[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
Über die Optionen des Intel LAN Treibers im Gerätemanager.
Dort sind einige Diagnose Funktionen verfügbar.
Meine Kabelqualität liegt - trotz sporadisch fehlenden LANs - satt im grünen Bereich.
LAN Kabellänge = 10 Meter.
Aber das eine hat wohl mit anderen nichts zu tun.
Hallo Leutz,
bin mit meinem Board sehr glücklich.
Aber
Wenn man sich hier durchlist hab ich laut aussagen hier schon zwei fehler gemacht nähmlich die TPU und EPU am Board aktiviert.
Laut der Anleitung wenn mann dies nutzen will sollte die per Schalter und am Bios aktiviert werden. Da sonst diese Funktion nicht zur verfügung steht.
Hab dies so noch nicht getestet! Das erklärt die Neustarts........ ^^
ZurZeit BIOS 0501 installiert!
So wenn ich das richtig verstehe kann ich die Schalter ausschalten und die TPU und EPU am Bios aktivieren ohne komfort zu verlieren oder...?
Euer Val.
@ plauzi
hier mal kurz die Übersicht der Übertragungsraten
SataI = 1,5 Gbit/s -> 187 MByte/s (1 Byte = 8 Bit) = Netto-Datenrate 150MByte/s.
SataII = 3 Gbit/s -> netto 300MByte/s
SataIII = 6 usw -> 600MByte/s
Je nachdem was deine Platte laut Messungen oder Erfahrungen so bringt, wählst du eine Schnittstelle. Für normale Platten würde also sogar SataI reichen, falls es SSD mit mehr als 300MB gibt, dann natürlich SataIII
Die deutsche Anleitung liest sich so, als ob man wählen könnte.
Wenn man TPU/EPU eh IMMER nutzen möchte, kann man es direkt am Board mit den echten Schaltern aktivieren.
Wenn man flexibel bleiben möchte, kann man es über das BIOS aus- und einschalten.
Ob das stimmt, habe ich noch nicht herausgefunden.
Schalte ich z. B. EPU per Schalter auf dem Board ein, so ist es im BIOS trotzdem nicht aktiviert. Ich muss es dort extra aktivieren.
Irgendwie sehr unlogisch.
Wenn du die Schalter auf OFF stehen hast, kannst du OC (TPU) und EPU trotzdem im BIOS aktivieren.
Ich habe jetzt nur noch nicht getestet, ob es dann ebenfalls zu diesem Restart beim Kaltstart kommt, wenn man OC nur im BIOS aktiviert.
So habe ich es auch verstanden.
Aber da das Board ja so recht keine Rückmeldungen liefert, zumindest was EPU angeht, ...
Ich werde mich auch erst am Wochenende mal ausführlich mit diesen Dingen beschäftigen können.
Vielleicht gibt es bis dahin hier ja schon ein paar fleißige Leute, die das getestet haben.
Es gibt keine speziellen SATA3 Kabel.
Die Leitungsbelegung ist überall gleich.
Nur von Sata1 auf SATA2 Revision der Kabel wurde noch dieser Metallbügel als Verriegelung hinzugefügt.
@ plauzi
In der Praxis sieht es bei meinen WD HDD so aus:
Übertragungsrate 80-120 MB/s, je nach Größe der Files, wenn ich von einer auf die andere HDD kopiere.
Da würde in der Tat ein Sata-I ausreichen.
Wie sieht es bei 2 SSD-Platten mit 6GB = SATA-III aus?
Wenn ich da von SSD1 auf SSD2 kopiere?
Welche Raten kämen dabei in der Praxis heraus?
---------- Beitrag hinzugefügt um 11:19 ---------- Vorheriger Beitrag war um 11:17 ----------
Bist du ganz sicher?
Warum unterscheidet dann ASUS bei den beigelegten SATA-Kabeln deutlich zwischen SATA2 und SATA3?
Das Kabel scheint das gleiche zu sein.
Sie schreiben dort nur von "Qualitätskomponenten", die ausgewählt werden müssten, um die Datenintegrität zu gewährleisten.
Was sind die Qualitätsunterschiede bei SATA Kabeln?
Gibt es da besser und schlechter abgeschirmte oder woran erkenne ich ein gutes Kabel?
Dann mach ich folgendes Heut so ca. um 18:00Uhr kann ich das Testen anfangen.
Hier schon mal meine specs.:
MB: ASUS P8Z68-V Pro - BIOS 0501 mit geändertem MyLogo
CPU: Intel i7 2600K
RAM: Corsair DualChannel Arbeitsspeicher XMS3 1333 2x 4GB
Graka.: Palit Sonic GTX 460
SSD: Intel Serie 320 40GB als Rapid Storage SATA2
HDD: 2x Samsung 750GB auf Raid 0 SATA2
OS: Windows 7 64bit Ultimate
TESTs:
Benchmark mit HW Schaltern Aktiv und BIOS Aktiv (TPU EPU)
Benchmark mit HW Schaltern Deaktiviert und BIOS Aktiv (TPU EPU)
Benchmark mit HW Schaltern Deaktiviert und BIOS Deaktiviert (TPU EPU)
Benchmark mit HW Schalltern Aktiv und BIOS Deaktiviert (TPU EPU)
Ergebnisse:
Alle ergebnisse werden in der Reihenfolge abgegeben. Benchmarks die verwendet werden PCMARK07 - Street Fighter mit alles auf MAX.
Die Ergebnisse und Screenshots kommen heut abend dann raus. ^^
Euer Val.
Da ich nicht ständig an den Settings herumspielen möchte (eigentlich nie, wenn einmal alles eingerichtet ist), braucht es diese vielen Programme nicht.
Asus Probe ist noch ganz brauchbar, aber der Rest? Hmm...
Bleibt natürlich alles jedem einzelnen überlassen.
Ich finde den "Fan Xpert" (oder so ähnlich) eine tolle Sache, da man damit ganz nach Gusto die Lüfterdrehzahl einerseits für den Normalbetrieb (mehr oder weniger durchgehend Leerlauf) so niedrig wie möglich, andererseits für hohe Dauerbelastung (Spiele?) so hoch einstellen kann, wie für ausreichende Kühlung erforderlich.
Komischerweise habe ich noch ein 0221 BIOS auf meinem Pro.
Dort funktioniert der RST tadellos. Der AS SSD Bench ergibt die gleichen Werte wie auf meinem alten 775 Board. PCI-E hat auch 16lanes, nur das mit den USB 3.0 hab ich auch das, das erst ab Windows funzt.
attachment.php
Guten Abend, heute kam mein P8Z68V-Pro an und ist nun auch eingebaut.Es hat ein P8P67 Evo-B2 ersetzt.Jetzt aber zu meinem Problem- will unbedingt die eingebaute Grafikkarte des 2600K nutzen und fuer die Spiele dann meine 5870@Cata 11.5.
Der Monitor haengt am Mainboard und ich hab auch ein Bild nur leider sagt mir der Geraetemanager "Für dieses Gerät sind nicht genügend Ressourcen verfügbar. (Code 12)
Wenn Sie dieses Gerät nutzen möchten, müssen Sie ein anderes Gerät mit Anschluss an den Computer deaktivieren." Darauf hab ich die ATi im Manager deaktiviert aber das hat nicht geholfen.
Im Bios hab ich IGP eingestellt 64 MB und Lucid als Aktiv gesetzt.Kann mir noch jemand weiter helfen? Dieser Lucid treiber laeßt sich auch erst installieren wenn 2 funktionierende Grafikkarten gefunden werden so steht es jedenfalls grob uebersetzt wenn ich das Setup starte.
Mfg
Thorsten
//Edit: Hab jetzt die ATI Treiber deinstalliert und die Karte dann ausgebaut.Leider immer noch die selbe Fehlermeldung im Geraetemanager.Was fuer Ressourcen will der von mir??Hab ich nen 2600K mit defekter Grafikeinheit?
Servus @ Thorsten73,
also wenn die Graka funkioniert muss du folgendes noch tun.
Ab ins Bios und iGPU Aktivieren und dein Monitor kabel ans Board stecken!
Falls du nach dem umstellen von Graka auf iGPU kein bild siehst. DAS ist normal!
Bis 10 Zählen und Rechner ausschalten! Kabel ans Board klemmen und dann die Intel Treiber installieren und danach die Lucid.
Zusammengefasst:
1. Bios auf iGPU stellen
2. Speichern der Einstellungen im Bios
3. Bis 10 Zählen und PC Aus machen
4. Kabel ans Board klemmen
5. Intel Graka Treiber installieren und danach Lucid Treiber
6. Fertig!
Gruß Val.
p.s. Viel spass mit deinem System ^^
Ich denk mal sein Fehler, war eben dass er nicht dran gedacht hat, dass erst für de iGPU ein Intel Grafiktreiber installiert werden muss. (ist mir auch passiert)
Hallo Valvaris, so oder so aehnlich hab ich das ja auch gemacht aber im Geraetemanager hab ich nen gelbes Ausrufezeichen und ich kann max. 800x600 einstellen.
Da hat ja der wechsel von AMD im Januar auf das Intel System besser und reibungsloser geklappt ohne das Windows neuzuinstallieren.
Mfg
Thorsten
Wo sollte man seinen Monitor denn eigentlich anschließen?
Am DVI Ausgang der Grafikkarte oder am DVI Ausgang des Boards?
Wo liegen die Vorteile bei welcher Lösung?
Momentan habe ich den Monitor an der Grafikkarte angeschlossen.
Ich kann keinen Vorteil erkennen, wenn ich ihn ans Board anstöpsele.
also ich hatte es eigentlich so verstanden dass man die schalter dann bentutzt wenn man das board hardwaremässig dazu veranlassen will die nötigen parameter für stabiles EPU und OC festzustellen und dann damit neu zu booten..ohne es im bios zu machen..weil man zb. nicht ins bios kommt, die rams spacken oder was auch immer.,,kann mich irren.
@plauzi am board ist es dafür da lucid virtu und optimus zu benutzen wenn man auch ne dedizierte graka drin hat...am ausgang deiner grafikkarte
kannst du damit nicht arbeiten...muss durchs board gehen.
Wie auch immer.
Ich habe gestern ein wenig getestet.
Selbst, wenn ich das OC nur im BIOS durchlaufen lasse, genehmigt sich das Board bei jedem Kaltstart zwei Anläufe, bis es endlich bootet. Egal, ob der TPU Schalter auf dem Board EIN oder AUS ist.
Ich denke, das ist noch ein Bug im 0501er BIOS.
Und was bringt es mir?
Ich suche den Vorteil. Ich sehe keinen.
Wenn ich volle Grafikkarten Power haben möchte, muss ich die Grafikkarte eh nutzen. Also kann ich den Monitor immer an der GraKa anschließen.
Mache ich "nur" Textverarbeitung, drehen die Lüfter der GraKa eh schön langsam, sodass man sie kaum hört.
Nutze ich den Board-Anschluss, ist meine GraKa ja nicht abgeschaltet, sondern läuft trotzdem noch "light" mit und die Lüfter drehen ebenfalls.
Also irgendwie null Vorteile. :confused:
Auch die Vorteile eines Lucid Virtu wollen sich mir nicht erschließen.
"Optimus" sagt mir jetzt gar nichts.
Entschuldigt für den Test Ablauf, PCMARK hat einige Schwirigkeiten gemacht und lässt sich nicht Problemlos mit Lucid Testen. Hatte gestern 4 Stunden verbracht dies mit Futuremark zu klären was für eine konfiguration am sinnvollsten währe. Erwarte bis jetzt noch eine Antwort.
Sonst kann ich dies Anbieten das ich Spiele Benchmarks zuerst durchlaufen lasse da PCMARK je nach konfiguration eine Halbe Stunde dauern kann.
Danke für die Errinerung @GaBBa-Gandalf ^^
Gruss Val.
iGPU ganz einfach erklärt. ^^ Oder ^^ mal anders.
Reusper Reusper.......
iGPU hat zwei Modi zur auswahl.
Skizze:
Mode 1 (Energie Sparer)
Monitor----->iGPU (Board Anschluss)----->Falls ein Programm Läuft das in der Lucid Virtu aufgelistet ist!------>Eingebaute Graka. (3D Games Zokkkkkeeeennnnn... ^^)
Mode 2 (3d Gamer)
Monitor----->Eingebaute Graka. (Anschluss an Graka.)---->Falls ein Transcoder der in Lucid Virtu aufgelistet ist!----->iGPU zum Transcodieren (QSync) = (Zokken und gleichzeitig Transcodieren ohne einbussen von Graka Leistung!)
Fazit:
Willste Strom sparen und nur die Graka verwenden wenn Notwendig Mode1.
oder
Willste Zokken bis der Artzt kommt und gleichzeitig Video Transcodieren Mode2.
Zur installation von Mode1 und Mode2 ist es wichtig das Beide Treiber installiert sind von der Graka. (ATI/NVIDIA) und die Von INTEL.
Bekannt ist das Virtu schwirigkeiten hat mit Grakas. die mit Dual GPUs bestückt sind!
Damit jeder zum genuss kommt erkläre ich hier meine Schritte wie ich mein System für Virtu ready gemacht habe.
1. Monitor an Graka angeschlossen
2. Im OS die Treiber von ATI/NVIDIA installiert
3. Neustart
4. Ins BIOS und iGPU aktiviert und iGPU als Haupt Graka ausgewählt! VORSICHT: Die eine Einstellung aktiviert den Prozessor IGPU und die Andere sagt von wo es angeschlossen werden soll!!!
5. Einstellungen Speichern und Neustart.
6. Schwarzes Bild 10sec. Warten und per Knopf ausschalten!
7. Monitor ans Board anklemmen DVI/VGA ist egal eins von beiden halt
8. Treiber von Intel installieren
9. Neustart
10. Virtu installieren
11. Neustart
12. Fertig und PC ist für Mode 1 konfiguriert. ^^
Viel Spass und Viel Erfolg beim installieren wünscht euch Val. :d
Da schaut man mal eine Woche nicht rein und schon gibts einen Sammelthread für Z68er...
Gleich mal was zur CPU Kompatibilitätsliste:
Der Thermalright Archon passt problemlos aufs Board.
1. RAM Slot ist auch nutzbar!
Ansonsten habe ich die üblichen Probleme:
- Internal PLL muss deaktiviert sein, damit der Rechner aus dem Standby erwacht
- Zudem kommts in 10-20% der Fälle nach einem Kaltstart vor, dass der Rechner nach dem Biosscreen einfach hängen bleibt (blinkender Cursor). Manchmal muss ich dann 2 mal neustarten, meistens reichts aber einmal.
Habe aber aktuell noch das 8801 Betabios drauf. Werde die Tage mal noch die anderen testen.
Ansonsten läuft alles zufriedenstellend und sehr stabil.. Einzig die CPU Lüfter Steuerung könnte gerne etwas flexibler sein, sprich weniger RPM im Idle. Mein TY-140 läuft minimal mit ca 650rpm. Bei meinem Gigabyte UD4 B2 konnte ich ihn auch auf 550 laufen lassen.
Aber soweit ich es gelesen habe, geht das bei keinem der Asus Boards.
Aber den Mode 1.... bringt es wirklich was, wenn die Grafikkarte eh nicht komplett abgeschaltet wird? Dann braucht man doch diese Funktion nicht. Der Verbrauch einer heutigen Grafikkarte (zumindest bei AMD) ist doch im IDLE Modus extrem gering. Wazu also das Ganze? Ich seh da keinen wirklichen Nutzen.
Ich überlege mir gerade ein P8Z68 zu kaufen habe aber zwei Fragen, die mir die stolzen Besitzer hier evtl beantworten können:
a) Liegt der einzige Unterschied zwischen der normalen Variante und der PRo Version wirklich in ein paar mehr E-Sata und USB 3.0 anschlüssen? Wenn ja, würde ich eher das normale Board nehmen, da meine Peripherie recht neu ist und daher nur USB 2.0 kann.
b) Kann das BIOS den Rechner booten, wenn kein Strom am Netzteil anlag (hieß bei meinem früheren Asusboard Startup after Power Loss oder so)? Finde ich eine enorm praktische Funktion, da ich den PC so über die Steckerleiste anschalten kann.
Danke,
HdS
Mal eins vorweg........
danke für euer vertrauen. ^^
Also laut recherche hab ich dies gefunden:
"How Virtu GPU Virtualization Works
Lucid Virtu software is able to assign tasks in real time to the best available graphics resource based on power, performance and features considerations, with no need for additional hardware. If high end graphics power is needed for applications like DirectX 11, high-resolution 3D gaming, the system will assign the job to the discrete GPU. If not, the discrete GPU automatically goes into idle mode, while heat drops, fan speed slows down and GPU utilization goes down to zero, resulting in a green, power-efficient, long-lasting system."
Quelle: Lucidlogix
Sprich die eingebaute Graka. wird nicht beansprucht somit im sogenannten Standby (Nicht Deaktiviert). Daher geringerer Stromverbrauch und Langliebigkeit der Hardware!
Virtu ist halt für die da die Sehr viel Multitasking betreiben.
Anwendungsbeispiel:
Ich selber Produziere eLearning videos während die Transcodiert werden Zokke ich gerne nebenbei. Mit SandyBridge und Virtu kein Problem. Ohne rukkler und zieher zum Gaming erfolg und das Video dannach sieht spitze aus. Ist auch für die gedacht die mit Fraps arbeiten und andere Screencasting Tools.
Normale Anwender profitieren von der Langliebigkeit der Investition und die geschwindigkeit wenn man alles was das Board bietet auch nutzt. ^^
Gamer haben durch Lucidlogix Virtu eine Stromsparende lösung denn nicht jeder zokkt nur am PC und geht mal gern ins Youtube dabei kann auch beides Laufen ohne einbusen. ;)
Sollte so langsam mich für Lucidlogix bewerben h3h3h3h3h3h3h3
Euer Val.
---------- Beitrag hinzugefügt um 15:04 ---------- Vorheriger Beitrag war um 14:57 ----------
MOD entschuldige für den Doppelpost?
@HdS
Also 2 SATA3 Ports weniger und das was du schon gemeldet hast fehlen bei der Günstigeren variante.
zu B ja das Board hat die möglichkeit ist aber nicht empfehlenswert dies so zu Nutzen. Da du so ein Netzteil schwer beschädigen kannst. Wenn du dein Monitor zum Beispiel aus haben willst und andere Peripheri - Kauf dier ein Master - Slave Steckerleiste.
Durch das anschalten von PC geht aufeinmal alles andere auch an!
Gruss Val.
Wieso kann man das NT damit schwer beschädigen?
Kann mich jetzt nicht erinnern jemals damit Probleme gehabt zu haben und mache das seit ca ~5 Jahren.
Machen tue ich es, weil ein PC auch "aus" sonst noch extrem nervige LEDs an hat.
Hätten PCs noch vernünftige An/Aus Taster, könnte man Master-Slave Dosen verwenden, aber so geht das leider nicht.
@ Valvaris
Ich habe deine Schritte zum Einrichten mal im Startbeitrag festgehalten.
@ basti2910
CPU-Kühler im ersten Beitrag mit aufgenommen.
