Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
Ich installier grad mal Vista auf ne Test HDD und guck obs anders ist, ansonsten hat DFI wohl mal wieder nen Triplecore Problem -.-
Durch ne Neuinstallation von Vista wurde das Problem auch behoben... liegt also nicht am DFI.
Ich denk, dass die NB auch nur so heiß ist, weil sie mit den PWMs verbunden ist... anders kann ich mir den ziemlich konstanten Abstand nicht erklären ^^
