[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Danke fürs prüfen Schrotti und rolex0815.
(http://www.hardwareluxx.de/community/17922504-post4040.html http://www.hardwareluxx.de/community/17922588-post4041.html).
Ich denke ich versuche mal eine Antwort von Asus zu bekommen.
Was auch nicht so ganz ok zu sein scheint ist die Reaktion nach Stromausfall. Obwohl das bei mir im BIOS so eingestellt ist, daß der PC nach einem Stromausfall aus sein soll geht er automatisch wieder an (z.B. wenn ich am Netzteil den Stecker ziehe während der PC an ist und den Stecker wieder stecke).
Nur soviel: Fehler war das keiner, das Board läuft problemlos mit 0902 und einem i7-2600k.
Bei dir hakt es an was anderes. CPU Sitz überprüft?
Sämtliche Steckverbindungen überprüft?
es muß einfach am Bios Flash liegen. Bis auf ein paar Kleingkeiten lief der Rechner eigtl. vorher astrein.
Ich habe nichts anderes getan als von der Asus Seite für´s P8Z68-V das 902 Bios runter zu laden zu entpacken und nach einem Neustart im Bios unter Anwendungen per EZ Flash das 902 drüber zu bügeln. Hat das Board ja auch anstandslos gemacht 100% oder so hat´s angezeigt.
Overclocked war´s auch nicht (Automode war da eingestellt). Geprüft mit Intel Burntest 2.x hatte ich den REchner vorher ja auch schon (8 Runden) -> keiner Fehler .......
Ich hätte es ja auch mit AI Suite2 o.s.ä unter WIN7 geflasht, hatte die Suite aber kurz vorher deinstalliert, weil sie 2 mal bei einer Image sicherung (SSD System Partion. zu einer eSata Platte) abgestürzt ist. Ich wollte eigtl nach dem Bios Flash gucken ob´s eine neue Version von der Ai Suite auf der Asus Seite gibt- neuer als die CD Installation halt.
Nun ja ich kann nur sagen, daß mit dem 0706er alles paletti war, deshalb halte ich es selbst für eine nicht notwendige Aktion das 902er zu flashen kurz ich halte es für einen Fehler.
Ich habe neben der Neubestellung des Boards ( ich will so schnell wie nur möglich ausschließen, daß die CPU einen Mitbekommen hat) den Asus Support angeschrieben mit der Bitte mir 2-3 Bios Chip (als Ersatz) zu schicken. Meinetwegen gegen BEzahlung.
Aber dazu später.
Neue, andere Ideen sind immer Willkommen - Danke!
Müßte beim Offset Mode die CPU nicht runter takten? Bei mir bleibt sie grad immer auf volle Power, also 3900. Sie müsste doch im idle runtertakten!
Das hat aber AFAIK nichts mit dem Offset Mode zu tun. Diese Dinge stellst du über den AI Tweaker ein und wichtig sind auch Speedstep, C1/3/6 States.
Mit den angehängten Screenshots läuft er unter Last auf 4,4 GHz und geht im Idle brav auf 1,6 GHz runter.
Hallo an alle hier und besonders die Experten.
Ich hoffe sehr, dass hier jemand so freundlich wäre und mir helfen könnte. Ich habe massive Probleme mit dem Bluetooth Modul des P8Z68 V Pro MoBos.
Mein System:
Windows 7 64 bit
inkl. SP1 und allen Updates bis heute
650 W BeQuiet Netzteil
500 GB Festplatte
1 LG Bluray Laufwerk
470 GTX Graka von Point of View
Meine Einstellungen im Mobo:
Alles auf Standard, Bios ist Version 0902 (die neuste bei der Asus Homepage)
Treiber:
Die neuesten von der Asus Hompage (speziell Atheros Bluetooth Driver Version 7.2.0.65, habe aber auch den Treiber der DVD probiert und auch den neuesten mit Version 7.4. irgendwas, ganz egal, bringt alles nichts).
Mein Problem:
Mein neu installiertes Windows findet alle meine Bluetooth Geräte, kann sie pairen und zeigt sie an. Aber bei den Lautsprechern, Headsets gibt es massive Aussetzer, die HP Bluetooth Tastatur reagiert nur beim Pairen auf die Tasteneingabe, sonst nicht).
Ich habe alle Atheros Treiber durchprobiert, zusätzlich habe ich Asus Bluetooth Go installiert, der findet meine BT-Hardware auch und ebenfalls kann er alle Funktionen dafür konfigurieren.
Und, ja, meine BT-Harware funktioniert einwandfrei unter Vista 32bit, XP 32bit, mit meinem PocketPC Windows Mobile 5, mit meinem Palm Pre ebenfalls. Ich hatte im Leben noch nie so heftige BT-Probleme.
Ich habe mittlerweile herausgefunden, dass es irgendwie an der Installationsreihenfolge und der anschließenden Verwendung von BT Go und dann dem Pairen mit Windows liegen könnte, dass es zufällig funktionieren kann, dass meine Musik ohne sekundenlange Aussetzer über die Lautsprecher oder das Headset abgespielt werden kann.
Einmal habe ich es hinbekommen. Da wurde die Signalstärke unter Windows mit 4 Strichen (von 5) angezeigt. Dann habe ich meine HP-Bluetooth Tastatur über BT verbunden, sie funktionierte nicht (nein, ein Treiber wird nicht dafür angeboten), dann habe ich das Gerät entfernt. Diese Aktion hat wieder zu meinen BT Problemen mit massiven Aussetzern bei der Tonwiedergabe geführt. Und der Signalstärke von 2-3 Strichen von 5 (sichtbar unter Windows am jeweiligen Gerät).
Okay. Ich habe mein Windows 7 also neu aufgesetzt. Treiber von CD installiert (Mein Gedanke: vielleicht geht ja DER). Aber nein.
Die Bluetoothverbindung ist extrem instabil.
Mein BT ist im EFI aktiviert. Die Geräte werden alle ohne Probleme erkannt. Ich habe die neuesten Treiber und auch den älteren von der DVD probiert. Mein BT Modul im Motherboard ist nicht defekt, denn durch Zufall hat es einmal richtig und ohne Aussetzer funktioniert, da hatte ich zuerst über BT Go gepairt und dann über Windows, habe es aber nicht wieder hinbekommen. Mein MoBo war zu dem Zeitpunkt von "Normal" auf "Turbo" gesetzt, ist das wichtig? (Systemwiederherstellung bringt leider auch nichts, schon probiert). Meine Geräte funktionieren unter Vista ohne Probleme, die Batterien sind voll. Mein System wurde komplett neu installiert. Das Problem bestand weiterhin.
Ich versuche seit 2 Wochen (da habe ich das Board gekauft, einfach so zurückschicken geht also nicht mehr) jeden Abend für 2 Stunden, mein BT zu verwenden und Spiele zu spielen oder Musik zu hören, ohne das die BT Verbindung extrem laggt.
Mir ist aufgefallen, dass nach einer Wiedergabeunterbrechung die Musik extrem schnell abgespielt wird, so als ob sie sich "angestaut" hätte und dann in der kurzen Zeit der Wiedergabe schneller abgespielt wird, weil die Übertragung nicht "hinterher kommt".
Ich weiß mir wirklich nicht mehr zu helfen und möchte Euch jetzt gern um Hilfe bitten, denn ich kann einfach nicht mehr. Ich weiß nicht mehr weiter.
Ein Anruf bei Asus hat nicht weitergeholfen, sie meinten, ich solle die neueste Atheros BT Driver Version installieren (Version 7.04. nochwas, hab ich jetzt leider nicht parat, ist aber die neueste) und am MoBo für die CPU nicht nur 1 Stromstecker sondern alle beide anzuschließen, weil die CPU sonst "underpowered" sein könnte.
Hat alles nichts geholfen.
Ich habe hinten in der Nähe des BT Moduls, falls das wichtig ist, einen WLAN-Stick "LWUK12 TP-Link TL-WN821N(DE) 300/USB2/ 11n" mit 2,4 Gigaherz eingesteckt.
Wärt Ihr so nett und könntet mir mal antworten? Ich habe schon bei Google gesucht wie ein Verrückter und es gibt nicht viele Hinweise. Auch nicht in diesem Thread, den ich schon durchsucht habe.
Ich wäre so dankbar über Eure Hilfe.
Grüße
Sven
Du bist nicht der erste hier mit BT problemen bei diesem board, inkl mir. Habs dann aufgegeben und im EFI deaktiviert und meinen alten BT Stick genutzt, so ein stick bekommt man ja schon für 5 euro.
Danke für Deine Rückmeldung Phantom2k.
Dann kann ich das Board nicht weiterempfehlen und es gehört eigentlich an Asus zurückgeschickt. Ich habe es mir ja nicht inkl. Bluetooth-Modul gekauft und dafür Geld bezahlt, um mir dann nochmal nen BT-Stick zu kaufen.
Dabei geht es mir nicht um die zusätzliche Ausgabe von 5€ als vielmehr ums Prinzip.
Hat echt niemand ne Lösung gefunden?
Offset ist der Wert wie die Spannung sich zur Standardspannung des CPUs verhält. Es hat also rein gar nichts mit der Taktung des CPUs zu tun.
Schau mal nach den CPU-Einstellungen (CPU-Config), scheint so als ist sowas wie C1, Turbo Mode oder Intel Speedstep bei dir deaktiviert.
Jo, danke. Bei mir war C1/3/6 deaktiviert. Und der OffMode ist die Regelung der VCore.
---------- Beitrag hinzugefügt um 16:53 ---------- Vorheriger Beitrag war um 16:46 ----------
Deine Einstellungen schau ich mir genau daheim an. Thx
Salve,
Rechner läuft wieder, das Ersatzboard ist eingebaut - wieder ein P8Z68-V (wieso eigtl. :confused:).
Anscheinend hat der Bios Flash über das EZ Flash Tool im Bios nicht gefunzt.
Keinen CPU Fehler (CPU LED leuchtet nur kurz beim Satrt) mit dem 2. Asus- also muß die CPU i.O. sein.
Nun würde mich echt interessieren wie ihr flasht. Im Windows mit dem Asus Tool ? Klassisch mit Dos Diskette (wenn das überhaupt mit den neuen Boards geht)? oder über das EZ 2 Flash.
Ach ja, hätte nicht damit gerechnet, aber Windows 7 mußte neu aktiviert werden -wahrscheinlich weniger wegen dem Board, aber mir ist gerade noch eingefallen der LAN Port hat ja eine andere MAC Adresse.........
Und flashen werde ich erst wieder wenn ich genau weiß was da abgegangen ist...
Ich nutze immer den im (EFI-)Bios eingebauten Flasher. Habe damit bisher bei keinem Board (P5K-E, P5Q-E und 2x P8Z68-V) Probleme gehabt. Du kannst bei dir also von einem Einzelfall ausgehen.
ich habe gerade selber das Herstellerforum wiedergefunden. Dort gibt es auch direkten Support von Asus:
ASUS - Forum de Luxx
Vielleicht bekommst Du dort noch einen Tip.
Okay , danke für die Rückmeldung. Ich habe mein altes DFI X38 immer geflasht (Dos Diskette) ,davor das Lanparty mit dem P Chipsatz und davor das ICFX mit der AMD SB 600, aber sowas ist mir noch nicht passiert....
ICh warte mit dem 706er flashen noch bis ich Rückmeldung von Asus habe ( Will mir ein paar BIos Chips auf Halde legen) :fresse:.
Wieso willst du das 0706er flashen? Das 0902er läuft auch auf Sandy Bridge CPUs einwandfrei.
Nun, das hatte wenigstens beim ersten P8 Board schonmal geklappt, wenn auch unter Windows....ich warte aber noch.
Wie ist das eigtl. Zwischensteps brauchen nicht mehr geflasht zu werden richtig?
Man kann also (wenn) dann sofort das 902er nehmen?
thx
---------- Beitrag hinzugefügt um 22:13 ---------- Vorheriger Beitrag war um 21:54 ----------
Mensch was ist das denn nun wieder für ein Mist ????? Wieso bekommt man nun ein 801 angeboten :hmm:
Nee ich lass erstmal komplett die Finger davon......
Sers,
hab 2x 60GB SSD´s und ein paar schnelle Platten.
Kann ich damit 2x SSD-Caching machen?
MFG
Wo habt ihr eure System SSD angestöpselt:
- SATA 6Gb/s port(s), gray
- Marvell® PCIe SATA 6Gb/s controller :
- SATA 3Gb/s port(s), blue
Der Marvell Anschluss soll ja nach dem Kurz Review von Pinky langsamer sein.
Hallo Zusammen,
habe heute Antwort vom Asus Support Ratingen bezgl. Bios Chip erhalten.
Leider kann man den wohl von dort nicht erhalten.
2-3 Links waren dabei....
Zitat:
"1. Bios Baustein per Eprombrenner neubeflashen ( z.B. BIOS Kompendium © - Startseite)
2. Neuer Biosbaustein -> asus.ALTERNATE.de Shop im Shop / www.bios-info.de"
Im Bios Kompendium ist der Hausflasher erkrankt und erst Ende 2011 wieder zurück..und unter dem Alternate Link sind nur uralt Sockel und deren Chips aufgeführt......sehr sinnig....
Ich meine hier gelesen zu haben, daß ein paar P8 User irgendwo her einen bekommen haben. Können die mir bitte mitteilen woher ? Danke.
Für den Fall, dass Du mich meinen solltest:
Nachdem ich nach einem gescheiterten BIOS-Flash nicht einmal mehr ins BIOS kam und alle Versuche, das Mainboard wieder zum Leben zu erwecken, gescheitert waren, hat mir der ASUS Support damals angeboten, den kompletten BIOS-Baustein auszutauschen. Das hat auch wunderbar geklappt.
Welche BIOS Methode habt ihr verwendet, damit wir die Finger davon lassen? Oder besteht der Fehler nicht mehr?
Bei Windows 7 noch in den erweiterten Energie-Optionen den minimalen Leistungszustand des Prozessors auf 0% stellen und den maximalen bei 100% belassen. Nach dem Übernehmen lässt sich das automatische Runtertakten dann auch live mit dem IntelCore-Gadget von Orbmu2k beobachten. :wink:
Okay, danke soweit, aber dazu hast du das Board eingesendet richtig ?
Mit welcher Bios Version (Chip oder Board) wurde repariert?
Darf ich noch erfahren wie du geflasht hast bevor es abgeraucht ist und welche Bios Version drauf sollte?
Ich nutze Bluetooth zwar auch, aber nur zur Synchronisierung des Handy's - da gibt es keine Probleme. Die Reichweite ist zwar eher schwach vom Modul (ein billig Stick von Conrad um ein paar Euro konnte deutlich mehr) aber funktionieren tut's.
Ich würde auf BT-GO und ähnliches Zeugs verzichten und nur die neuesten Atheros Treiber (Bluetooth Suite) installieren.
Zu finden ist die neueste Version 7.4.0.100 hier: Atheros & Zidas drivers
Zusätzlich würde ich testweise das WLAN Modul räumlich entfernt vom BT Modul einstecken. Da beide im gleichen Frequenzband unterwegs sind (BT nutzt zwar frequency hopping) kann man gegenseitige Störungen nie ganz ausschließen.
---------- Beitrag hinzugefügt um 12:58 ---------- Vorheriger Beitrag war um 12:55 ----------
BIOS von der Herstellerseite runterladen und übers EZ Flash im BIOS updaten.
Hab ich seit ich das Board besitze schon 6x so gemacht. Nie Probleme gehabt. Du kannst wie schon geschrieben von einem Einzelfall oder Pech :heul: ausgehen.
Wenn ich das mache zeigt er mir Werte zwischen 800 und 8000MHz an und springt immer hin und her.
