~ # /opt/hp/hpssacli/bin/hpssacli ctrl all show config detail
Smart Array P410i in Slot 0 (Embedded)
Bus Interface: PCI
Slot: 0
Serial Number: 500143800549FF60
Cache Serial Number: PACCQ9SXKAZZ
RAID 6 (ADG) Status: Disabled
Controller Status: OK
Hardware Revision: C
Firmware Version: 6.64
Rebuild Priority: Medium
Expand Priority: Medium
Surface Scan Delay: 15 secs
Surface Scan Mode: Idle
Queue Depth: Automatic
Monitor and Performance Delay: 60 min
Elevator Sort: Enabled
Degraded Performance Optimization: Disabled
Inconsistency Repair Policy: Disabled
Wait for Cache Room: Disabled
Surface Analysis Inconsistency Notification: Disabled
Post Prompt Timeout: 0 secs
Cache Board Present: True
Cache Status: OK
Cache Ratio: 0% Read / 100% Write
Drive Write Cache: Enabled
Total Cache Size: 256 MB
Total Cache Memory Available: 144 MB
No-Battery Write Cache: Disabled
Cache Backup Power Source: Batteries
Battery/Capacitor Count: 1
Battery/Capacitor Status: OK
SATA NCQ Supported: True
Number of Ports: 2 Internal only
Encryption Supported: False
Driver Name: HP HPSA
Driver Version: 5.5.0
Driver Supports HP SSD Smart Path: False
Internal Drive Cage at Port 1I, Box 1, OK
Power Supply Status: Not Redundant
Serial Number:
Drive Bays: 4
Port: 1I
Box: 1
Physical Drives
physicaldrive 1I:1:1 (port 1I:box 1:bay 1, SAS, 146 GB, OK)
physicaldrive 1I:1:2 (port 1I:box 1:bay 2, SAS, 146 GB, OK)
physicaldrive 1I:1:3 (port 1I:box 1:bay 3, SAS, 146 GB, OK)
physicaldrive 1I:1:4 (port 1I:box 1:bay 4, SAS, 146 GB, OK)
StorageWorks MSA 60 at Port 2I, Box 1, Not OK: Check device status detail
Fan Status: Failure
Temperature Status: OK
Power Supply Status: Redundant
Vendor ID: HP
Serial Number:
Firmware Version: 2.28
Drive Bays: 12
Port: 2I
Box: 1
Expander 250
Device Number: 250
WWID: 50014380067A7080
Port: 2I
Box: 1
Vendor ID: HP
Enclosure SEP (Vendor ID HP, Model MSA60) 248
Device Number: 248
WWID: 50014380067A70A5
Port: 2I
Box: 1
Vendor ID: HP
Model: MSA60
SEP: (1) 2.28
Backplane Module (BPM): (1) 2.06, (2) 2.06
Fan Control Module (FCM): (1) 1.08, (2) 1.08
Seven Segment LED Display: (1) 0.10
Physical Drives
physicaldrive 2I:1:1 (port 2I:box 1:bay 1, SATA, 2 TB, OK)
physicaldrive 2I:1:2 (port 2I:box 1:bay 2, SATA, 2 TB, OK)
physicaldrive 2I:1:3 (port 2I:box 1:bay 3, SATA, 2 TB, OK)
physicaldrive 2I:1:4 (port 2I:box 1:bay 4, SATA, 2 TB, OK)
physicaldrive 2I:1:5 (port 2I:box 1:bay 5, SATA, 2 TB, OK)
physicaldrive 2I:1:6 (port 2I:box 1:bay 6, SATA, 2 TB, OK)
Array: A
Interface Type: SAS
Unused Space: 0 MB
Status: OK
Array Type: Data
Logical Drive: 1
Fault Tolerance: 5
Heads: 255
Sectors Per Track: 32
Cylinders: 65535
Strip Size: 256 KB
Full Stripe Size: 768 KB
Status: OK
Caching: Enabled
Parity Initialization Status: Initialization Completed
Unique Identifier: 600508B1001CC221DF55388CA954F6AD
Logical Drive Label: A3333D25500143800549FF601005
Drive Type: Data
LD Acceleration Method: Controller Cache
Port: 1I
Box: 1
Bay: 1
Status: OK
Drive Type: Data Drive
Interface Type: SAS
Native Block Size: 512
Rotational Speed: 10000
Firmware Revision: HPD6
Serial Number: BS05P8C0SADN0851
Model: HP DG146BABCF
Current Temperature (C): 34
Maximum Temperature (C): 48
PHY Count: 2
PHY Transfer Rate: 3.0Gbps, Unknown
Port: 1I
Box: 1
Bay: 2
Status: OK
Interface Type: SAS
Firmware Revision: HPD1
Serial Number: BS01P8104HB10803
Model: HP DG146A3516
Current Temperature (C): 35
Maximum Temperature (C): 43
PHY Count: 1
Port: 1I
Box: 1
Bay: 3
Status: OK
Interface Type: SAS
Firmware Revision: HPDD
Serial Number: 3NM4E66B00009828WLKZ
Model: HP DG146ABAB4
Current Temperature (C): 31
Maximum Temperature (C): 70
PHY Count: 1
Port: 1I
Box: 1
Bay: 4
Status: OK
Interface Type: SAS
Firmware Revision: HPDC
Serial Number: 3NM63S4T00009848T7AZ
Model: HP DG146BB976
Current Temperature (C): 29
Maximum Temperature (C): 39
PHY Count: 2
Array: B
Interface Type: SATA
Unused Space: 0 MB
Status: OK
Array Type: Data
Logical Drive: 2
Fault Tolerance: 5
Heads: 255
Cylinders: 65535
Strip Size: 256 KB
Full Stripe Size: 1280 KB
Status: OK
Caching: Enabled
Unique Identifier: 600508B1001C407A415FA3255D952E9D
Logical Drive Label: A6C5DB74500143800549FF60662A
Drive Type: Data
Port: 2I
Box: 1
Bay: 1
Status: OK
Rotational Speed: 5400
Firmware Revision: 1AQ10001
Serial Number: S2H7J1EB201404
Model: ATA SAMSUNG HD204UI
SATA NCQ Capable: True
SATA NCQ Enabled: True
Current Temperature (C): 21
Maximum Temperature (C): 62
PHY Count: 1
PHY Transfer Rate: 1.5Gbps
Port: 2I
Box: 1
Bay: 2
Status: OK
Serial Number: S2H7J1EB201398
Current Temperature (C): 22
Maximum Temperature (C): 64
PHY Count: 1
Port: 2I
Box: 1
Bay: 3
Status: OK
Serial Number: S2H7J1BB129411
Maximum Temperature (C): 67
PHY Count: 1
Port: 2I
Box: 1
Bay: 4
Status: OK
Serial Number: S2H7J9AB101050
Maximum Temperature (C): 60
PHY Count: 1
Port: 2I
Box: 1
Bay: 5
Status: OK
Serial Number: S2H7J9AB100928
Maximum Temperature (C): 66
PHY Count: 1
Port: 2I
Box: 1
Bay: 6
Status: OK
Serial Number: S2H7J1BB129416
PHY Count: 1
Device Number: 248
Port: 2I
Box: 1
Vendor ID: HP
Model: MSA60
SEP: (1) 2.28
Expander 250
Device Number: 250
Port: 2I
Box: 1
Vendor ID: HP
SEP (Vendor ID PMCSIERA, Model SRC 8x6G) 249
Device Number: 249
Firmware Version: RevC
WWID: 500143800549FF6F
Vendor ID: PMCSIERA
Model: SRC 8x6G
Du hast viel geschrieben, was lobenswert ist, allerdings wurden ein paar Dinge ausgelassen, die für eine Fehlersuche essenziell sind:
- Was für ein Controller war im dedizierten Rechner?
- Was meinst Du mit "HDDs umgebaut"? Von internen Platten im dedizierten Rechner in die MSA60? Die MSA60 einfach nur vom dedizierten Rechner an den ESXi gehängt?
- Waren die SAS-HDDs schon immer in der MSA60 oder waren die auch im dedizierten Rechner? Auch hier wieder: an was für einem Controller hingen die?
- Wie ist die Schreibgeschwindigkeit auf dem SAS-RAID (ich gehe davon aus, dass beide RAID jetzt in der MSA60 stecken)?
Mal eine Frage hat jemand von euch schonmal ein Upgrade der vCenter Server Appliance von 5.5 auf 6.0 durchgeführt?
Mein Upgrade bricht immer mit "Es ist ein Fehler bei der Installation aufgetreten" ab. Die Logs sind nicht wirklich hilfreich.
Das einzige was mir seltsam vorkommt ist das der vpxuser während dem bereitstellen der Appliance versucht diese anzupassen was mit "Dieser Vorgang ist im aktuellen Zustand nicht zulässig" abbricht.
Und dann hätte ich noch ne freie 6 Kern Sandy für den zweiten Arbeitsplatz. Dort ist der X58 abgeraucht und im Moment nur ein uralt Pentium zur Verfügung. Und halt die ganzen Kleingeräte, die da laufen. Ich habe zwar kein Auto, bin aber (im Moment noch) Grossbezieher von Energie. Im 1 Mann Haushalt.Ich hätte da Mal eine Frage ...
Und zwar habe ich am ESXi (64 GB) zwei 4 Port Karten stecken.
Da das Ganze an der 3.2 kVA USV hängt, brauche ich aber echt zuviel Strom.
Im Moment bewege ich mich bei 600-700W im Idle
ESXI neuste genommen
Ähh ESXI läuft *g* wo kann man das sehen? *g*
vmware tools installiert ja
ich hatte nur Win10 laufen und hatte 100% innerhalb der VM
Win10 läuft nativ jedenfalls 100x schneller
Auch wenn es nicht ganz zum Sammelthread passt, hat jemand von euch die VCP6-DCV Prüfung gemacht?
Ich mache nämlich nächste Wochen den vSphere 6 Install, Configure and Manage Kurs und möchte die Prüfung in kürze angehen. Erfahrungen von anderen die den Weg schon hinter sich haben wären toll.
Hab jetzt seit 4 Jahre beruflich sehr viel mit vSphere zutun aber was man so über die Schwierigkeit der Prüfung liest![]()
Diese Foundation und die "echte" VCP6-DCV Prüfung.
Das ist schon ne Hausnummer für so nen blöden Zettel.
Hallo Batey, wie gesagt: Konsole oder RDP ändert nix an der Performance immer gleich 100% sobald ich ein Fenster bewege ...
deswegen habe ich auch ein Thread aufgemacht
Ich habe Win10 installiert und wollte Hyper-V benutzen .. kommt als Fehlermeldung das mein Prozessor SLAT nicht unterstützt
