[Sammelthread] ASUS Maximus IV Gene-Z (Intel Z68) ROG
Willkommen im Sammelthread zum ...
ASUS MAXIMUS IV GENE-Z
Layout:
weitere Bilder:
Spezifikationen:
Backpanel:
1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
2 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0 (white port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
6 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x ROG Connect switch(es)
1 x Go Button(s)
1 x Clear CMOS jumper(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
1 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x Cable ties pack(s)
1 x ROG theme label(s)
1 x 12 in 1 ROG Cable Label(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Maximus IV GENE-Z Deutsches Handbuch Version G6731
+ Maximus IV GENE-Z BIOS 3305
For proper operation, please ensure to update Intel Rapid Storage Technology driver to version 10.8.0.1003 and BIOS to version 3305 before enabling Intel Smart Response Technology.
Update procedure for users needing Intel Smart Response Technology:
(1) Enter OS, and ensure Intel Smart Response Technology has been turned off under Intel Rapid Storage Technology interface.
(2) Install version Intel Rapid Storage Technology driver to version 10.8.0.1003.
(3) Reboot the system, and update BIOS to version 3305, then reboot.
(4) Enter the BIOS setup screen, press F5 to load BIOS default, then change the Intel SATA Port to RAID mode.
(5) Boot into OS, and re-enable Intel Smart Response Technology under Intel Rapid Storage Technology.
+ Maximus IV GENE-Z 0902 Offizielles Beta Bios Datum 19.09.2011
+ Maximus IV GENE-Z 0706 Offizielles Beta Bios Datum 16.08.2011
+ Maximus IV GENE-Z 0403 Final Bios mit IRST 10601002
+ Maximus IV GENE-Z 0208 First release Bios
+ Maximus IV GENE-Z 0650 Beta Bios
+ Maximus IV GENE-Z 0604 Beta Bios
+ Maximus IV GENE-Z 0603 Beta Bios
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.2.0.1030 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V7.1.14.1107 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V7.1.20.1119 XpVistaWin7
+ Treiber SATA: Intel® Rapid Storage Technology Version: 10.6.0.1022 Datum: 08.06.2011
+ Treiber SATA: Intel® Rapid Storage Technology Version: 10.8.0.1003 Datum: 11.11.2011
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.62.0 WHQL XpVistaWin7
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.63.0 WHQL XpVistaWin7
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.63.0 WHQL eSata XpVistaWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.1.0.0 WHQL XpVistaWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.7.0.0 WHQL Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.7.0.0 WHQL Win7 64-Bit
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.10.0.0 XpVistaWin7
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.14.1.0 XpVistaWin7
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.14.2.0 XpVistaWin7
+ Treiber Video: Intel(R) Graphics Accelerator Driver V8.15.10.2372 WHQL VistaWin7
+ Treiber Video: Intel® HD Graphics Driver 8.15.10.2462 VistaWin7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 8.15.10.2462 VistaWin7 64-Bit
+ Treiber Video: Intel® Graphics Media Accelerator Driver 15.22.50.64.2509 VistaWin7 64-Bit
+ Treiber Video: Intel® Graphics Media Accelerator Driver 15.22.50.32.2509 VistaWin7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.106 09.08.2011 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.106 09.08.2011 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.108 Win7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6363 & 6.0.1.63 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows Vista & Windows 7
+ ASUS AI Suite II V1.01.30 Install Program XpVistaWin7
+ ASUS AI Suite II V1.01.40 Install Program XpVistaWin7
+ ASUS AI Suite II V1.02.11 Install Program XpVistaWin7
+ ROG CPU-Z V1.58 Setup
+ ROG CPU-Z V1.58.4 Setup
Besonderheiten:
Reviews:
ASUS Maximus IV Gene-Z LGA1155 Review | techPowerUp
ASUS Intel Z68 ROG Maximus IV Motherboard Reviews | legitreviews.com
ASUS Maximus IV Gene-Z Motherboard Review | tbreak.com
Asus Maximus IV Gene-Z Motherboard Review | ninjalane.com
ASUS Maximus IV Gene-Z - Artikel | Hartware.net
Asus Maximus IV Gene-Z Motherboard review (mATX) | KitGuru.net
ASUS Maximus IV Gene-Z Review - Mainboards - Reviews | ocaholic.ch
ASUS Maximus IV Gene-Z Review | Overclock3D.net
ASUS RoG Maximus IV Gene-Z Motherboard Review | hardwareheaven.com
ASUS Maximus IV Gene-Z review | hardwareheaven.com
ASUS Maximus IV Gene-Z (Intel Z68) mATX Motherboard Review | TweakTown.com
Asus Maximus IV Gene-Z Review | bit-tech.net
Asus Maximus IV Gene-Z Intel Z68 and Asus Matrix GTX 580 Platinum Review | whatswithjeff.com
Weitere Infos und nützliche Links:
- Welcome to Republic Of Gamers! - Maximus IV GENE-Z
- TEST || ASUS MAXIMUS IV GENE Z
- Vorstellung im ROG Community Forum
- ROG Community Blog: Weapon Drop Inbound
- Official ASUS Maximus IV Gene-Z Motherboard Unboxing
- Video COMPUTEX 2011: ASUS ROG Maximus IV GENE-Z Z68 Motherboard
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Corsair Vengeance Rot 8GB DDR3-1600 CL9-9-9-24 (CMZ8GX3M2A1600C9R) @ 1333 7-7-7-19
G.Skill RipJaws-X 8GB DDR3-1333 CL7-7-7-21 (F3-10666CL7D-8GBXH) @ 2133 11-11-11-30|1866 9-10-9-28|1600 8-8-8-24|1333 7-7-7-21
G.Skill RipJaws-X 8GB DDR3-1600 CL9-9-9-24 (F3-12800CL9D-8GBXL) @ 1600 9-9-9-24
G.Skill RipJaws-X 16GB DDR3-2133 CL11-11-11-30 (F3-17000CL11Q-16GBXL) @ 2133 10-11-10-27 1T
Mushkin Enhanced Blackline Frostbyte DDR3-2133 CL10-11-10-28 (994015) @ 2133 10-11-10-27 1T | 1866 9-10-9-27 1T
1067 MHz | 8-8-8-24-1T | 1.563V | 2x2GB SuperTalent Chrome 2000 C8 | Elpida Hyper | P67 | websmile | Screen
1067 MHz | 8-8-8-24-1T | 1.575V | 2x2GB Corsair Dominator GT 1866 C7 | Elpida Hyper MGH-E| P67 | websmile | Screen
1130 MHz | 7-9-7-21-1T | 1.613V | 2x2GB G.Skill RipjawX 2133 C8 | Elpida BBSE | P67 | websmile | Screen
Kompatibilität CPU Kühler:
+ Corsair H60 (Hersteller-Link)(Foto von Emiras)
+ Corsair H70 (Hersteller-Link)
+ be quiet! Dark Rock Advanced C1 (Hersteller-Link)
+ be quiet! Dark Rock Pro C1 (Hersteller-Link) (Foto)
+ EKL Alpenföhn Brocken (Hersteller-Link) (Foto von Emiras)
+ Noctua NH-U9B SE2 (Hersteller-Link)
+ Noctua NH-D14 (Hersteller-Link)
+ Noctua NH-U12P SE (Hersteller-Link)
+ Noctua NH-C12P SE14 (Hersteller-Link)
+ Noctua NH-C14 (Hersteller-Link)
+ Prolimatech Megahalems (Hersteller Link)
+ Prolimatech Super Mega (Hersteller-Link)
+ Scythe Mugen 2 Rev. B (Hersteller-Link) (FOTO) mit SCURK-3000 oder Backplate-Mod
+ Scythe Ninja 3 (Hersteller-Link)
+ Thermalright Venomous-x (Hersteller-Link)
+ Thermalright HR-02 (Hersteller-Link) (Foto von Stullen Andi)
+ Thermalright HR-02 Macho (Hersteller-Link) mit Thermalright Macho Asus Bolt-Thru Kit
Swiftech Apogee XT (Preisvergleich)
Overclocking Ergebnis:
CPU-Z Validator 3.1
ASUS Maximus IV Gene-Z + 2500K
60°C geschlossenes Gehäuse mit Prime95.
Und dabei hab ich noch viel zuviel Vcore drauf -> 1.32V
So, werds mir nun auch bestellen, wenn ich mein P8P67-M Pro verkauft hab. Oder ist die naechsten Wochen ein starker Engpass zu erwarten? Keine Lust dann Wochen ohne Board zu bleiben.
Ich auch nicht. Gab schon etliche Shops wo es da war und dann sofort ausverkauft wurde. Hol dir das Teil.
So hab jetzt mal auf 1.28V verringert. 1.26 gibt nen BSOD. Temp liegt nun bei 55°C. Denke das ist in Ordnung unter Vollast.
Bezüglich des Netztwerkproblems. Wenn man eine Änderung der Vcore im Bios vornimmt darf man nicht direkt ins Windows booten sonst bleibt die LAN Verbindung aus (angeblich kein Netzwerkkabel eingestöpselt). Rechner ausschalten und wieder hochfahren und alles ist beim Alten.
Eieiei was bin ich froh dass der ganze Kram läuft.
Ein paar Tage werd ich keins haben, das ist auch kein Problem. Nur wenns dann wochenlang ncht verfuegbar waere, das waer bloed.
Hab nun auch nicht mehr so viel Geld ueber, muss das alte erst weg.
Komisch aber das ich nichts an der VCore gemacht habe und auch mehrmals neu starten musste damit es mal wieder erkannt wurde.
Immo läuft es auch nach weiteren Neustarts.
Liegt aber mit an Sicherheit grenzender Wahrscheinlichkeit an den Einstellungen der Fritzbox und dem Lan Port.
Stecke das Kabel mal in einen der anderen Lan Ports und dann guckste. ;)
btw: das war an graebens gerichtet. ^^
Hab ja auch ne Fritz hier.. Habe ich alles schon durch. Bringt gar nix.
Edit: Klar wars an graebens gerichtet. Wir haben ja das selbe Problem... :d
Habt ihr auch keine Seriennummer für die Creative Audigy Software? War bei meinen anderen ROG-Boards immer dabei!
Die selben Symptome - aber nicht die selbe "Krankheit" ;)
Bei einem Rampage II Extreme war mal keine dabei - absolut aussichtslos über Asus was zu bekommen.
Hätte an den Händler zurücksenden müssen.
Ich hab meine Creative Software von der Asus Seite geladen. Muss man installieren, neu starten und danach aus dem Startmenü den Aktivierungsassistenten starten. Sobald der offen ist, packt der dort automatisch eine S/N ein. Es besteht gar keine Möglichkeit was einzugeben. Nach der Aktivierung ist die komplette Software benutzbar.
Der Crystallizer geht sogar... find ich ja alles extrem smooth.
Die Hülle der CD ist bei mir auch leer und im ganzen Karton bin ich auch auf keine S/N gestossen.
So kann er wenigstens nicht verloren gehen. ;)
Ist das ein generischer Key - oder im Bios hinterlegt - Fragen über Fragen.
Stand bei der Aktivierung was dabei wie oft man aktivieren kann ? ;)
Keine Ahnung wo der sich den Key geholt hat.
Stand auch nix von begrenzter Aktivierung.
Also Hardwareversand.de hatte noch etliche auf Lager, mein Asus Maximus IV Extreme-Z ist gestern auch angekommen.
Der Schatz liegt noch verpackt vor mir.
Ja habs schon gesehn. Bestellte auch meinstens bei dem Laden.
Aber erst muss das alte weg, wie gesagt. Hoffe nur der Noctua C12P passt dann auch. Jetzt sind da nur einige wenige Millimeter platz zur Grafikkarte.
Tja das Leidd von µATX ;)
Weiss nicht mehr wer das wissen wollte, aber die Treiber CD mit Datum 06.06.2011 lag beim Extreme-Z bei.
Jap wie schon geschrieben nun scheint es zu funzten nach Treiber update aus deinem Link und umstecken auf LAN1 und dauerhaft Aktivieren des LAN Ports.
Kann man im schlimmsten Fall die Grafikkarte auch im zweiten PCIe Slot betrieben? Wäre ja auch noch eine Möglichkeit, falls es Platzprobleme mit dem NH-C12P geben sollte.
Mit welcher Ausrichtung passt der NH-C12P auf das Board? Ich meine in welche Richtung schauen die Bögen der Heatpipes? In Richtung Grafikkarte? In Richtung Memory-Slots?
Nach links:
Hoeher darf der Sockel aber auch nicht sitzen. Viel Spielraum ist da weder nach oben noch nach unten.
Der untere Slot hat ja nur 8x Anbindung. Dann lieber nen anderen Kuehler.
Ich hab gestern in meiner Verzweiflung noch den Boxed runtergeworfen und mich erbarmt meinen Ninja3 von der LiquidPro zu befreien...
Konnte es dann nicht sein lassen auch noch ein wenig zu spielen und scheint bisher gut zu laufen. Direkt mal 4,8GHz mit knappen 1.34VCore. Gefällt mir die neue Plattform. :d
@Manuel: Den Test mit dem LAN hab ich mir mal geklemmt, da es bei dir ja jetzt funktioniert. :)
Was hast denn für eine CPU Micha ? Die scheint auch gut zu laufen.
Ich hab mich noch nicht weiter gespielt als 4 Ghz kommt aber noch.
Weiß nur nicht was mit der H60 möglich ist dann im neuen Case :'(
Kein Problem wegen dem LAN jetzt läuft es ja und wenn nicht kannst es ja immer noch
testen für mich ;)
Schick mir mal Bilder vom neuen System dann wenn es im V35X eingebaut ist.
---------- Beitrag hinzugefügt um 10:53 ---------- Vorheriger Beitrag war um 10:51 ----------
Nach links:
Wow ganz schön eng da drin, hoffe dein Kühler passt auf das Gene-Z auch drauf.
Eine relativ unbekannt Batch vom 2500K (L104A438).
Google spuckt da nur eine Hand voll CPU-Z Validationen mit 5,4GHz aus sonst nix.
Temps waren sogar relativ OK für Luftkühlung. 70°C mit dem Ninja und einem BlackSilentPro mit 1200RPM.
Klar, wenn dein LAN wieder spinnt mach ich mich dran. Auch wenn die Vergleichbarkeit sich wohl in Grenzen hält, du mit der Fritzbox und ich mit einem relativ alten D-Link Router.
Bilder bekommst du dann wenns soweit ist. Heute sollte der Radi kommen, dann kann ich das Case zerfräsen. :fresse:
Aber nun mal lieber genug OT.
Ähm, OnTopic... Schönstes Z68 Board am Markt :d
Nein ehrlich, das ist echt nen schönes Teil. Ich dachte ich würde mein EVGA vermissen, aber das Gene ist schon was leckeres und definitiv 2 Klassen höher als das X58 LE.
Ich bin zufrieden. :)
Habt ihr beim CPU OC eig. jetzt permanent die hohe Leistung anliegen oder mit den features/stromsparmodi?
Keiner eine idee wegen meinem Mausprob?
Ich finde auch dass es sehr gut aussieht. Allerdings verliert es sich etwas im Gehäuse :d
Btw: Die Graka wandert noch nen Slot nach oben...
Stromsparmodus ist aktiviert... auf jeden Fall !
Hatte anfangs auch wie du ein Keyboard / Mausprob aber nachdem ich alle Treiber aktualisiert hatte war das gegessen.
Der undere Slot ist halt nur 8x. Einzig der Obere hat die volle Anbindung.
Ueberlege, ob ich auch sone Hx0 zulegen soll. Sind und bleiben die Dinger denn 100%ig dicht? Muss man die irgendwann nachfuellen? Kann man das ueberhaupt? Da muss doch auch ne Pumpe drin verbaut sein? Wie ist da die Lautstaerke? Und wie gut ist das Ding bei stundenlanger Last?
