seit ich aber den 4-Pin Stecker mit meinem Mainboard verbunden habe leuchtet der Kühler nur noch in weiß.
Mein Setup sieht wie folgt aus:
-rog strix X570-e-gaming
-ryzen 5 3600
-Gigabyte RX 5700 XT
-32 GB G.Skill Trydent Z rgb ram mit 3200 MHz
-besagte uphere Lüfter mit beiliegendem Hub
-Wraith Prism Cooler
-Bitfenix Dawn tg Gehäuse
-Cooler Master MWE 550W Netzteil
Das BIOS ist auf der neuesten Version das Problem war jedoch vorher schon da.
Vielleicht hat ja jemand eine Lösung für mein Problem.
Danke schonmal im voraus, SiBo
Mein Windows Jetzt (1909 - Build 19363.836) hat gestern nach paar Wochen ein Update gemacht und seit dem ist die CPU zu 99% über 4000MHz und 1,3V + Teilweise springt der auf 1,448V ohne da ich was mache. Anhang anzeigen 508588
Bios
Also ich habe die Build 18363.863. Hast du dich verschrieben? Bei mir ist jedenfalls die CPU im Idle komplett im Ruhezustand ohne Spitzen. Nur wenn ich etwas öffne taktet er hoch auf 500-800 Mhz
Hi Leute - bin neu im Forum, da ich hier endlich einen Thread über das Motherboard 570-F gefunden habe.
Ich habe folgende Fragen und hoffe einer von Euch Experten kann mir eine Unterstützung geben.
Also zuerst - habe ich 2 Speicherriegel mit 3600 - Die werden mit Auto nur mit 2666 erkannt. Ist das o.k.
zudem habe ich beide Rigel in B1 und B2 gesteckt, da A1 und A1 nicht funktionierten bzw. der PC keinen Muxx machte.
Jetzt hab ich im Handbuch gesehen, dass einer in B2 und der andere in A2 rein kommen muss. Das habe ich bein meinen anderen ASUS Bords nicht.
Bin ich da jetzt auf dem falschen Pfad?
Für DDR4-3600 musst du das XMP Profil im Bios aktivieren: Bios -> Ai Tweaker -> Ai Overclock Tuner -> DOCP einstellen. Damit dies aber funktioniert müssen die Riegel unbedingt in den Slots A2 und B2 stecken, ebenso musst du eine passende CPU haben.
Seit meinem 1800x gehe ich nur noch nach der Qualified Vendor List, nachdem ich mit einem G.Skill Kit massive Probleme hatte. Wenn der Ram nicht in der Liste auftaucht hat man leider keine Garantie die volle Geschwindigkeit zum Laufen zu bekommen. Das ist zumindest meine Erfahrung.
Hab die gleichen in Rot (BL2K16G36C16U4R). Laufen super mit den XMP-Werten, bei mir auch übertaktet auf 3800MHz (siehe weiter vorne im Thread) auf dem X570-E
Wenn bei Tweaker bei der Frequenzerhöhung des Speichers mit Ai Overclock Tuner - D O C P nicht manuell von AUTO umgestellt wird, läuft der Speicher da o.k. ?
Also wenn ich den Zustand auf AUTO lasse. Erkennt das Board fehlerfrei das Übertakten?
@Reous
Ich habe zugegebenermaßen nicht die riesen Ahnung von den (Asus) AMD Brettern. Bei Board Nr 3 (auch Asus) hab ich, wenn ich die SOC Spannung auf Auto lasse im Ryzen Master Tool 1,35Volt und mehr (!) Ab wann ist die Spannung für den Controller tödlich?
Stelle das per Hand immer auf 1,1 bis 1,15 Volt. Ist tatsächlich bei allen so.
Woran liegt das?
Schludert Asus da? Sowas mit zu viel Spannung auf Auto gab es auch bei Asus 2011/3. Da haben sich einige ihre 5960X gegrillt.
Das Gaming -E erkennt scheinbar die F4 3600C1D-32GVKC @3733 nicht ganz sauber. Trfc steht als "Auto" bei 300, ausgelesen 600 ?
Taste mich grade bisschen ran, weil mit Calculator komm ich nicht weiter.
@Manixx
Ich bin jetzt nicht sicher was du genau meinst. Wenn du das XMP (DOCP) Profil nicht aktivierst, dann läuft er nur mit dem hinterlegten SPD Profil. Das ist meist was zwischen 2133 - 2666.
@Joker (AC)
Das mit den 1.35V ist ein (für mich) bekannter Auslesefehler. Hab das auch schon bei anderen Hersteller gesehen. Real liegen aber nur die eingestellten ~1.10V an.
Ist die trfc bei dir wirklich auf 300 oder 312 bei Auto? Letzteres ist auch so ein blöder Anzeigefehler.
@Reous
Die 1,35Volt und mehr habe ich, wenn ich es auf Auto lasse.
Fix eingestellt sind es auch zB 1,15V im Master Tool (oder HW-Info)
Zu den Subtimings. Leider kann der Ryzen Ram Calculator mir den ausgelesenen Dateien nichts machen.
Bei den B-Dies ging es optimal.
Ich mach mal Screen davon. Hab da Trfc 1,2 und 3 (meine ich)
Edit, Screen (Sieht auf 470Prime auch so aus)
Ich weiß, jammern auf hohem Niveau
@Joker (AC)
Wie gesagt, zumindest mir ist das mit der trfc geläufig. Wenn man einen Wert manuell einträgt, dann wird es korrekt angezeigt. Der Auto Wert ist natürlich auf den ersten Blick irreführend.
ich weiss ich bin neu und habe hier noch keinen Beitrag geleistet, trotzdem würde ich mich über einen Tipp freuen.
Und zwar habe ich das X570-E und wollte mir den Biosmod installieren damit ich meinen PCH Lüfter regeln kann.
Nur stellt sich mir das Problem dass wenn ich das via EZ-Flash machen will er mir folgende Meldung rausspuckt:
"File is not a proper Bios"
Gibts da irgendnen Trick? Am Stick kanns nicht liegen, ein Bios von Asus konnte ich aufspielen.. habe jetzt 1405 installiert und wollte auf 1405X2..
Oder ist USB-Flashback was anderes als das EZ-Tool?
EDIT: Ich glaube ich habe mir die Frage gerade beantwortet.. ich muss den netten Knopf auf der IO-Blende nach folgender Anleitung nutzen..
der ist für den chipsatz und ja die position ist schlecht.. das layout vom e ist das gleiche.. ich hab die karte aber auch im ersten port.. solang der kleine lüfter dir nich zu laut wird ist mMn alles ok.
Hallo bin Neu hier und habe seit Gestern ein Asus 570 E-Gaming. Scheint so weit zu funktionieren, nur habe ich folgendes Problem, dass ich keine USB Headset verwenden kann. Diese Krachen wenn ich sie verwende. Habe ein Logitec 935 und ein Steelseries bei beiden das selbe. Verwende ich die Headset über den Klinkenanschluss alles kein Problem. Hat wer das selbe Problem oder kann mir bitte weiterhelfen, habe schon versucht die Treober neu zu installieren pm Mainboard und auch von den Kopfhörer, keine Besserung. Auch werden diese als Lautsprecher erkannt, war bei meinen alten PC nicht so.
