Whitecker007
Legende
Wenn ich das Geld hätte sofort,aber hab immoment 0 Money gib ma bitte den Link zu JZ wenn ich mir späöter dann eins kaufen willl hol ich mir da nochmal eins.
Am Limit? Hä? Da geht noch ein klein wenig!![]()
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 8,0x
Fine CPU Clock Ratio...................: 0,5
CPU Frequency .........................: 3825Mhz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 450MHz
PCI Express Frequency (Mhz) .........: 100Mhz
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive.......................: 800mv
PCI Express Clock Drive...............: 900mv
CPU Clock Skew (ps)...................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance....................: [turbo]
Extreme Memory Profile (X.M.P.)........: disabled
(G)MCH Frequency Latch.................: 400
System Memory Multiplier ..............: 2.66b
Memory Frequency (Mhz) ................: 1200Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time..............................: 6
tRCD .........................................: 5
tRP'..........................................: 6
tRAS..........................................: 16
Advanced Timing Control [Press Enter]
tRRD....................................: Auto
tWTR....................................: Auto
tWR.....................................: Auto
tRFC....................................: Auto
tRTP....................................: Auto
Command Rate (CMD) .....................: Auto
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.............11......: 9
tRD Phase0 Adjustmen.............0.....: Auto
tRD Phase1 Adjustment.............0....: Auto
tRD Phase2 Adjustment ............0....: Auto
tRD Phase3 Adjustment.............0....: Auto
Trd2rd(Different Rank)............6....: Auto
Twr2wr(Different Rank)............6....: Auto
Twr2rd(Different Rank)............5....: Auto
Trd2wr(Same/Diff Rank)............8....: Auto
Dimm1 Clock Skew Control...............: Auto
Dimm2 Clock Skew Control...............: Auto
DDR2 Write Training....................: Auto
Channel A Driving Settings [Press Enter]
Driving Strength Profile...............: Auto
Data Driving Pull-Up Level.............: Auto
Cmd Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Up Level.............: Auto
Clk Driving Pull-Up Level..............: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down Level...........: Auto
Ctrl Driving Pull-Down Level..........: Auto
Clk Driving Pull-Down Level...........: Auto
Channel B
Channel B Timings Settings [Press Enter]
Static tRead Value......................: 9
tRD Phase0 Adjustmen.....................: Auto
tRD Phase1 Adjustment....................: Auto
tRD Phase2 Adjustment ...................: Auto
tRD Phase3 Adjustment....................: Auto
Trd2rd(Different Rank)..................: Auto
Twr2wr(Different Rank)..................: Auto
Trd2wr(Same/Diff Rank)..................: Auto
Channel B Driving Settings [Press Enter]
Data Driving Pull-Up Level..............: Auto
Cmd Driving Pull-Up Level...............: Auto
Ctrl Driving Pull-Up Level..............: Auto
Clk Driving Pull-Up Level...............: Auto
Data Driving Pull-Down Level...........: Auto
Cmd Driving Pull-Down Level............: Auto
Ctrl Driving Pull-Down Level...........: Auto
Clk Driving Pull-Down Level............: Auto
{U]Motherboard Voltage Control{/U]
Loadline Calibration.………...........: disabled
CPU Vcore….……….....................: 1,38750V
CPU Termination…..... 1.200V*......: 1,26V
CPU PLL…………………....1.500V*..........: 1,50V
CPU Referen.…………....0.76V*.........: 0,838 (kontrolliert durch et6)
MCH/ICH
MCH termination...1.100V...........: 1,26V
MCH Reference….…….0.760V...........: 0,838 (kontrolliert durch et6)
MCH/DRAM Ref.…......0.900V.........: AUTO
ICH I/O……………….....1.50V............: 1,5V
ICH Core…………...……1.100V............: 1,1V
DRAM
DRAM Voltage ……....1.800V.............: 2,02V
DRAM Termination .…0.900V.............: AUTO
Channel A Reference 0.900V............: AUTO
Channel B Reference 0.900V............: AUTO
Die NB ist unter Wasser.
Und mit etwas mehr VTT hab ich kein Problem.
Hat hier jemand 9x500 mit 8GB Ram am laufen?
naja bleibt mal aufm teppich...wakü bringt schon einiges...aber trotzdem liegen da diese hohen spannungen an...das ist doch etwas arg. trotzdem jedem das seine
@whitecker
bei mir geht mit 1,26V für vtt alles von 450 bis 500
die mch austüfteln ist da eher so ne sache...wegen strap und den 8gb
aber so langsam glaube ich, dass ich meine 24/7 gefunden habe...an der stabilität wird noch etwas gefeilt....aber das sollte dann schon passen. vor allem geht der s3 noch :muhar:
Code:MB Intelligent Tweaker(M.I.T.) Robust Graphics Booster ...............: Auto CPU Clock Ratio .......................: 8,0x Fine CPU Clock Ratio...................: 0,5 CPU Frequency .........................: 3825Mhz Clock Chip Control Standard Clock Control CPU Host Clock Control..................: [Enabled] CPU Host Frequency (Mhz) ............: 450MHz PCI Express Frequency (Mhz) .........: 100Mhz C.I.A. 2.......................................: Disabled Advanced Clock Control [Press Enter] CPU Clock Drive.......................: 800mv PCI Express Clock Drive...............: 900mv CPU Clock Skew (ps)...................: 0ps MCH Clock Skew (ps)...................: 0ps DRAM Performance Control Performance Enhance....................: [turbo] Extreme Memory Profile (X.M.P.)........: disabled (G)MCH Frequency Latch.................: 400 System Memory Multiplier ..............: 2.66b Memory Frequency (Mhz) ................: 1200Mhz DRAM Timing Selectable ................: [Manual] Standard Timing Control CAS Latency Time..............................: 6 tRCD .........................................: 5 tRP'..........................................: 6 tRAS..........................................: 16 Advanced Timing Control [Press Enter] tRRD....................................: Auto tWTR....................................: Auto tWR.....................................: Auto tRFC....................................: Auto tRTP....................................: Auto Command Rate (CMD) .....................: Auto Channel A Channel A Timings Settings [Press Enter] Static tRead Value.............11......: 9 tRD Phase0 Adjustmen.............0.....: Auto tRD Phase1 Adjustment.............0....: Auto tRD Phase2 Adjustment ............0....: Auto tRD Phase3 Adjustment.............0....: Auto Trd2rd(Different Rank)............6....: Auto Twr2wr(Different Rank)............6....: Auto Twr2rd(Different Rank)............5....: Auto Trd2wr(Same/Diff Rank)............8....: Auto Dimm1 Clock Skew Control...............: Auto Dimm2 Clock Skew Control...............: Auto DDR2 Write Training....................: Auto Channel A Driving Settings [Press Enter] Driving Strength Profile...............: Auto Data Driving Pull-Up Level.............: Auto Cmd Driving Pull-Up Level..............: Auto Ctrl Driving Pull-Up Level.............: Auto Clk Driving Pull-Up Level..............: Auto Data Driving Pull-Down Level..........: Auto Cmd Driving Pull-Down Level...........: Auto Ctrl Driving Pull-Down Level..........: Auto Clk Driving Pull-Down Level...........: Auto Channel B Channel B Timings Settings [Press Enter] Static tRead Value......................: 9 tRD Phase0 Adjustmen.....................: Auto tRD Phase1 Adjustment....................: Auto tRD Phase2 Adjustment ...................: Auto tRD Phase3 Adjustment....................: Auto Trd2rd(Different Rank)..................: Auto Twr2wr(Different Rank)..................: Auto Trd2rd(Different Rank)..................: Auto Trd2wr(Same/Diff Rank)..................: Auto Dimm1 Clock Skew Control...............: Auto Dimm2 Clock Skew Control...............: Auto DDR2 Write Training....................: Auto Channel B Driving Settings [Press Enter] Driving Strength Profile...............: Auto Data Driving Pull-Up Level..............: Auto Cmd Driving Pull-Up Level...............: Auto Ctrl Driving Pull-Up Level..............: Auto Clk Driving Pull-Up Level...............: Auto Data Driving Pull-Down Level...........: Auto Cmd Driving Pull-Down Level............: Auto Ctrl Driving Pull-Down Level...........: Auto Clk Driving Pull-Down Level............: Auto {U]Motherboard Voltage Control{/U] Loadline Calibration.………...........: disabled CPU Vcore….……….....................: 1,38750V CPU Termination…..... 1.200V*......: 1,26V CPU PLL…………………....1.500V*..........: 1,50V CPU Referen.…………....0.76V*.........: 0,838 (kontrolliert durch et6) MCH/ICH MCH termination...1.100V...........: 1,26V MCH Reference….…….0.760V...........: 0,838 (kontrolliert durch et6) MCH/DRAM Ref.…......0.900V.........: AUTO ICH I/O……………….....1.50V............: 1,5V ICH Core…………...……1.100V............: 1,1V DRAM DRAM Voltage ……....1.800V.............: 2,02V DRAM Termination .…0.900V.............: AUTO Channel A Reference 0.900V............: AUTO Channel B Reference 0.900V............: AUTO
so kann ich das system vor allem noch sehr kühl mit der wakü gehen und extrem leise, sogar unter volllast!
der unterschied zw. fsb475+strap333 und fsb450+strap400 ist marginal...habe dafür den mittelwert aus 3 läufen gebildet-> getestet wurde cinebench, 7zip (komprimierung), nerovision (testvideo)
von daher war die entscheidung dann recht simpel...werde jetzt mal gucken was aus den settings noch rauszuholen ist...die frage ist wo fange ich an...die vtt senken???
@mr.bo
habe je nun das große glück, dass mein ram bis 1200 geht...mit akzeptablen latenzen...das bringt mir ne menge spielraum
Ich hab 1.28 VTT 24/7is das schlimm?
@shortyhamma ^^ Quälen macht spaß wa
Werde es mit deinen Latenzen auch mal testen. Bislang nur auf 5-5-5-15 bzw 18 gewesen. Vieleicht geht ja noch was
Testest du auch mit Everest deinen Speicherdurchsatz, oder entscheidest du nach den von dir genannten Programmen ?
hab heute neuen Lüfter für den cpu kühler geholt extra nur zum benchen weil die Temperaturen so hoch gingen was das so bringt echt hammer bild1 gekühlt mit s-flex 1200 rpm bild2 mit ultra kaze 3000 rpm( so laut wie ein staubsauger)
daher hab ich 2 x Slipstream die bis zu 1900 RPM gehen. Aber für den Alltag reichen 900 rpm
ne die kann man wirklich nur zum benchen reinmachen 45 dba das hält man nicht aus aber kühlt unheimlich wollte unbedingt die 4,5 ghz schaffen glaub aber hier ist schluss mein board limitiert bei 4,4 ghz mehr geht nicht primestabil mit ud-3 aber ist auch schon was denke ich
) geht nur auf 1000 RPM, wenn ich den niedriger einstell geht der sofort aus
ich liebe meine Lüftersteuerungcinebench in 64bit...
wert bei 3,8ghz +fsb750 + strap333 + turbo + ddr2 1140+ 6-5-6-16 + pl9
16666 punkte (x-cpu test)
