[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Also ich hatte und habe die Version 7.0.0.1144 drauf beim Treiber. Das is die neueste die ich finde für die 6er Chipsets. Passt ja, oder?
Na klar. :d
Aber der hier ist lt. Bezeichnung ja wohl auch ein neuerer Treiber?
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20261&keyword=%22%09Intel+Management+Engine%22&OSFullname=Windows+7*%2c+64+Bit&lang=deu
.....manchmal glaube ich Intel hat im eigenen Download-Center selbst keinen Durchblick mehr?
@all
Habt ihr das hier mal gesehen bzw. ausprobiert?
http://downloadcenter.intel.com/Det...eu&OSVersion=Windows 7*, 64 Bit&DownloadType=
:confused::(
Hier mal eine Liste (Stand Aug.2011) über die bisher erschienenen Intel ME-Tools für den 6er Chipsatz:
Auch wenn man den neuesten ME-Treiber installiert ist der immer von 2010.
Ich installiere immer nur den Chipsatztreiber mit -OVERALL und dann habe ich einen Management Engine Treiber von 04/2011 drin ;)
Die Firmware kann man immer flashen, die hat mit dem Treiber nichts zu tun !
Asus hatte immer nur die ME-Firmware von Februar drauf und deshalb habe ich auf die Neueste von August geupdatet !
Sie zählen zwar die Versionsnummern von diesem MEI_allOS Paket hoch, der Treiber hat jedoch bei 3 dieser Pakete immer das gleiche Versionsdatum vom Oktober 2010. Das mit den unterschiedlichen Versionen im Intel DL Center ist mir auch schon aufgefallen. :)
So ein ME Info Utility ist schon bei dem Paket von Waxman (Gigabyte HP) dabei, zu finden unter:
Code:
CPT_1.5M_7.1.20.1119\Tools\System Tools\MEInfo\Windows
Die Ausgabe von dem Ding bringt bei mir:
Code:
Intel(R) MEInfo Version: 7.1.20.1119
Copyright(C) 2005 - 2011, Intel Corporation. All rights reserved.
Intel(R) ME code versions:
BIOS Version:                           0706
MEBx Version:                           Not available
Gbe Version:                            1.3
VendorID:                               8086
PCH Version:                            5
FW Version:                             7.1.20.1119
UNS Version:                            Not Available
LMS Version:                            Not Available
MEI Driver Version:                     7.1.20.1056
Wireless Hardware Version:              Not Available
Wireless Driver Version:                Not Available
FW Capabilities:                        17828928
    Intel(R) Capability Licensing Service - PRESENT/ENABLED
    Intel(R) Dynamic Application Loader - PRESENT/ENABLED
CPU Upgrade State:                      Upgrade Capable
Cryptography Support:                   Disabled
Last ME reset reason:                   Power up
Local FWUpdate:                         Enabled
BIOS and GbE Config Lock:               Disabled
Host Read Access to ME:                 Disabled
Host Write Access to ME:                Disabled
SPI Flash ID #1:                        EF4017
SPI Flash ID VSCC #1:                   20052005
SPI Flash BIOS VSCC:                    20052005
BIOS boot State:                        Post Boot
OEM Id:                                 00000000-0000-0000-0000-000000000000
OEM Tag:                                0x00000000
Ja ja nix mit dem Treiber zu tun, deshalb konnte ich die erst nach dem Install des alten Treibers flashen. :haha: Das magst du glauben, ich jedenfalls nicht.
Nutzt hier jemand 6GB/s Raptoren am Marvell im RAID0?
Ist es normal das die nur 200MB / Sek. schaufeln average und recht häufig Einbrüche auf bis zu 0.1MB runter :( haben?
Ist das am Intel Controller besser?
Da hängt bloß eigentlich eine SSD dran, wenn der Controller also in den RAID Modus versetzt werden muss, hat das keine Nachteile für die SSD?
Ich habe zwei Raptoren (aber nur S-ATA IIer) am Intel hägen im RAID0, der SSD macht das gar nix aus, da im RAID-Modus alle Intel-Ports auf AHCI laufen.
@Labrador: Ich habe auch unter Dos geflasht, da geht es immer.
Ich halte nichts von diesen Windows Flashprogrammen !
Für die Mutigen unter den 6er-Boards Nutzern:
der ME Alpha-Treiber ..1056 ist überhohlt, für Boards mit dem 7er-Chipsatz hat Intel einen neuen ME-Treiber veröffentlicht:
7.1.21.1134
Viel Spaß ;)
Hallo, ich überlege mir eines der hier behandelten Boards mit einem 2500k zu kaufen und wollte fragen wie es offiziell mit der Unterstützung der nächsten Generation von Intel CPUs aussieht.
Kann bei Asus nichts konkretes finden. Da gibts nur dürftige Informationen zu PCIE3, was mich aber nicht so interessiert.
Warte auf die GEN3 Boards,die unterstützen Ivy Bridge auf jeden Fall. Die werden in den nächsten Tagen bei den Händlern gelistet sein.
ASUS P8Z68-V/GEN3
ASUS P8Z68-V PRO/GEN3
ASUS P8Z68 Deluxe/GEN3
Der Alpha-Treiber 7.1.20.1056 war auch nicht für unsere Boards, trotzdem wurde er - wie in diesem Forum zu lesen war - installiert.
Der 7.1.21.1134 ist der ebenfalls für den 7er-Chipsatz gedacht, trotzdem wird er auf unseren Boards installiert werden. Wetten...
Übrigens habe ich den Treiber zum Test gestern installiert, bis jetzt läuft mein Rechner bestens.
ja installiert hat er sich auch bei mir nur die frage ist
warum installiert er sich obwohl er nicht für unser board ist
ist er überhaupt optimiert für unser board?
Okay ich denke mit dem Treiber verhält es sich wie beim Chipsatztreiber.
Der läuft auf jedem Intel, die Frage ist nur wie?
Einen Treiber kann man immernoch im Gerätemanager löschen, aber ne Firmware für den Intel7 würde ich absolut nicht flashen..........
Das sehe ich genauso. Den Chip7-Treiber habe ich vorhin wieder entfernt und den 7.0.0.1144 aufgezogen. Hatte heute Morgen einen Aussetzer, angeblich wars der Nvidia-Treiber und Firefox.
Vor dem Treiberwechsel und seit M4 hatte ich diese Aussetzer nicht mehr.
Hallo Kollegen,
auf der ASUS Seite ist ein neuer USB 3.0 Treiber für unsere Boards verfügbar.
Der nennt sich ASUS USB 3.0 boost und soll eine Beschleunigung für USB 3 Geräte bringen. Starten muss man das Tool über die AI Suite (die läuft bei mir nicht, also kann ich das Tool nicht testen).
Ist das was Neues, hab noch nie davon gehört?
Wenn man den Treiber entpackt, liegt ein PDF bei mit den nötigen Erklärungen.
Hallo Zusammen, hab mir jetzt erspart 91 Seiten durchzulesen. Bei mir hängt sich die Maus und manchmal zusätzlich noch die Tastatur auf. Dass der Zeiger langsamer wurde ist mir auch schon passiert.
Auf der ersten Seite steht. USB 3.0 Port verwenden. Das probier ich jetzt mal, oder gibts noch andere Möglichkeiten? Oder geht vielleicht meine Maus kaputt?
Vielen Dank!
Nur für den ASMedia USB3.0 Controller, nicht für den NEC USB 3.0 Controller (P8Z68 Dlx) geeignet.
Danke, scheint wohl als ob es 902 ersetzen wird :d 902 ist ja auch Beta :d
Die 902 bleibt jetzt erst mal drauf solange die stabil läuft. Außerdem ist mir das downgrading über das DOS Flash Tool zu umständlich hab ich keine Lust zu ;)
hab noch das 0606 das ganz gut rennt. hab heut die ME-Firmware geflasht und der nächste bios flash wird denk die nächste final die "support for Next Gen 22nm Processor" hat. bin so ganz zufrieden und von so gut wie allen bisherigen problemen verschont geblieben. die temps sind denk so ok, war anfangs nur etwas verwirrt da meine letzten systeme alle AMD waren und die gelegentlichen wirren angaben der spannungen, temps und rpm´s der lüfter sind wohl wirklich auslesefehler. das asus tool hat ja eh voll einen weg. fands nur etwas seltsam das bei mir das tool hardware monitor auch diese auslesefehler hat, aber nur für ne sekunde, danach is wieder ganz normal.
Habe von 0606 auf 0801 geflashed. Danach wurde auf default zurück gesetzt und ich musste alles neu einstellen. D.h. ich muss kein CMOS-Reset mehr machen oder die Defaulteinstellungen im BIOS auswählen?
Das Speichern der BIOS-Screens ging trotz eingestecktem USB-Stick nicht (USB 3.0 Front, es ist kein USB flash drive vorhanden oder so ähnlich, heißt es), ich hatte meine Einstellungen daher vorher alle abfotografiert.
Mit genau den gleichen Einstellungen bekomme ich jetzt beim Booten einen CPU-FAN Error, obwohl ich die Überwachung disabled habe :kotz:
Den habe ich vorher nie gesehen. Habe da auch nix angeschlossen wegen Wakü.
Konnte den Fehler jetzt nur dadurch abstellen, dass ich die Lüfterüberwachung enabled habe und die Drehzahl auf ignore.
