[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Es gibt von ASUS neue BIOS-Versionen für einige Z68 Boards.
1. v1101 für P8Z68-V PRO (>hier<)
2. v0805 für P8Z68-V LE (>hier<).
Welchen Speicher habt'n ihr so in eurem P8Z68 stecken?
Ich möchte mir das ASUS P8Z68-V/GEN3 holen und bin auf der Suche nach einem guten Tipp bzw. Preis-/Leistungsverhältnis für 8GB. Angesichts der Auswahl-Möglichkeiten bin ich total überfordert und hab irgendwie keinen Bock mehr nach Testberichten zu googeln.
Welche Riegel habt Ihr Euch geholt?
Ich kann dir G-Skill empfehlen da ich selbst auf dem board habe und einwandfrei funktioniert :)
Im BIOS hat sich nen bissl was geändert: z.B. das hier:
attachment.php
Und die Option "VRM Spread Spectrum" ist weggefallen.
Neues BIOS 1101 für das V-Pro:
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1155/P8Z68-V_PRO/P8Z68-V-PRO-ASUS-1101.zip
Release Notes
[ 1101 ]
1. Improve system stability
2. Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc. -Support- CPU Support
Das hatte ich bereits heute Vormittag >hier< gemeldet.
Danke für die Ergänzung.
thx euch beiden
edit:
Bei mir steht da immer 0902 wäre das aktuellste Bios. Schaffe es selber nicht auf der Asus Seite auf euer Download zu kommen.
sagt mal kann das p8z68-v auch 3pin lüfter regeln, was ich im handbuch herausgefunden habe ist das 3 lüfteranschlüße (cpu,chassis 1+2) regelbar sind aber nicht ob die nur pwm oder auch 3 pin regeln ?
habe 2 scythe slipstream für meinen megahalems und 2 fürs gehäuse, alles 3pin lüfter, die jeweils über ein y Kabel an einem lüfteranschluß angeschloßen werden und zumindest auf meinem alten p55a-ud5 von gigabyte wurden die problemlos mit voltage geregelt und so bequem und leise hätte ich es auch gerne am neuen board
nur ist eben die frage ob ein asus z68 das kann mit 3pin lüftern ? alternative wäre ein asrock board oder wenn eventuell msi - gigabyte fällt raus
agree.
oder mal posten wie ihr da auf das 1101er bios kommt. dann kann man sich mal selber von der vertrauenswürdigkeit ein bild machen.
agree.
Vom ftp-Server von ASUS natürlich und damit vertrauenswürdig. Mit dem IE9 und Opera 11.52 funktionieren die in den Posts angegeben Links fehlerfrei.
Oh, auf dem ftp Server gibt es auch eine neue Version für das P8Z68-V PRO GEN3, 0402 vom 28.11. ...
Dann schaut doch mal auf dem FTP-Server von ASUS nach:
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1155/P8Z68-V_PRO/
Ist das vertrauenswürdig genug?
Die Fundstelle konntet Ihr übrigens bereits aus dem Download-Link ablesen, den ich verwendet hatte.
na klar hab ich gesehn dass der link von asus ist. ich meinte mit vertrauenswürdig eher ob die biosversion denn schon für die öffentlichkeit bestimmt ist. denn wie gesagt auf der normalen support seite ist die version noch nicht 'released'. ich weiß ja nicht ob vielleicht jemand auf der asus seite oder von einem asus mitarbeiter die info bekommen hat dass die uploads auf dem ftp-server 'final' sind oder vielleicht nicht. oder ob man diesen link vielleicht aus nem anderen forum hat wo es vielleicht noch infos gibt über die uploads, also warum die z.b. dort rumliegen und noch nicht auf die support seite eingepflegt wurden? einfach weil man noch nicht dazu kam? oder gibt es noch andere gründe? das hab ich eigentlich gemeint mit der frage 'wie ihr auf das 1101 bios kommt?'.
das der link bei mir auch funktioniert ist klar :d
Kann jemand helfen.
Ich habe das P8Z68 V Pro wenn ich meinen Rechner komplett ausschalte oder den Rechner runterfahre und ich ihn dann wieder einschalte startet er aber geht dann aus und dann wieder an und bootet.
Also er strtet imemr 2 mal kann man das ändern war vorher nicht so.
Woran liegt das denn.
ab bios 0706 gibt es keine doppelstarts mehr. oder im bios bclk auf 100mhz stellen. bekannte probleme und fixes stehen im eröffnungspost.
keiner ne ahnung mit der lüftersteuerung - habt ihr keine Lüfter ;) oder alles pwm :fresse: ?
"Auf der Platine des ASUS P8Z68-V Pro lassen sich sechs FAN-Header finden, wovon drei in 4-Pin-Bauweise ausgeführt sind. Für den bzw. die CPU-Lüfter sind zwei 4-Pin Anschlüsse vorgesehen. Weiterhin sind noch ein vier- und ein dreipoliger Chassis-Fan-Anschluss vorhanden. Diese vier Anschlüsse lassen sich über ASUS´ Q-Fan Lüftersteuerung gut konfigurieren. Der User hat die Wahl zwischen drei fertigen Kennlinien und einer manuellen Einstellung, wo Temperaturen und PWM-Signale selbst festgelegt werden können. Noch mehr Optionen bietet die Lüftersteuerung über die AI Suite II unter Windows. Weiterhin sind noch zwei Power-Fan-Anschlüsse in 3-Pin-Bauweise vorhanden, die allerdings nicht geregelt werden können."
Quelle: Hardwareluxx, Mainboard Test z68v-pro: http://www.hardwareluxx.de/index.ph...z68v-pro-mit-intels-z68-chipsatz.html?start=3
für das ohne pro gilt denk ich das gleiche. ob du jetzt von asus eine softwaresteuerung nimmst oder was anderes ala speedfan ist dir überlassen.
ich hatte selbst mit bios 0606 und BCLK auf auto nich nie doppelstarts
und wegen dem neuen bios seh ich das so änlich wie hi-tech. die daten auf asus` FTP server sind zwar mit sicherheit ok aber ich warte dennoch bis das 1101 für´s PRO auf dem public server gehostet wird und auch da werd ich denk noch ne woche warten. ich werds so machen nicht das es dort auftaucht und dann auf einmal steht das es ne beta is und warten werd ich allgemein wegen dessen stabilität obs wirklich gut rennt. nich das es wie ja schon geschehen wieder zurückgezogen wird.
ich bin da auch nur so vorsichtig weil seit es die boards gibt so viele leute mit allen möglichen bios versionen von kleineren problemen berichten und ich mit dem 0606 bis jetzt davon anscheinend weitestgehend verschont worden bin.
das einzige was ich bemängeln kann sind die hin und wieder auftretenden auslesefehler der spannungen und temps sogar in hardware monitor, was aber kein problem ist das sie nicht dauerhaft sind sondern wenn es kommt 1-2 sekunden angezeigt wird und dann wieder korrekt zurückspringt.
Verhalten nach Stromausfall
ich bräuchte nochmal einen Vergleich:
Im Bios gibt es eine Einstellung wie sich das System nach Stromausfall verhalten soll. Diese steht wohl standardmäßig so, daß er aus sein soll.
In meinem Fall P8Z68-V Pro (BIOS 0902 und 1101) geht der PC jedoch wieder an. Ich habe auch schon probiert, wie es sich verhält, wenn ich im Bios einstelle er soll wieder angehen (falls das im Bios vertauscht wurde). Hat aber ebenfalls nicht geholfen.
Ist das bei euch auch so? D.h. wenn Ihr den Netzstecker zieht während der PC läuft und ihr ihn dann wieder einsteckt läuft der PC ohne Einschalten mit dem Taster hoch?
Danke im Vorraus,
Leser
Hab extra mal für dich getest: BIOS 1101 -> Option steht auf "Power Off"
Ergebnis: wie bei dir fährt der Rechner hoch
weiß jetzt nicht ob ich richtig bin. Versuch aber meine dringenden Fragen hier los zu werden.
Board nagelneu Asus P8Z68-V Pro Gen3
CPU 2700K
Speicher G.Skill RipjawsX 1600
Lüfter Noctua D14
Netzteil 550W Corsair, Festplatten, SSD, Nvidia GTX460 alles vorhanden gewesen.
Prime95 lief eine Stunde . CPU Temp normal bei 25°C bei 4015 MHz geht’s bis auf 60°C
ebend nochmal mit Normal-Bios (Default F5)
Prime95 lief 3 minuten (Rechner eingefroren) CPU Temp normal bei 28°C 3600 MHz geht`s bis 52 °C
Die USB Tastaturen wollen nicht ins Bios. Genius USB geht garnicht. Logitech Usb jetzt nur noch sporadisch. Beim Booten kommt „NO Keyboard detected“ unter Windows gehen beide Tasten
Aber jetzt zum Hauptproblem.
Der Rechner friert sporadisch einfach ein. Nur noch Reset hilft. Man kann auch nicht sagen,… wann.
Einfach so,… mal früher mal später.
Bios eingestellt mit Asus TurboV EVO auf Auto-Tuning (Schnell) jetzt wieder auf Normal.
Welche von den drei Teilen könnte eine Macke haben,… was soll ich zuerst zurückschicken? OK der Noctua-Lüfter wird i.O. sein
Vielleicht hat jemand ein Tipp….
@Andy_20
Super. Danke fürs Testen. Ich werde mal schauen, ob im Asus Forum die Asus Mitarbeiter dies zwecks Korrektur an die Entwickler weitergeben.
also von den G-Skill F3-12800CL7D-8GBRH Ripjaws bin ich echt begeistert.
Gut, ich bin noch nicht lange dabei mit dem Z68 System aber das die Speicher so rasant arbeiten hätte ich nie gedacht.
Die laufen auf 1866 mhz, zwar erstmal mit 11-11-11-28 vom Board vorgegeben auf Auto, die sind aber dennoch schneller als mit 7-8-7-24 und mit 1600 mhz.
Überhaupt ist das System ne ganz schöne Umstellung wenn man von einem X38 Sockel 775 System kommt....
Anscheinend habe ich die LLC noch nicht ganz kapiert. Habe es auf regular stehen, aber dennoch geht die CPU manchmal auf 1,29 V hoch, das komische - die LAst ist dann noch nichtmal sonderlich hoch. Dann im Intel Burntest mit 8 eingestellten Cores, 4096 MB Speicher bleibt die Spannung ziemlich ruhig bei 1,23-1,24V.
Sieht man sich diesen Link genau an, stellt man durch den Verzeichnisnamen "pub" fest, das es sich um den Teil des ftp-Servers handelt, der für alle verfügbar ist. Natürlich kann es sich auch um ein Bios im Betatstatus handeln. Asus stellt solche Versionen aber nur dann zur Verfügung, wenn sie schon weitestgehend ausgereift sind, um sich nicht Ärger von unzufriedenen Usern auszusetzen.
Vielleicht habt ihr ja noch eine Idee, ich habe keine mehr.
Im Zuge meines wechsels auf das Asus P8Z68-V Pro habe ich Windows neu installiert.
Nun versuche ich seit geschlagenen 2 oder auch 3 Wochen die Intel AHCI Treiber zu installieren.
Hier der Zustand aktuell mit den Windows Treibern.
Lade ich nun den aktuellsten Treiber von der Intel Seite und installiere diesen, endet der anschließende Neustart immer in einem Bluescreen.
Auch mit den Treibern von Asus ist es genau das gleiche, immer endet es im Bluescreen und ich muss wieder den Standard Windows Treiber laden.
Wieso glaubst du das der Treiber von Windows ist? Der ist nur von Microsoft an Intel signiert. Wenn bei Treiberdetails der Treiber iastore.sys o.s.ä. steht und das System läuft, dann ist doch alles klar - der ist von Intel...oder verstehe ich dich nicht?
