emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
Produktseiten
Preisvergleich
Press Release
G.SKILL Launches Trident Z Royal Series DDR4 RGB Memory Kits
Taipei, Taiwan (20 November 2018) - G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is launching Trident Z Royal series DDR4 RGB memory kits, featuring a patent-pending full-length crystalline light bar upon a polished heatspreader in gold or silver with stunning 8-zone RGB lighting. The patent of the crystalline design on PC components has been applied for across major countries. Available in high-speed specifications, the Trident Z Royal is first available from DDR4-3000MHz to DDR4-4600MHz at launch. With the perfect marriage of RGB lighting and speed, the Trident Z Royal is the ideal memory kit for any high-class system build.
Check out the following trailer for a first-look at Trident Z Royal:
Magnificent Royal Design
Trident Z Royal is the latest addition to the Trident Z flagship family, featuring a crown jewel design. Meticulously crafted to display just the right amount of light refraction, the crystalline light bar scatters the RGB colors in a magnificent display of LED lighting. Complementing the patented high-class light bar design, polished aluminum heatspreaders of gold or silver colors cools the memory modules in the award-winning classic Trident Z tri-fin design. And to help maintain the pristine shine of the heatspreaders, each Trident Z Royal memory kit comes with a piece of microfiber cloth to let you wipe away fingerprints and dust.
Upgraded RGB Lighting
Inside the Trident Z Royal is the next generation RGB module designed with 8 individually controllable lighting zones, which allows for smoother color transitions and provides an even more stunning lighting experience for your build. To control this next generation RGB memory, a new set of lighting control software will be available for download from the official G.SKILL website.
Extreme High-Speed Specifications
Engineered on a newly designed custom PCB to accommodate the increased lighting zones, the Trident Z Royal is also built for high speed overclocking specifications, ranging from 16GB to 128GB kit capacities and up to DDR4-4600MHz memory speeds. For a list of specifications available at launch, please refer to the chart below:
XMP 2.0 Support & Availability
The new Trident Z Royal series memory kits are equipped with the latest Intel XMP 2.0 profiles for easy one-click memory overclocking, and will be available via G.SKILL worldwide distribution partners in December 2018.
Spezifikationen
Galerie
News & Reviews
[News] Es glitzert und funkelt: G.SKILL stellt den Trident Z Royal vor - HARDWARELUXX
[Reviews]
Collectors Editions
https://www.gskill.com/en/product/f4-3000c16q-32gtrsu
https://www.gskill.com/en/product/f4-3200c16q-32gtrsu
https://www.gskill.com/en/product/f4-3200c14q-32gtrsu
https://www.gskill.com/en/product/f4-3600c17q-32gtrsu
https://www.gskill.com/en/product/f4-3600c16q-32gtrsu
https://www.gskill.com/en/product/f4-4000c17q-32gtrsu
"This memory kit set includes the Royal Display Box, letting you show off the default lighting effect of your memory kit by simply connecting the USB-to-microUSB cable to any USB port or phone charger..."
[Reviews]
- [User-Review] G.Skill Trident Z Royal DDR4-4000C17D-16GTRS Overclocking Test @ Hardwareluxx (getestet von websmile)
- G.SKILL Trident Z Royal F4-3200C16D-16GTRG & F4-3200C16D-16GTRS @ Quasarzone.co.kr
- G.SKILL Trident Z Royal F4-3200C16D-16GTRS @ Think Computers
- G.SKILL Trident Z Royal F4-3200C14D-16GTRS @ Guru3d
- G.SKILL Trident Z Royal F4-3200C14D-16GTRS @ lab501.ro
- G.SKILL Trident Z Royal F4-3200C14D-16GTRG @ Tom's Hardware
- G.SKILL Trident Z Royal F4-3600C16D-16GTRS @ purepc.pl
- G.SKILL Trident Z Royal F4-3600C16Q-32GTRS @ Next Hardware
- G.SKILL Trident Z Royal F4-4000C17D-16GTRS @ wccftech
- G.SKILL Trident Z Royal F4-4000C17D-16GTRS @ Techpowerup
- G.SKILL Trident Z Royal F4-4000C17D-16GTRS (2x) @ Tweaktown
- G.SKILL Trident Z Royal F4-4600C16D-16GTRG @ coolaler
- [Video] G.SKILL Trident Z Royal F4-3200C16Q-32GTRS @ KreativEcke (Youtube)
Software
Download
- G.SKILL Royal Lighting Control v1.00.03
Changelog schrieb:Added backwards support for Trident Z RGB series.
Please uninstall previous G.SKILL lighting control software before installing Royal Lighting Control; for clean uninstall instructions for Trident Z RGB v1.06.68, please visit this forum thread. - G.SKILL Royal Lighting Control v1.00.02
User Manual: Royal_Lighting_Control_Software_Guide_1.18i.pdf
Downloadhinweise
1) Before installing, please make sure the motherboard BIOS is updated to the latest version.
2) Before installing the software, please extract the ZIP file contents to a known location. If you are using Windows built-in zip utility or having trouble with the installation process, please right click on the ZIP file, click on "Properties", and then check "Unblock". (Click here for an example screenshot)
3) When installing, if the installer isn't working properly for you, please right click on the installer EXE file and choose to "Run as Administrator".
4) On some Z370 and ASUS X99 motherboards, enabling "SPD Write" in BIOS is required: PDF Guide.
5) This software may conflict with other LED lighting control software (such as ASUS Aura, Gigabyte RGB Fusion, MSI Command Center/Mystic Light, NZXT CAM, etc.). Please do not install multiple software at the same time, or the software may not work as intended. We are working to improve compatibility between the different software programs.
