- Ort
- Erde
- Desktop System
- Nase
- Laptop
- Dell Inspiron 17R SE
- AMD Ryzen 9 5950X
- Gigabyte X570 Aorus Master
- Wasser
- 4x Crucial Ballistix 16GB 3600 CL16
- RTX 3080 Ti Founders Edition
- Samsung GQ65QN95B
- Samsung SSD 970 EVO Plus 1TB
- be quiet! Silent Base 802 schwarz
- be quiet! Dark Power Pro 11 1000W
- Keyboard
- Logitech G915
- Mouse
- Logitech G703
- Windows 10 Pro
- Webbrowser
- Firefox
- Internet
- ▼200 MBit ▲10 MBit
Vielleicht ein ähnliches Problem:
Ryzen 5 2600 very high temperature. Help? - [Solved] - CPUs
Und nochmal, falls das untergegangen ist:
AMD Ryzen 7 2700X, 2700, 5 2600X 2600 im Test (Seite 6) - ComputerBase
- Offtopic -
Intel Core i7-2600K, 4x 3.40GHz (Fertigung: 32nm)
Intel Core i7-6700K, 4x 4.00GHz (Fertigung: 14nm)
Ist wohl auch kein Wunder.
I had this same exact issue last night installing the 2600X on my Gigabyte Aorus 5 Wifi x470. I booted the computer- everything worked great, updated the bios via gigabyte's software called @bios. rebooted- all looked well until i opened up CAM to change the LEDs on the NZXT x62 kraken. and saw i was running at 80C spiking up to 90C when opening up chrome. HW monitor showed the same high temps but ranging from 75-90C. I took off the cooler, reseated the CPU and re-applied thermal pastes from recommendations of the internet with no result. (AIO functioning fully). After getting frustrated i switched the bios back to the original bios via the Q-Flash and the temps went back to normal. Solid as a rock now.
Check which bios is available before that one (as long as it's post ryzen 2 release) and revert back to that. I would recommend not using @bios- download the bios file and put it only on a flash drive and update the bios by pressing DEL during the boot sequence for Q-Flash and install the bios that way.
If there is not a bios version pre-2nd gen ryzen release try clearing cmos and reinstalling most current bios via the DEL + Q-Flash method.
- Offtopic -
Mein 2600k wurde auch iwie bedeutend heißer als erwartet. Bei meinem Umstieg auf die berühmt berüchtigten TIM Intels habe ich schon schlimmes geahnt, der Schrecken blieb allerdings aus![]()
Das Ding (6700k) ist gefühlt thermisch nicht nennenswert schlechter als der 2600k (also bei gleicher Last laut coretemp erreiche ich vergleichbare Temperaturen).
