[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Und hier sind zwei SSD´s im Einsatz (C300 128GB / Vertex 2 120GB) Beide am Intel SATA 6GB angeschlossen und unter Win 7 x64 incl. RSM 10.5.1.1001....absolut keine Probleme seit Installation (1 Woche her)
Achso, P8Z68-V (ohne pro)
Gruß,
Lötbert
Sei froh! :rolleyes:
Hier läuft das Ganze ebenfalls unter Win7 x64 und RSM 10.5.1.1001.
Nur dass ich halt die 6Gb/s SSD dranhängen habe und die zwei 3 Gb/s SSDs.
Ich habe die Vertex 3 jetzt seit 2 Tagen am Marvell 6 Gb/s Port hängen und bisher gab es keinen Freezer mehr.
Die beiden Intel 6 Gb/s Ports kristallisieren sich so langsam als zentrales "Übel" heraus.
Also, ich hab mein Win 7 neu aufsetzen müssen, da es BSOD´s am Stück hagelte. Zwar hat Win alle Geräte anstandlos erkannt und dementsprechende Treiber installiert (hatte vorher eine Asrock P67 extreme drinne) aber das Sys lief keine 5 Minuten am Stück durch. Ich dachte erst das Board ist im Eimer.......aber eine separate Vista Installation zeigte keinerlei Probleme. Also habe ich Win 7 neu installaliert. Seitdem gibbet keine Probleme mehr. Eigentlich sehr ungewöhnlich, dass ein Boardwechsel solche Probleme macht....aber man steckt ja nicht immer drin;-))
OCZ weiß anscheinend um die Probleme, aber spielt es (noch) herunter:
OCZ would like to provide an update to all our customers regarding the BSOD issue. We can once again confirm that the hardware issues causing problems on other manufacturers are not present in our proprietary design. While the BSOD issues continues to affect a very small percentage of our customers OCZ has been able to replicate the issue and have isolated it to the Intel RST driver. OCZ has continued to run testing and analysis that leads us to believe that the Intel driver is causing these problems, in addition we have been able to replicate the issues on a wide range of drives including SandForce based drives as well as other branded drives utilizing a number of different controllers. We advise any customers that have experienced the BSOD issue to immediately switch to the Microsoft driver. Through OCZ and SandForce testing with the Microsoft driver we have been unable to replicate the issue, and we are continuing to run additional testing on all platforms.
We appreciate our customers support and patience through this, and while the vast majority of customers will never experience this issue we encourage any customers that experience this or any issues whatsoever to immediately contact our forum support team here or our in-house customer service team where we will be happy to assist you.
Damit ist das Freezer-Thema eigentlich keins mehr, was in diesen Thread gehört, denn es betrifft nicht explizit die hier behandelten Boards.
Hallo @ all,
ihr seid quasi meine letzte Hoffnung, ich weiß nicht mehr was ich noch tun ausprobieren soll. Ich besitze das P8Z68-V (Bios/UEFI 0401) als Prozessor läuft bei mir ein i5-2500k ( nich übertaktet). Meine Grafikarte ist folgende ASUS HD6950 2Gb (kein Bios Mod). Aso noch vergessen 2x4gb 1333er Ram von Corsair und ne Corsair Force F-120 120GB SSD (hängt am SATA III Port). 550W Superflower NT und Windows 7 Professional 64bit ist drauf.
So nun zum Problem mein System läuft im Desktopbetrieb stabil. Aber sobald ich ein Game starte (im menu auswählen --> dann spiel starten oder server joinen) das klapt alles soweit so gut aber nach 15 bis 20sek im Game freezt das Bild ton läuft weiter oder auch nicht, dann nach einiger Zeit läuft das spiel dann weiter und das ganze wiederholt sich dann mehrfach oder der Pc bleibt hängen und das spiel beendet sich mit der fehlermeldung spielt funktioniert nicht mehr. Geteste wurde das mit Crysis 1 und 2, Team Fortress 2 sowie Half Life Loas Coast. Alle Treiber sind aktuell Lucid logix wurde auch testweise deaktiviert. RAM getestet und Grafikarte über extra netzteil versorgt.
Jetzt kommt etwas seltsames, guter Freund von mir hat genau die gleiche hardware bis auf Graka und Netzteil, also haben wir mal meine Graka bei ihm eingebaut und instaliert und Command and Conquer 4 gestartet (das hat seine HD5770 1gb zu 100% ausgelastet alles auf very high). Und das lief mit meiner Grafikarte auf very high alles ohne mucken zu machen. Achso noch eine Anomalie wenn ich auf meinem Rechner 3dmark vantage laufen lasse käuft das auch stabil durch nur games wolen bei mir nicht laufen. Wenn igendwer eine Antwort oder einen Ansatz zur Lösung des Problemes weiß dann bitte ich um seine Hilfe/ Ratschläge. Denn ich weiß net mehr weiter!!!
Hallo @Eu1eOne,
probier doch mal folgendes den JMicron® JMB362 controller im Bios Deaktivieren.
Die Corsair welche ist das bitte denn es gibt die Force3 mit SATA 600 und die F120 mit SATA 300 bitte vergewissere dich das deine SSD korrekt angeschlossen ist. ^^
Wenn du den SATA600 nicht brauchst schalte diese im Bios auch ab. :d
Drück dir die Daumen
Gruss Val.
Eventuell ein Audioproblem mit dem Treiber ? Oder die SSD ^^
AAAAAHHHHH Schreien könnte ich......!!!
Jetzt spinnt der CPU Temp wie blöde und verursacht abschaltungen im System!!!
Hab diesen mit einem Externen Tempfühler gemessen da sind abweichungen von über 15° drinnen. AAAAHHHHHH
Weis da jemand wie man dieses umgehen kann?
Vielen Dank im vorraus
Val.
---------- Beitrag hinzugefügt um 23:25 ---------- Vorheriger Beitrag war um 23:22 ----------
Zum hinzufügen hab ein phänomen entdeckt mit dem EPU.
Wenn der Schalter am Board AUS ist startet der Rechner einige male wieder neu nach einem Kaltstart.
Wenn dieser Aktiv ist passt alles. Keine neustarts
Im Bios auch die Einstellungen geprüft wenn schalter aus alles im Bios aus ohne erfolg - PC Startet nach Kaltstarts neu. ^^
Euer Val.
Hallo @Eu1eOne,
Gruss Val.
Also der JMicron controller steuert meines wissens nach nur den E-SATA port an, lasse mich aber auch eines besseren belehren wenn es anders ist. Die Beiden Sata 3 ports aufem vboard werden ja vom intel chipsatz gestellt. Die SSD ist eine Force 1 also Sata 2. Die ssd hing schonmal am sata 2 port bringt keine besserung mit sich. aber den jmicron kann ich mal abschalten. Audiotreiebr habe ich mal testweise ganz runtergeworfen aber gab dadurch auch keine besserung !!! Trotzdem schon einmal danke an alle die sich meinem Problem angenommen haben.
Hab den BUG bei Lucid Logix gefunden und ist super rekonstruierbar.
Das andere mit dem Runterfahren hat sich geklärt hat aber zum BUG beigetragen.
------------------Situation
Wenn eine Software den Shutdown Forciert sprich dreckiges Herunterfahren ohne das sich Prozesse langsam verabschieden!! Hat Lucid Logix was dagegen......
Nähmlich dies zerstört bei solch einem Prozess die Lizenzdatei!!! Danach funktioniert Virtu nicht mehr und es muss mit einer gleichwertigen BIOS version geflasht werden. Sprich es darf nicht die gleicher Versionierung sein.
Soweit ich die Lizenzmechanik verstanden habe wird ein Token zwischen dem Bios und Lucid ON THE FLY ausgetauscht und wenn dieser Prozess irgendwie gehindert wird funktioniert Virtu nicht mehr und die Lizenz im Bios ist kaputt.
Seit bitte vorsichtig bei Software die euren Rechner Herunterfährt!!!
Rekonstruierbar nach ca. 5 Shutdowns mit Free Youtube to MP3 Converter diese Software macht einen Kernel Shutdown mit einem Dreckigen Befehl.....
Euer Val.
Leute, Microsoft ist doch immer wieder IT-Wonderland wie ich eben feststellen mußte. :haha:
Vor einigen Wochen habe ich vom P67 Deluxe B2 auf das Deluxe B3 umgebaut.
Mein Windoof7 wollte natürlich ne Neuaktivierung. Eben habe ich vom P67 Deluxe B3 auf das Z68V Pro umgebaut und alles läuft im Windoof und keine Aktivierung nötig? Das soll einer mal verstehen???:shake::d
Lucid Virtu habe ich mir vorerst mal gespart........
Morgen kommt mein P8Z68-V....
Muss leider in Vorkasse treten bis ich mein B2 Board erhalten haben.
Naja aber immerhin kostet der Wechsel auf ein aktuelles Board im Nachhinein nichts. gelobt sei der Intel Produktionsfehler :fresse:
Hab seit heute im Büro auch das P8Z68-V, muss mich erstmal an das scheiss UEFI Bios gewöhnen :rolleyes:
Ich benötige mal Hilfe von euch. Bzw vión denen die das Board haben.
Also es geht um das P8Z68-V Pro. Ich bin Kurz vor der Bestellung eines Pc. So nun kann ich mich nicht richtig entscheiden. Wie gut is das Board? Is es Stabil, wie sieht es mit Oc aus?
Das andere Wäre ein Asrock Z68 Pro3
Mir geht es um Stabilität und Oc. Habe keine Lust das das Board dan anfängt wegen jeder kleinigkeit rum zu Zicken. Wäre für eure Hilfe sehr dankbar
Mein Rechner ist heute angekommen und ich bin gerade dabei alles zusammen zu bauen.
Habe zwei kleine Fragen:
Ist es normal, das an der Statikplastikhülle, in der sich das Mainboard befindet, kein Siegel oder ähnliches befindet, an dem man sehen könnte, ob es bereits eingebaut wurde?
Ich glaube auf der Rückseite, da wo die Schrauben reinkommen, sind minimale Kratzer. Würde mich schon ärgern, da ich bei der Bestellung extra darauf hingewiesen habe, das ich alles orginal verpackt will.
Außerdem sind auf der Rückseite an einigen Stellen minimale bläuliche Verfärbungen. Ist das normal?
Ist es normal das die Ränder des Mainboards ein klein wenig kleben?
@CarnageDark: Und deine Frage stellst du in einem Asus Sammelthread? :d
Das die Antistatiktüte nicht versiegelt ist, ist normal.
So , das neue Bord ist heute angekommen . Es war tatsächlich das Board was im Eimer war . Ich habe nochmal das Pro genommen .
alles klar da weiß ich bescheid THX
So, melde mich mit neuem Rechner zum Dienst.^^ Das Zusammenbauen ging recht reibungslos von statten und das Gehäuse ist super. Ich glaube ich hatte noch nie so wenig Kabelsalat im Innenraum des Gehäuses.
Natürlich habe ich wieder paar kleine Fragen. An meinem Enermax 82+ Modu ist so eine kleines Kabel das aussieht wie ein Lüfterkabel. Für was ist das denn gut? Ist das dafür gedacht, das man rein theoretisch den Lüfter des Netzteil regeln kann oder muss ich das anschließen?
An meinem Enermax sind leider noch teilweise diese alten Stromstecker dran, die früher die IDE Laufwerke gebraucht haben. Ich hatte deswegen jetzt zu wenig Satastromversorungsanschlüsse (Ihr wisst bestimmt was ich meine^^) und habe einen Adapter benutzt.
Dadurch habe ich aber an einem KAbelstrang des Enermax recht viele Sachen hängen und wollte fragen ob das ein Problem ist. Das Kabel hat 2 Satastromversrgungen und 2 dieser alten Stromanschlüsse. An den 2 Sataanschlüssne habe ich normale Festplatten dran. An einem der nromalen Stromanschlüsse habe ich einen Adapter dran gemacht um noch zwei weitere Satastromanschlüsse zu haben. Davon nutze ich aber nur einen für eine weitere Festplatte. An dem letzten normalen Stromanschluss hängt jetzt noch die Soundkarte (Asus Xonar DX) per Adapterkabel (An der Soundkarte ist das so ein kleiner Anschluss mit drei Stiften. Sieht aus wie bei einem Lüfter).
Reicht das für die Geräte oder muss ich mir da jetzt Gedanken machen?
Was für ein Programm ist geeignet die Temperaturen der Cpu auszulesen? Ich habe es mit verschiedenen genutzt, aber alle zeigen mir andere Werte an. Und gerade zu Beginn möchte ich die Temperaturen natürlich im Auge behalten.
Ansonsten macht der Rechner aber jetzt schon sehr viel Spaß, das Booten ist ein Traum (Jedenfalls nachdem ich diesen Hängebug des LPMs beseitigt habe^^).
Ich hatte die Hänger recht oft während ich meine Software installiert habe (Asus Z68Pro/ Crucial M4 am Intel Sata3-Anschluss). Scheint mit dem Ausschalten der LPM-Funktion aber weg zu sein.
Ach ja, ist es normal das auch shcon Mainboards mit 501er Bios verschickt werden oder ist das auch eher ein Indiz dafür, dass das Board schon bei jemand anderem war, der es eventuell geflasht hat? Im Prinzip ist es mir egal, da alles zu laufen scheint, würde mich nur interessieren.
Ach ja, alles was mit der IGPU zusammen hängt, habe ich erst einmal weggelassen und warte, bis das wirklich ausgereift ist.
EDIT:
Release Date: 06/8/2011
Change Log:
Added margin to already-passing electromagnetic interference regulatory tests. Provides additional EMI margin for systems integrators.
Improved performance with Link Power Management. Resolves performance pauses and hesitations with certain host systems.
This is a recommended but not required firmware update. If the end user is experiencing pauses or hesitations in systems with Link Power Management ("LPM") enabled, then this update is highly recommended.
Scheinbar behebt die neue Firmware von der Crucial M4 das LPM-Problem.
Ich habe jetzt das neue Board eingebaut und Windows 7 neu aufgespielt . Bisher noch keinen Freezer mehr . Das Bios ist das 401 . Allerdings habe ich noch nicht den Intel Rapid Stoarge Treiber aufgespielt . Der verursachte auch bei mir den Freezer . Kann das hier jemand bestätigen ? . Systemplatte ist die OCZ Vertex 3 120 GB und ist am Intel SATA 6 GB/s angeschlossen .
Hallo @norby,
mit dem Intel Controller kann ich keine fehler feststellen. Nutze 2x SATA Samsung Raid 24/7 Platten auf Raid 0 und eine SSD mit 40GB von Intel Serie 320 als Cache platte. Soweit ultra zufrieden ^^
Natürlich sind reine SSD Lösungen schneller aber für nen sparbeutel wie mich eine 200%ige speed Steigerung. :d
VG Val.
P.s.: Habe den aktuellen IRST von Intel drauf und alles ist aktiv. Keine hänger what so ever...... ^^
Folgende Konfig plane ich:
ASUS P8Z68 Deluxe
OCZ Vertex 2 120GB
WD Caviar Black 640GB
2x WD Raptor 150GB
2x SATA ODD's
An welchen SATA Ports soll ich die anklemmen?
Hmmmmmm.........
2x WD Raptor 150GB auf Port 1 und 2 (SATA2)
2x SATA ODD auf Port 3 und 4 (SATA2)
1x OCZ SSD auf Port 1 (SATA3)
1x WD Black auf Port 2 (SATA3)
Es versteht sich das alles auf den Intel Controller -
Marverll Controller im BIOS Deaktivieren! ^^
Somit kannst du die WD Raptor auf Raid 0 setzen und die SSD Platte als JBOD ist als Systemplatte dabei. Die OODs werden da auch super laufen ohne Boot konflikte. ;)
VG Val.
Also mir kam es auch so vor, das ich die Hänger erst bekam, als ich den aktuellen Treiber installiert habe. Das könnte daran liegen, das die neueren Treiber das LPM aktivieren.
Ist auch hier im Artikel beschrieben:
Hänger mit SSD durch Ausschalten von Intel LPM (Link Power Management) beseitigen
Seit dem ich LPM mit der Regdatei deaktiviert habe, funktioniert wieder alles. Das Firmwareupdate von Crucial sollte den Fehler aber auch beheben.
Zwei wichtige Frage hätte ich auch noch. Wenn mein Rechner bootet dann klackt irgendwas zwei mal, direkt wenn das Windowslogo erscheint. Hört sich ein wenig an, als würde ein kleiner Schalter umgelegt "klick klack".^^ Ist das bei euch auch so, ist das normal?
Wie kann ich das Booten etwas beschleunigen? Der Windowsstart ist Blitzschnell, aber das Booten dauert sehr lange. Folgendes wird angezeigt:
Recht lange das Biosbild -> Schrift -> Bios -Marveltext -> Bios und dann erst Windows.
Da ich die Marvelsataanschlüsse nicht nutze, wo kann ich die deaktivieren?
