[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Nein, wenn er nur transcoding benutzen will kann er auch das Deluxe nehmen.
Erst mal CMOS Reset durchführen und die defaults laden. Dann alles was mit Stromspar und Runtertakten zu tun hat aktivieren. ;)
Danke, genau das war's.
Taktet nun wieder schön runter.
Noch eine Information:
Wie ich in http://www.hardwareluxx.de/communit...-deluxe-intel-z68-810782-18.html#post17023895 geschrieben hatte, traten diese Hänger bei mir nie auf.
Nun habe ich die SSD (vorher Corsair Force Series 60GB, 2.5", SATA II, CSSD-F60GB2-BRKT) gegen eine Corsair Force Series GT 120GB, 2.5", SATA 6Gb/s (CSSD-F120GBGT-BK) getauscht und die Hänger waren prompt da. Erst das Deaktivieren des LPM hat bis jetzt mal Abhilfe gebracht.
hab alle Einstellung unter dem Punkt siehe Bild durch...
Kann es sein, dass der folgende Arbeitsspeicher..
.. mit dem P8Z68 Deluxe nicht vollkommen kompatibel sind?
Auf der ersten Seite steht dieser RAM jedoch als "konform" für das P8Z68-V.
Hatte den Q-Code 06 Microcode loading. Board befindet sich noch beim Händler zum Umtausch. Dieser Fehler kann jedoch eigentlich nichts mit dem RAM zu tun haben, richtig?
Ist halt ein Thema, das selten angewendet wird und im Falle der Sandy Bridge CPU/GPUs auch noch ziemlich neu.
Erfahrungen = wenig.
Ja wozu dient der bloß???
Biste schonmal auf den Gedanken gekommen das viele CPU Kühler 2 Lüfter haben oder mit 2 Lüftern betrieben werden und man entsprechende Auschlüsse braucht ohne an die Anschlüsse für Gehäuselüfter zu gehen? :bigok:
Ich habe nicht nach CPU_FAN_OPT gefragt. Ich rede von dem Anschluss, der sich DANEBEN befindet.
Wer lesen kann ist klar im Vorteil.
Ich hatte die Force GT auch genau 2 Tage im Einsatz.
Dann haben mir die zahlreichen Freezer (jeweils so 2-3 Minuten lang) gereicht.
Ich war auch nicht mehr bereit, in der Registry am LPM zu manipulieren.
Corsair hatte mir vorher in deren Forum bestätigt, dass die neue SSD solche Probleme nicht hätte.
Haha!
Zudem hat die OCZ Vertex 3 Max IOPS wesentlich bessere Benchmark Werte mit AS SSD.
Ich habe die Force GT an den Händler zurückgegeben. Ich bin es leid, Betatester für Sandforce SSDs zu sein. :(
Du ich glaube hier hat sich bisher außer dir keiner Gedanken um diesen Anschluß gemacht?
Aber wenn du es unbedingt wissen möchtest, frag mal Doktor(ASUS) im Hersteller und Support Thread. Der kann dann mal in Taiwan nachfragen.
Genau dieser Speicher läuft hier bei mir absolut problemlos...und das sogar in Verbindung mit diesem Speicher im 16 GB-Verbund:
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
Also am Board sollte es eigentlich nicht liegen.....ich habe wohl alle Ram-Haupttimings manuell eingestellt.
Gruß,
Lötbert
Ja das sachste so in Deinem jugendlichen Leichtsinn:fresse:
Die XMS sind im Gegensatz zu den Vengeance eigentlich für 1.65 V ausgelegt..laufen aber trotzdem auch mit wesentlich weniger Spannung...also ganz identisch sind se wohl nicht.....wie auch immer lüppt prima hier;-)
"In meinem jugendlichen Leichtsinn" - Sehr witzig ;)
Naja, ganz identisch werden sie nicht sein. Aber mal abwarten. Hoffe das neue Board kommt spätestens Mittwoch. Schon eine Woche im Umtausch. Die ganze neue HW liegt hier rum -.-'
für was ist die render standby funktin im bios für die igpu?
muss die an oder aus sein?
Ich hatte die Force GT auch genau 2 Tage im Einsatz. Dann haben mir die zahlreichen Freezer (jeweils so 2-3 Minuten lang) gereicht. Ich war auch nicht mehr bereit, in der Registry am LPM zu manipulieren.
Vollkommen verständlich. Ich finde es auch ein Armutszeugnis, __WENN__ jedoch das LPM deaktivieren reicht, gebe ich mich damit zufrieden. Nur sollte jetzt überhaupt nichts mehr in dieser Richtung auftreten. Habe den Thread im Corsair Forum übrigens auch gesehen.
Aber Gas geben tut das Ding schon ...
Sorry, wurde jetzt ein wenig OT.
---------- Beitrag hinzugefügt um 12:46 ---------- Vorheriger Beitrag war um 12:30 ----------
Hmm, ein 3 pin Lüfteranschluss, der undokumentiert ist? Hast du mal versucht, dort einen Lüfter (vielleicht nicht grad den für die CPU) anzustecken?
Das ist kein Anschluß, glaube eher das da zu Servicezwecken ein Jumper drauf kommt und deshalb das ganze undokumentiert ist.
Ich würde da nix draufstecken!
Mhmmm, ist schon merkwürdig dieser Anschluss..und ohne Hintergrundwissen würde ich da auch nixx draufstecken.
Allerdings ist das Ding auch wirklich saudämlich angebracht..der ist so nahe am CPU-Fan Header, dass wenn man lediglich einen Lüfter mit 3-Pinanschluss hat, schon mal auf die Idee kommen könnte den dort anzuschließen....weil der CPU-Header ja nun mal einen 4pin-PWM Anschluss hat.
Generell find ich es nicht so schön, wenn es undokumentierte Funktionen gibt....und hier ist die Gefahr halt relativ groß das Dingen aus "Versehen" zu benutzen....ich glaube, ich frage mal beim Doc nach...macht mich ganz wuschig;-))
unwissende Grüße,
Lötbert
Edith sagt:
Habe jetzt mal eine Anfrage im Asus-Support-Forum gestellt.....gucken ob wat kommt.
Hi zusammen,
ich habe ein recht dramatisches Problem und hoffe das der ein oder andere mir ein wenig helfen kann.
Ich habe mehrere absolut identische Systeme die wie folgt aufgebaut sind:
Mainboard:P8Z68-V PRO
CPU: Sandy Bridge: Core i3-2100
RAM:Kingston DDR3-1333 KVR1333D3N9K2/4G (2x2GB)
HDD1: Western Digital WD2503ABYX
HDD2:Western Digital WD1003FBYX
Netzteil:
Be Quiet Pure Power L7 430W
Ausserdem habe ich intern noch nen Cardreader und einen weiteren USBslot per OnBoard USB angeschlossen und nutze noch 2x16 Kanal Videoeingangskarten auf den beiden PCI-Schienen des Boards, sowie eine PCIe 1x ParalellPort Karte auf dem äussersten schwarzen PCIe slot.
Grafikkarte nutze ich keine weitere, hier wird die OnBoard Möglichkeit genutzt.
Als OS nutze ich WinXP mit aktuellen WindowsUpdates und habe im BIOS dementsprechend die Sata schnittstellen von AHCI auf IDE umgestelt. Festplatten sind an den 3Gb/s Sata schnittstellen angeschlossen.
So... jetzt mein Problem.. irgendwann bleibt das komplette Windows einfach kommplett stehen. also weder Strg+Alt+Entf noch Mausbewegungen sind möglich. Steht komplett alles.. Selbst in den Windowslogs passiert anscheinend nichts mehr, keinerlei Fehler.
Es passiert absolut sporadisch.. manchmal nach 3 Tagen, manchmal nach 3 Wochen. Kann ach nicht mit gewissen aktionen des Nutzers zusammen hängen, da es auch auftritt wenn den Rechner geiner nutzt. Muss noch dazu sagen das der Rechner 24h am Tag läuft.
Bis vor kurzem habe ich das Asus P5q-VM-DO Mainboard genutzt. Damit lief alles wunderbar. Weiss langsam nicht mehr weiter.
Vielleicht hat jemand von euch ne Idee wie ich am besten vorgehen soll um das Problem zu lokalisieren.
Vielen Dank im Voraus
stell doch mal die timings von ram per hand ein, vielleicht hilft das ja.
Kann ich denn irgendwie rausbekommen ob die aktuell suboptimal sind ?.. wie finde ich denn heraus was ich da an timings einstellen muss?.. sry hab nicht all zu viel erfahrung damit wie du siehst.
Bootet nicht
Servus,
wenn ich mich auch mal kurz einschalten könnte.
Hab auch das Board, hab aber ein Problem.
Also immer wenn ich denn computer starte kommt die meldung No Hard Disk is detected kurze zeit später sagt er mir bitte boot medium wechseln. Geh ich ins Bios, ab und zu findet er die festplatte und manchmal nicht. An was kann das liegen dass er die HDD nicht findet. Festplatte funktioniert (hab das mit 3 Platten ausprobiert)
Es ist ein Externes Laufwerk und eine HDD angeschlossen (also Boot Medium)
Teilweise startet er, und manchmal kommt die Meldung. Langsam verzweifle ich :(
Hast du das neueste BIOS drauf? 0651
Hast du mal das SATA Kabel getauscht oder die HDD an einen anderen SATA Port angeschlossen?
Ich hatte das Problem wie von Dir beschrieben - neudeutsch "Freeze" - über längere Zeit. Da es mit einem Gigabyte-Board nur alle 3 - 4 Tage auftrat (und ich keine Ahnung hatte, woran das liegen könnte), beließ ich es dabei.
Nach dem Wechsel zu einem (anderen..) ASUS-Board traten die "Freezes" alle paar Stunden auf, worauf ich schließlich ermittelte, dass es am RAM lag.
Die Timings stehen auf den RAM-Riegeln drauf, und man kann sie im BIOS einstellen. Normalerweise ermittelt das Board selbsttätig, welche Timings für den RAM geeignet sind (es kann das von den Riegeln auslesen). Wenn der RAM also nicht "von selbst" fehlerfrei arbeitet, ist das zumindest ein Hinweis, dass er grundsätzlich nicht so gut funktioniert wie vom Hersteller versprochen. "Entschärfte" Timings (= höhere "Latenzen"..) können dann mitunter soweit Abhilfe schaffen, dass es trotzdem ohne Störungen funktioniert - aber dann eben nicht mit "optimaler" Leistung.
Um herauszufinden, ob das Problem überhaupt vom RAM kommt, wäre das Beste, ihn komplett durch einwandfrei funktionierenden (hoffentlich erprobt ;)) zu ersetzen. Da der meistens nicht zur Verfügung steht, empfiehlt es sich, einen der (in der Regel) 2 Riegel auszubauen und zu sehen, ob es so besser wird. Wenn nicht, den anderen ein-/ausbauen.
Man kann den RAM auch (schneller) testen, mit (z.B.) "MemTest86" (Memtest86+ - Advanced Memory Diagnostic Tool).
Hab jetzt nicht alle 37 Seiten gelesen.
Ich nutze noch die 0501 Biosversion. Ist die aktuelle Beta denn stabil oder gibt es neue Fehler?
Was hier beschrieben wird mit "no hdd ist detected" habe ich auch, obwohl eine SSD und zwei weitere per Sata bzw. eSATA dranhängen und auch funktionieren. Benchmarks sind auch i. O.
Weiterhin ist mir aufgefallen, dass wie schon bei meinem alten Asus Board (P5B) so eine Art zweifacher Start stattfindet. Die Lüfter drehen kurz hoch, dann werden sie wieder leiser und erst danach kommt der Piep vom Einschalten. Ist das der angesprochene Lüfterbug oder haut da was anderes nicht hin? Den komischen bunten Asus Screen sehe ich auch 2 mal bevor Windows startet. :confused:
Auch bleibt die rote LED unterhalb des Kühlkörpers unter der Graka einige Zeit an, bevor sie ausgeht (paar Sekunden). Ist das normal?
So hab jetzt nochmal geschaut.. die RAM spannung liegt bei mir auf 1,512V Bei Timings steht alles auf AUTO.. ist aber nicht veränderbar... muss ich vorab irgendetwas beachten bevor ich die Timings manuell anpassen kann ?
Ausserdem hab ich gesehen das ich aktuell mit dem BIOS 501 arbeite und werde es nochmal flashen.
Findet Memtest die Timing bzw. spannungsprobleme ?
Leider hab ich bisher keinerlei erfahrung damit timings manuell ein zu stellen.. da gibts ja tausend werte.. muss ich dann erstmal schauen wo ich die alle her bekomme.
Noch zwei Fragen. Board kommt leider erst morgen vom RMA zurück, werde es dann ggf. testen.
1. Warum sehe ich, wie schlingel3377 bereits geschrieben hat, den Bootscreen 2 mal?
2. Wie stelle ich die Timings vom RAM um? Habe ein 2x 4GB 1600MHz Kit. Auf welchen Wert sollte es dann gestellt werden?
Hallo
Bräuchte mal ein paar Tips.
Habe das P8Z68 Deluxe mit dem neuesten Bios und Win7 64 Home Premium gut am laufen. Das einzige was ich nicht verstehe ist das meine HDD LED ständig am Flackern ist obwohl nichts im Hintergrund läuft.
Habe schon in den Foren nach dem problem gesucht und unter anderen den Windows Search Dienst abgeschaltet aber ohne erfolg. Die LED läuft und läuft pernament.
