Willkommen im Sammelthread zum ...
ASUS MAXIMUS IV GENE-Z
Layout:
weitere Bilder:
Spezifikationen:
Backpanel:
1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
2 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0 (white port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
6 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x ROG Connect switch(es)
1 x Go Button(s)
1 x Clear CMOS jumper(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
1 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x Cable ties pack(s)
1 x ROG theme label(s)
1 x 12 in 1 ROG Cable Label(s)
1 x HDMI
2 x eSATA 3Gb/s
2 x USB 3.0
6 x Audio jack(s)
OnBoard-Anschlüsse:
1 x System panel(s)
1 x Reset button(s)
1 x Go Button(s)
Lieferumfang:
User's manual
I/O Shield
1 x SLI bridge(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Maximus IV GENE-Z Deutsches Handbuch Version G6731
+ Maximus IV GENE-Z BIOS 3305
For proper operation, please ensure to update Intel Rapid Storage Technology driver to version 10.8.0.1003 and BIOS to version 3305 before enabling Intel Smart Response Technology.
Update procedure for users needing Intel Smart Response Technology:
(1) Enter OS, and ensure Intel Smart Response Technology has been turned off under Intel Rapid Storage Technology interface.
(2) Install version Intel Rapid Storage Technology driver to version 10.8.0.1003.
(3) Reboot the system, and update BIOS to version 3305, then reboot.
(4) Enter the BIOS setup screen, press F5 to load BIOS default, then change the Intel SATA Port to RAID mode.
(5) Boot into OS, and re-enable Intel Smart Response Technology under Intel Rapid Storage Technology.
+ Maximus IV GENE-Z 0902 Offizielles Beta Bios Datum 19.09.2011
+ Maximus IV GENE-Z 0706 Offizielles Beta Bios Datum 16.08.2011
+ Maximus IV GENE-Z 0403 Final Bios mit IRST 10601002
+ Maximus IV GENE-Z 0208 First release Bios
+ Maximus IV GENE-Z 0650 Beta Bios
+ Maximus IV GENE-Z 0604 Beta Bios
+ Maximus IV GENE-Z 0603 Beta Bios
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.2.0.1030 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V7.1.14.1107 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V7.1.20.1119 XpVistaWin7
+ Treiber SATA: Intel® Rapid Storage Technology Version: 10.6.0.1022 Datum: 08.06.2011
+ Treiber SATA: Intel® Rapid Storage Technology Version: 10.8.0.1003 Datum: 11.11.2011
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.62.0 WHQL XpVistaWin7
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.63.0 WHQL XpVistaWin7
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.63.0 WHQL eSata XpVistaWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.1.0.0 WHQL XpVistaWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.7.0.0 WHQL Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.7.0.0 WHQL Win7 64-Bit
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.10.0.0 XpVistaWin7
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.14.1.0 XpVistaWin7
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.14.2.0 XpVistaWin7
+ Treiber Video: Intel(R) Graphics Accelerator Driver V8.15.10.2372 WHQL VistaWin7
+ Treiber Video: Intel® HD Graphics Driver 8.15.10.2462 VistaWin7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 8.15.10.2462 VistaWin7 64-Bit
+ Treiber Video: Intel® Graphics Media Accelerator Driver 15.22.50.64.2509 VistaWin7 64-Bit
+ Treiber Video: Intel® Graphics Media Accelerator Driver 15.22.50.32.2509 VistaWin7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.106 09.08.2011 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.106 09.08.2011 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.108 Win7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6363 & 6.0.1.63 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows Vista & Windows 7
+ ASUS AI Suite II V1.01.30 Install Program XpVistaWin7
+ ASUS AI Suite II V1.01.40 Install Program XpVistaWin7
+ ASUS AI Suite II V1.02.11 Install Program XpVistaWin7
+ ROG CPU-Z V1.58 Setup
+ ROG CPU-Z V1.58.4 Setup
Besonderheiten:
Reviews:
ASUS Maximus IV Gene-Z LGA1155 Review | techPowerUp
ASUS Intel Z68 ROG Maximus IV Motherboard Reviews | legitreviews.com
ASUS Maximus IV Gene-Z Motherboard Review | tbreak.com
Asus Maximus IV Gene-Z Motherboard Review | ninjalane.com
ASUS Maximus IV Gene-Z - Artikel | Hartware.net
Asus Maximus IV Gene-Z Motherboard review (mATX) | KitGuru.net
ASUS Maximus IV Gene-Z Review - Mainboards - Reviews | ocaholic.ch
ASUS Maximus IV Gene-Z Review | Overclock3D.net
ASUS RoG Maximus IV Gene-Z Motherboard Review | hardwareheaven.com
ASUS Maximus IV Gene-Z review | hardwareheaven.com
ASUS Maximus IV Gene-Z (Intel Z68) mATX Motherboard Review | TweakTown.com
Asus Maximus IV Gene-Z Review | bit-tech.net
Asus Maximus IV Gene-Z Intel Z68 and Asus Matrix GTX 580 Platinum Review | whatswithjeff.com
Weitere Infos und nützliche Links:
- Welcome to Republic Of Gamers! - Maximus IV GENE-Z
- TEST || ASUS MAXIMUS IV GENE Z
- Vorstellung im ROG Community Forum
- ROG Community Blog: Weapon Drop Inbound
- Official ASUS Maximus IV Gene-Z Motherboard Unboxing
- Video COMPUTEX 2011: ASUS ROG Maximus IV GENE-Z Z68 Motherboard
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Corsair Vengeance Rot 8GB DDR3-1600 CL9-9-9-24 (CMZ8GX3M2A1600C9R) @ 1333 7-7-7-19
G.Skill RipJaws-X 8GB DDR3-1333 CL7-7-7-21 (F3-10666CL7D-8GBXH) @ 2133 11-11-11-30|1866 9-10-9-28|1600 8-8-8-24|1333 7-7-7-21
G.Skill RipJaws-X 8GB DDR3-1600 CL9-9-9-24 (F3-12800CL9D-8GBXL) @ 1600 9-9-9-24
G.Skill RipJaws-X 16GB DDR3-2133 CL11-11-11-30 (F3-17000CL11Q-16GBXL) @ 2133 10-11-10-27 1T
Mushkin Enhanced Blackline Frostbyte DDR3-2133 CL10-11-10-28 (994015) @ 2133 10-11-10-27 1T | 1866 9-10-9-27 1T
1067 MHz | 8-8-8-24-1T | 1.563V | 2x2GB SuperTalent Chrome 2000 C8 | Elpida Hyper | P67 | websmile | Screen
1067 MHz | 8-8-8-24-1T | 1.575V | 2x2GB Corsair Dominator GT 1866 C7 | Elpida Hyper MGH-E| P67 | websmile | Screen
1130 MHz | 7-9-7-21-1T | 1.613V | 2x2GB G.Skill RipjawX 2133 C8 | Elpida BBSE | P67 | websmile | Screen
Kompatibilität CPU Kühler:
+ Corsair H60 (Hersteller-Link)(Foto von Emiras)
+ Corsair H70 (Hersteller-Link)
+ be quiet! Dark Rock Advanced C1 (Hersteller-Link)
+ be quiet! Dark Rock Pro C1 (Hersteller-Link) (Foto)
+ EKL Alpenföhn Brocken (Hersteller-Link) (Foto von Emiras)
+ Noctua NH-U9B SE2 (Hersteller-Link)
+ Noctua NH-D14 (Hersteller-Link)
+ Noctua NH-U12P SE (Hersteller-Link)
+ Noctua NH-C12P SE14 (Hersteller-Link)
+ Noctua NH-C14 (Hersteller-Link)
+ Prolimatech Megahalems (Hersteller Link)
+ Prolimatech Super Mega (Hersteller-Link)
+ Scythe Mugen 2 Rev. B (Hersteller-Link) (FOTO) mit SCURK-3000 oder Backplate-Mod
+ Scythe Ninja 3 (Hersteller-Link)
+ Thermalright Venomous-x (Hersteller-Link)
+ Thermalright HR-02 (Hersteller-Link) (Foto von Stullen Andi)
+ Thermalright HR-02 Macho (Hersteller-Link) mit Thermalright Macho Asus Bolt-Thru Kit
Swiftech Apogee XT (Preisvergleich)
Overclocking Ergebnis:
CPU-Z Validator 3.1
ASUS Maximus IV Gene-Z + 2500K
werde aber weiter testen was noch möglich ist.
