[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Hat schon mal jemand Erfahrung mit der Bluetooth-Funktion des Boards gemacht? Ich kriege es um's Verrecken nicht hin, mein Sony C905 als Fernbedienung einzurichten. :fire:
Ich dachte, ich könnte meinen 5€-BT-Adapter entsorgen (mit dem das immer problemlos funktioniert hat), aber das Asus-Board stellt sich einfach quer.
Alles installiert sich (siehe angehängte Bilder), aber sobald ich die Fernbedienung starte, kann ich die Maus gerade mal ein paar Sekunden lenken, danach geht nichts mehr.
Kann es sein, daß der Adapter eine Reichweite von ~10cm hat? Das wäre dann ca. 4,9m unter dem BT-Durchschnitt..
Oder ist das nur eine Konfigurationssache?
Edit: Es scheint tatsächlich ein Reichweitenproblem zu sein. In der dritten Datei im Anhang sieht man die Signalstärke, wenn ich das Mobiltelefon direkt über das Gehäuse, unter den Schreibtisch halte.
Über dem Schreibtisch habe ich entweder nur sehr schlechten Empfang oder gar keinen....
Verdammt, mit dem ollen Epox-5€-Stick konnte ich noch aus dem Nachbarzimmer mein PC steuern.
Wie stellt Asus sich das mit den tollen BT-Features vor, wenn man dafür vor dem PC sitzen muss? Dann kann man auch gleich Tastatur und Maus benutzen.
Mein Z68Pro ist heute von Asus zurück gekommen . Die habe ein neues Bios aufgespielt . Wenn einer noch ein möchte , dann kann er es für 130 Euro ink. Versand haben . Das Zubehör ist noch original verschweißt .
was für ein bios wurde aufgespielt
Wie kann ich den Boot-Piep abstellen? Der ist ja furchtbar laut und nervig. :(
Hallo zusammen,
ich muss zunächst gestehen, dass der Thread mir zu lang geworden ist und ich nur bis Seite 8 gelesen habe. Sollte also eine Lösung meins Problems zwischen dort und hier genannt sein, gebt bitte Bescheid!
Seit vorgestern habe ich folgende Dinge:
ASUS P8Z68-V PRO(+Corsair 8GB+i3 2120)
2x Crucial C300 SSDs (hängen an SATA3&4)
(und eine alte 500GB WD-Platte, hängt an SATA5)
Mein Wunsch: Raid0 von dem Windows gebootet wird und die WD als Datenablage.
Softwareseitig:
Bios 0501 x64
Raid-Treiber von ASUS-Seite 10.50.1026
Problem:
Ich boote von der Win7 64bit+SP1-DVD und mache mich für die Installation klar. Der/Alle Raid-Treiber lassen sich nicht installieren.
Welchen nehme ich: /RAID/IRST_10501026_XpVistaWin7/Driver/Disk/64bit, genau so wie man ihn runterladen kann, auf eine SD-Karte gepackt und in diesem Rechner eingeschoben.
Es wird einer als kompatibel angezeigt: Intel Desktop/Server/../SATA RAID Controller
Wähle ich ihn aus, versucht er zu installieren, scheitert aber mit der Meldung, dass kein Gerätetreiber gefunden werden konnte.
Ich habe das ganze auch schon mit folgenden Abänderungen betrieben:
1. alle (?) Betriebsmodi bezüglich Raid- oder Nichtraidbetrieb im Bios geändert
2. nur WD dran hängen lassen
3. nur SSDs dran hängen lassen
4. die SSDs auf die Marvel-SATAs gesteckt und Marveltreiber zu installieren versucht
5. Win7 32bit-DVD hernehmen und 32bit-Raid-Treiber zu installieren versuchen
6. Ubuntu 11.04 Live 64bit starten und schauen, ob er was sieht - und er sieht keinerlei Festplatten
Habt ihr eine Idee, was man da noch ausprobieren bzw. woran das liegen könnte?
Gruß und Dank schonmal für eure Hilfe,
NRicola
------Edit------
Ich habe nun mein temporäres USB-DVD-Laufwerk durch ein (internes) SATA-Laufwerk ersetzt und siehe da: auf einmal geht's.
Die Logik hinter derartigen Dingen kann so, sooo abgespaced sein....
Das unten mal so als Anhaltspunkt.......gekühlt mit einem Kryos und Mora2, Wassertemp siehe Screen, Raumtemperatur ca. 21°.
Gruß,
Lötbert
Könntest du mir bitte einen Link geben wo du das aquaero-Gadget her hast? Das für CPU + GPU hab ich auch ;).
ich habe interesse dafür. ist eine Rechnung auch vorhanden ?
machst du über forumluxx marktplatz oder wie ? bitte um pn.
Thanks
hallo leute!
ich würde gern etwas zu diesem thread beitragen und hätte da auch ein paar fragen.
bevor ich allerding anfange ein paar infos um die spätere kommunikation zu erleichter, denn da ich selbst öfter hilfrstellung leiste weis ich, dass man jemandem der ahnung hat etwas anderst erklärt wie jemandem der keinen plan hat. ich leite selber einen sammeltread über die boardreihen GA-770TA-UD3 Rev. 1.0 - GA-790XTA-UD4 Rev. 1.0 - GA-790FXTA-UD5 Rev.1.0 den ich einst von Raptor55 übernommen habe. ich hab zwar relativ viel ahnung was hardware angeht und auch mit oc kenn ich mich recht gut aus nur hatte ich die letzten jahre eigentlich nur AMD systeme. bis auf einige ältere systeme und ein 775er intel was ich aus einzelteilen zusammengebaut habe. deshalb werde ich warscheinlich ein paar grundlegende fragen stellen um zu überprüfen ob ich die informationen was ich die letzten tage so angelesen habe richtig sind.
zuerst mal hier mein system:
Intel Core i5 2500K Batch - L117B253 UV Offset -0.170V
mit EKL Matterhorn auf Arctic-MX4 2x120mm Lüfter mit ca.1000RPM
P8Z68-V PRO
12288MB G.Skill DDR3-RAM
2x2GB Ripjaws F3-12800CL7D-2GBRM 7-8-7-24 1.6V
2x4GB RipjawsX F3-12800CL8D-2GBXM 8-8-8-24 1.5V
@ 1600Mhz 8-8-8-24 1.55V
nVidia GeForce EVGA GTX 570 Superclocked
60GB OCZ Vertex2 E SSD - 1640GB HDD´s
580Watt BeQuiet Straight Power E7-CM-580W
Lüfter: 3*140mm, 5*120mm
Xigmatek Midgard
Windows 7 Ultimate x64
BIOS:
CPU Voltage - Offset -0.170V
Internal PLL Overvoltage - disabled
Load-line Calibration - regular
Phase Control - Asus Optimized
der ram läuft einwandfrei mit den timings 8-8-8-24 und 1600Mhz auf 1.55V. den EKL Matterhorn hatte ich zwar nich vor den zeiten des sockel 1155 gekauft aber die halterung für 1156 ist ja die gleiche, also bin ich davon ausgegangen das er passen sollte. das war aber nicht ganz der fall... die löcher passen zwar überein aber die metallhalterung stößt oben links mit dem eck an dem blauen kühlkörper des boards an. auf sysprofile hat einer das gleiche board und den gleichen kühler und nachdem ich ihn gefragt hatte wie er es gemacht hatte antwortete er, dass er keine probleme bei der montage hatte. kann ich mir zwar kaum vorstellen aber naja.. auf der suche nach leuten mit dem gleichen problem bin ich hier im luxx auf einen thread über die Asus P8P67 reihe gestossen. also die mit dem P67 chipsatz wo das layout ja bekanntlich das gleiche ist. da hatte einer mit dem matterhorn das gleiche problem. nunja, ich hatte das problem nun beseitigt indem ich ein kleines stück von der halterung abgeflext habe. nun passt er einwandfrei.
also für den startpost: die beiden rams laufen wie angegeben einwandfrei. memtest lief bei test 5 knapp 20 runden und seid tagen im alltagsgebrauch und durch tests wie prime96 und linx ohne probleme. der EKL Matterhorn passt mit der einschränkung das man ein stück der halterung absägen oder flexen muss.
ich habe ja undervoltet. bevor ich im bios den finalen wert eingestellt habe ermittelte ich den stabilen wert über TurboV EVO. ich habe also prime 95 custom und Run FFTs in-place 10 minuten laufen lassen und die CPU voltage um 0.01V veringert. dann 10 minuten gewartet und wieder um 0.01V veringert. das ganze spielchen ging gut bis ich bei 0.97V ankam, bluescreen ;). man muss allerdings bedenken, dass der standardwert im TurboV der 1,165V beträgt in cpu-z unter volllast 1,256V beträgt. nun im nios Offset -0.170V eingestellt, sodas im windows im idle mit 1600Mhz 0.82V, falls er ohne schwere last mal kurz hochtaktet 1.15V und unter volllast im turbomodus mit 3700Mhz 1.11V anliegen. ist der wert ok so? und kann man anhand eines UV wertes wenigstens abschätzen wie sich die jeweilige cpu im OC schlagen wird, zumindest was was die volt angeht die gebraucht werden wird? so nach dem schema, wenn eine cpu @stock einen guten undervolting wert schafft wird die cpu beim overclocking auch weniger volt brauchen als eine cpu die sich @stock schlecht undervolten lässt?
hier mal ein screenshot der 2 schritte vor dem bluescreen entstanden ist, also mit 0.99V.
Undervolting
nun zu meinen fragen:
ich bin hauptsächlich über die werte verwirrt die mir das asus tool AI Suite II bei überwachung/sensor anzeigt und dann über die temps die ich habe. dazu kommt noch das die kerne unterschiedlich warm werden... aber mal von vorne.
das AI Suite II tool blinkt unten rechts mit einer warnung kurz auf wenn ein wert nicht passen sollte. bei mir passiert es manchmal z.b. das er aufblinkt mit: Warning CPU @127.5°C! oder mit Warning +12V @21.xxxV oder mit Warning +5V @0.2xxV. aber immer nur ganz kurz, der wert ist kurz darauf wieder ganz normal. ich gehe ja mal davon aus das dies ein anzeigefehler ist aber ich würde trotzdem mal eure meinung hören was ihr dazu sagt?
der hardware monitor zeigt im screenshot ja bei den lüftern einen topwert von
65535RPM an und das sogar bei den anschlüssen wo gar keiner dranne hängt... lol.
dann hab ich irgendwie das gefühl das meine temps nicht ganz ok sind, vor allem für den kühler der verwendet wird. momentan im idle, nur der browser mit einigen tabs läuft usw. also nichts besonderes, hat die CPU beim 1.kern:30°C - 2.kern:28°C - 3.kern:33°C - 4.kern:28°C wobei das asus tool bei CPU 34°C anzeigt was mit den AIDA temps CPU Package/IA Cores übereinstimmt wobei AIDA bei CPU 26°C angibt. was ist da nun die richtige temperatur für die CPU? vor allem was bedeuten bei AIDA die verschiedenen CPU temps? diese zeigt es an: CPU 26°C dann CPU Package 33°C und CPU IA Cores 33°C die immer parallel ansteigen und sinken und dann noch CPU GT Cores 33°C wobei ich glaube, dass das letzte die interne GPU sein soll, bin mir aber nicht sicher da ich diese eigentlich im bios deaktiviert habe.
unter voller auslastung kommen die temps aus dem obigen screen ganz gut hin wobei es an dem tag brutal heiss und auch schwül war und es über 26°C raumtemperatur hatte. diese waren beim 1.kern:50°C - 2.kern:48°C - 3.kern:55°C - 4.kern:50°C wobei das asus tool bei CPU 54°C anzeigte.
man muss natürlich bedenken das diese temps mit der undervolteten CPU dokumentiert wurden obwohl diese mit standard vcore auch nicht sehr viel höher waren.
sind diese temperaturen ok? und ist es normal das die temps der verschiedenen kerne etwas auseinander liegen und das vorallem der 3.kern immer gleich 4-6°C wärmer ist als die anderen?
ich hab erst gelesen das dies normal sein soll bei intel aber ich frag trotzdem lieber mal nach da mir das irgendwie sorgen macht.. ich kenns nämlich nur von meinen AMD´s, da waren die tems der verschiedenen kerne immer genau gleich egal bei welcher auslastung.
ich weiss, ist viel information auf einmal aber ich hoffe wirklich das sich jemand bitte die zeit nimmt um das zu lesen und meine fragen beantorten kann. bin wie gesagt neu was intel angeht. ich hätte auch schon früher geschrieben aber ich kann es selber nicht ausstehen wenn leute fragen stellen bevor sie sich auch nur ein bisschen informieren deshalb hab ich mich die letzten tage gut in die materie eingelesen, vor allem was das OC oder UV und die mios einstellungen von sandy bridge angeht und vor allem was es zu beachten gibt da doch ein paar unterschiede zwischen intel und amd bestehen.
vielen dank schonmal für die mühe an diejenigen die sich mit meinem problem beschäftigen.
Zur AI Suite und den Warnmeldungen kann ich dir nichts sagen, da ich es nicht nutze. AIDA64 sollte die Spannungen und Temps richtig auslesen.
Die unterschiedlichen Temps der Cores sind normal, das haben andere auch.
Hallo!
Habe mir das Board gekauft und verwende es mit i5-2500k, corsair H70 Liquid Cooler, Zotac 550 GTX TI und 16gb Corsiar Vengenance @ 1600MHZ
Alles rödelt und ich habe nach 10 Min. einen netten Bluescreen!
KA warum und kann mir jemand folgende Frage beantworten?
Habe die Pumpe der Wasserkühlung auf PWR1_Fan gehängt und die 2 Lüfter auf CPU_Fan.
Warum kann das Board die Lüfter nicht runterregeln? Egal was für eine Spannung der testet die - Lüftergeschwindigkeit ändert sich nicht... Will ja keinen Düsenjäger im Zimmer haben. und was zum Teufel ist der CPU_Fan_OPT?
LG Fredcombuese
Hmm und wo finde ich die beiden netten Intel gadget ;-)
Danke vorab.
Ich kühle ähnlich wie du. Mora2 komplett passiv mit HK3.0. Ich habe auch einen Wasser Temp Sensor mit eingeschleift, welchen ich damals direkt ans Rampage Board anschließen konnte. Dieses Board konnte mir dann den Wert direkt ausgeben. Leider hat das P8Z68 V Pro diesen Anschluß nicht mehr, daher überlege ich gerade an einem Aquaero, allerdings habe ich ne Laing und ich weiss nicht ob das Aquaero mittlerweile damit umgehen kann.
Meine Wassertemp ist aber auch nie mehr als 5 °C über Raumtemp ;-), daher hatten mich erst die hohen werte der Cores erschrocken, aber wie du schon sagst, voll latte, die Kiste rennt wie SAU und das ist das Wichtigste.
Aber gut, schluss mit offtopic...
Thx
relaxer
hi zusammen,
gibt es schon ein neues bios fuer das P8Z68-V????
Aber nicht das Intel-Tool......ist allerdings auch kein klassisches Gadget, sondern eine installierbare Anwendung. Das andere Tool habe ich eigentlich nur laufen um die Auslastung der Kerne zu "kontrollieren"
Das Intel Tool zeigt allerdings nicht jede Taktänderung an..aber ob die CPU mit vollem Takt oder im Idletakt läuft, und das reicht mir.
Hallo zusammen,
ich habe folgendes Problem mit dem P8Z68-V Pro: während dem booten reagiert meine Tastatur nur am USB 3.0 Port, somit komme ich nicht ins Bios wenn ich sie an einen 2.0er Port angeschlossen habe. Im Windows läufts dann ganz normal.
Ich habe es hier schon ähnliches gelesen, aber nicht so ganz verstanden.
Muss ich einfach den USB 3.0 den legacy support aktivieren dann funktioniert mein 2.0er Port mit Tastatur beim booten?
Eigenartig ist auch, dass mir beim Bootvorgang am 3.0er Port 2 Keyboards angezeigt werden, beim 2.0er nur eins wie es auch sein sollte.
Danke für eure Hilfe!
EDIT: Bios 0502 ist drauf
Hallo Leute,
ich wollte morgen eigentlich mein neues sys bestellen, und war das das ASUS P8Z68 Deluxe eigentlich meinte erste wahl, bis ich auf dieses Forum sties^^
ich habe mir einige seiten durchgelesen, und je mehr ich gelesen habe desto blasser wurde meine Gesichtsfarbe.
Wie schaut es denn momentan aus, bios + software soweit stabil das auch mit nicht so viel know how das ding zum laufen bekommt?
ach und noch etwas, ich habe momentan 4 Festplatten verbaut, welche in keinem Raidverbund laufen, kann ich diese dann einfach einbauen und ssd chaching nutzen?
bzw wenn ich diesen raid Modus softwareseitig aktiviere sind dann meine Daten weg?
LG Manu
angedachte Anschaffung besteht aus:
ASUS P8Z68 Deluxe
8GB-Kit Corsair Vengeance DDR3 1600 MHz CL9
Intel Core i7-2600K Box
Crucial M4 128GB SSD
ich habe mein system am samstag gekauft.
es laeuft alles einwandfrei, bis auf diese bios meldung die ich im moment nicht ausschalten kann.
cpu fan error .
aber sonst top system.
Warum schließt du den CPU-Lüfter nicht am CPU Fan Anschluss an?
Dann ist diese Fehlermeldung weg.
ich habe ne wakü mit lueftersteuerung. somit benoetige ich keine abschluesse am brett
Es gibt ein inoffizielles BIOS 0502, das diesen Bug beheben soll (soweit ich das verstanden habe).
Es gibt auch einen Link zu diesem BIOS. Guck mal im Thread nach.
herzlichen dank, fuer die info.
schau ich dann gleich mal durch.
Ram?
Hallo, ich bin nun 3 Wochen im Besitz von der Deluxe Version.
Nun hätt ich da ein paar Fragen.
Als Arbeitsspeicher nutze ich zwei mal das Kit hier: CMZ8GX3M2A1600C8
http://www.idealo.de/preisvergleich...mz8gx3m2a1600c8-corsair.html?ts=1309794997389
Also 16GB, da kommt auch das Problem.
Ich bilde mir ein das am Anfang nach der Installation der Taskmanager (Aida64 etc) mir
16,23 GB angezeigt hat. Ich dachte ok ein paar MB weniger ist normal.
Gestern, als ich mir die Ramdisk eingerichtet habe, ist mir zufällig aufgefallen das nur noch 15,27GB verfügbar sind, also Ramdisk aufgelöst etc. Neustart, das Bios kontrolliert,
scheint alles in Ordnung zu sein. Direkt nach den Start wenn die Festplatten usw angezeigt werden, zeigt das Bios die richtigen 16.384MB an.
Ich mein ich will ja nich kleinlich sein bei 16 Gigs Ram, aber das kann doch nich sein oder,
ist immerhin 1GB "verschwunden"
Woran kann das liegen, hat jemand ne Idee?
Selbstverständlich hab ich ein 64bit System drauf, Vista.
MFG
dann hab ich irgendwie das gefühl das meine temps nicht ganz ok sind ...
Deine Temperaturen sind völlig normal würd ich meinen. Ich habe einen 2600K und der zeigt exakt das gleiche Verhalten, mal wird der eine Kern ein wenig wärmer, mal andere. Alle gleich warm würde ich nicht glauben, da in der PC Welt noch immer das meiste sequentiell abläuft und deshalb ein Kern mal mehr zu tun hat als der andere / als die anderen.
Bei Aida ist die richtige Temperatur die "CPU Package". Sie dürfte wahrscheinlich einen Mittelwert über die Kerne bilden und den ausgeben. CPU allein gibt immer die niedrigste Temp. eines Kerns an soweit ich das beobachtet habe, k.A. was das für einen Sinn hat. Unter Last treibe ich ihn auf 47 Grad hoch, 50 und mehr Grad habe ich noch nicht geschafft - gut die Tests fanden nicht an höheren Umgebungstemperaturen statt (~ 22° Raumtemp).
Im Idle geht er auf 1,6 GHz runter.
naja, ich werde mir da mal das deluxe bestellen, hoffentlich muss ich nicht zuviel herum probieren damit es läuft.
zum testen will ich das board erst einmal ohne ssd chaching und virtu nutzen, muss ich da was beachten an bios Einstellungen?
LG
