[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [2]
Chrisch
Legende
Münsterland
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
die cpu ist bis 1,5v zugelassen und du wirst es nicht glauben aber es gibt leute, die kaufen sowas und machen garnix im bios! die ham dann wohl pech wenn alles auf auto is und er sich im turbomodus hochtaktet und auch die spannung mit anhebt oder wie?
Die haben dann halt alle luffis auf max und schöne hohe temps und mit n bissl pech auch ab un zu mal n absturz im sommer, wer sich n Crosshair IV und n 1090T kauft der wird sich schon die spannungen manuell einstellen.
Aber wie ich hier sehe sind wir unterschiedlicher Meinung und ich sag dann mal, jedem das seine.
man bist du begriffstutzig oder was ,es ist doch nicht nur die vcore ,den kannste auch auf 1.6V stellen da passiert nichts ,aber alle anderen spannung muss du vorsichtig sein ,soll ich die jetzt die ganzen spannungen aufzählen oder was
die cpu nB wenn du die übertaktest ,geht auf knappen 1.5V hoch wenn du auf auto stehen lässt ,aber 1.4V ist es nicht mehr gesund,dann habe ich auch geschrieben wenn du auf auto stehen lässt dann dann stimmen nicht unbedingt die angaben vom auslesetool ,also nachmessen ,weil in wirklichkeit bei mir dann 1.55V anliegen ,das heisst aber nicht das es jedes board macht ,nur wer übertaktet muss man warnen mit auto spannungen
du weißt aber schon das die farblich gekennzeichnet sind im bios? und ich schreibs für dich noch ein drittes oder viertes mal.... wenn man sich vorsichtig rantastet und nich gleich volles rohr loslegt, dann geht das in ordnung. ansonsten komm her und ich zeig dir das und du zeigst mir dann welche spannung zu hoch ist!
desweiteren gibts diese hardware combo auch als komplettsysteme und ich glaub kaum das sich die leute dann freuen wenns da abstürze gibt oder die kiste lärmt wie blöde weil dann wird se nämlich zurück geschickt...
naja du bist ein hoffnungsloser fall ,auch im bios die angezeigte spannungen passen nicht immer bei auto .ich habe alle spannungen nachgemessen und habe grauenhaffte spannungen festgestellt ,aber du bist hier die aussnahmen ,ich glaub du bist mein held
an deiner stelle unterhalte dich mal mit richtige freaKS wie octacore
ich red nich nur von den angezeigten im bios... aber freut mich wenn ich dein held bin. desweiteren bin ich nie an die angegebenen 1,5 rangekomm, auch nich über 1,4... und wenn alles so schlimm wäre, könnte man ja die hersteller verklagen, weil so mutwillig hardware kaputt gehn kann...
Abend zusammen
Frage:
die Spannungswerte die man im BIOS einstellen kann mit Plus/Minus Taste ( anstatt Auto :cool:)
Sind die Werte das Absolutwerte oder werden die zu den angegebenen Voltwerte dazu addiert??
Danke im vorraus
MfG:wink:
die werden addiert bzw subtrahiert, je nachdem ob plus oder minus
Es gibt zwei Modi, einmal wo man den absoluten wert eingibt und einmal den wo man den Wert addiert oder subtrahiert werden, der zweite müsste sich offset nennen.
Sprich wenn davor in grau 1,25V steht und der Wert in der Klammer den ich verändere z.Bsp.: [0,25V] dann ist der richtige Wert 1,5V
habe ich das richtig verstanden?? :confused:
muss ich den Modi selbst festlegen oder??
Dann wäre ja der Absolutwert Modi besser/Übersichtlicher
Danke
MfG
Wenn du im offsetmodus bist dann ja, dann kommen 1,5V an
Ich hab den "normalen" modus, tippe alle Voltwerte ein die ich gern hätte und dann passt es.
wieso mutwillig ,offiziell verlierst du jegliche garantie und solange alles orginal läuft dann funzt das auch mit den auto spannungen ,also vergleich kein Äpfel mit Birnen
ich mache alles im offset ,weil ich mit K10stat arbeite
ja nee is klar, verlierste de garantie, deswegen wird der 1090 zb ja auch als BE verkauft.... nu wird deine these bissl brühe mein guter...
bei manuell ,senkt sich aber die spannung im idle nicht ,ich verstehe nicht wieso ihr das nicht nutzt ,mit allen stromsparfunktionen sind es 50-80W weniger die er brauch und der rechner läuft doch die meiste zeit im idle ausser wenn ich zocke da darf er auch strom brauchen und ich lasse mein auch mit 4ghz rennen
Ich hab einfach 1,25V eingestellt, unter last kommen bis zu 1,28V an und im Idle geht es runter auf 1,22V, sollten aber die Abweichungen der LLC sein. Da ich den Strom aber eh noch recht billig bekomme dann isses mir noch egal. Nächste Woche hab ich aber frei dann werd ich mir auch mal den offset anschaun.
Hallo tim_s007,
Ich habe die 4000 MHz über den Multi eingestellt.
Wofür hat denn den freien Multi?
Cool & Quiet funktioniert nur mit CPU Offset Voltage.
Wenn du den Offset wählst, solltest du ihn keinesfalls
auf Auto belassen.
Nimm am besten denn kleinsten positiven Offsetwert.
wann du dich für manuel entscheidest,
ist das Cool & Quiet ausgeschaltet.
---------- Beitrag hinzugefügt um 23:55 ---------- Vorheriger Beitrag war um 23:15 ----------
Was versteht Asus oder ein anderer Hersteller eigentlich unter AUTO-Einstellung.
Jede CPU hat je bekanntlich eine andere Vcore-VID und das dürfte meiner Meinung
die einzigste Kenngrösse sein, nachdem ein Brett-Hersteller die AUTO-Werte im
BIOS einstellen kann.
Oder glaubt ihr etwa das Asus tausende von CPU's getestet hat, um auf die korrekten
Spannungen für eine vom Benutzer angelegte Taktfrequenz zu kommen.
Ich hoffe auf zahlreiche Rückmeldungen und lasse mich auch gerne eines Besseren
belehren.
Gruss Lucki67
natürlich nicht
@SmokeySkull,du bist wirklich unbelehrbar ,wo steht geschrieben das du garantie behälst wenn du übertaktest ,natürlich muss man sich die frage stellen ,können sie es feststellen
aber bitte tu mir ein gefallen und überlege erst ,bevor du hier losschreibst ,das ist jetzt auf dein satz bezogen:ja nee is klar, verlierste de garantie, deswegen wird der 1090 zb ja auch als BE verkauft.... nu wird deine these bissl brühe mein guter...
hier extra für dich und lese genau ,die ist noch immer gültig
Prozessor-Garantie -
Hallo an betreffenden,
Macht euch mal locker, immer schön geschmeidig bleiben.
Wir alle in diesem Forum wolen doch von den Erfahrungen der anderen
profitieren/lernen.
Das geht aber alles sehr viel besser, wenn der Umgangston passt.
Gruss Lucki67
soo...vor wenigen Stunden bin ich endlich mit dem Umbau meines Systems fertig geworden ^^
Aber bis ich es geschafft hatte mal Win 7 überhaupt zu installieren -.-
Habe nun eine wichtige Frage:
Die SATA Ports 1-4 sind bei mir auf AHCI eingestellt. An Port 1 hängt die SSD und an Port 2 die HDD. Meine HDD wurde aber nicht im Arbeitsplatz angezeigt, dann habe ich halt über die Datenträgerverwaltung das manuell geregelt das sie agezeigt wird und ihr auch einen Laufwerksbuchstaben zugeteilt + formatieren lassen.
Sorry hatte bisher nie mehrere HDD´s gleichzeitig am laufen, deswegen ist es auch noch ein weiteres Neuland für mich SSD + HDD
Ist das so richtig ?
Welche Treiber habt ihr denn alles von dieser Asus CD installiert ?
Habe eine Crucial RealSSD C300 64GB SSD.
Ich lass das System jetzt erst mal so laufen, mache heute Mittag die restlichen Programme und Spiele drauf. Wenn das System stabil ist, wird océd.
Hier mal meine idle Temps @Asus Probe
CPU: 36°C
MB: 37°C
NB: 50°C
SB: 43°C
Sind die in Ordnung ?
Die Spannungen sind alle auf auto. etc. etc.
Edit: Hier noch ein ASSD Benchmark. Sind die Werte in Ordnung ?
[url=http://www.abload.de/image.php?img=ssdbench21r2.png][/URL]
Ich habe mir vor die aktuelle C'T-Ausgabe zu Gemüte geführt.
Mein Fazit: Ambizionierten Übertaktern würde ich den Artikel
'Prozessoren:Kernspannung vs. Taktfrequenz' wärmstens ans Herz legen.
Gruss Lucki67
