[Sammelthread] DFI LANparty UT 790FX M2R / M2RV (AMD 790FX) [1]
Dfi LANParty UT790FX M2R/M2RV
***sammelthread***
I. Allgemeine Infos zum Chipsatz
II. Technische Details zum Board [UT790FX M2R/M2RV]
CPU
# AMD® Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
# Socket 940 AM2 65nm
# HyperTransport 3.0 and 1.0
Chipset
# AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB600
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667 and DDR2 800 DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
# 1 PCI Express x4 slot
# 3 PCI slots
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit flash memory
Audio
# Bernstein audio module - Realtek ALC885 8-channel HD Audio Codec - High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight) - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Serial ATA with RAID
# AMD SB600 - Supports up to 4 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
# Silicon Image SiI3132 - Supports up to 2 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 2 connectors for 4 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system boot-up
PCB
# ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Tests Review´s sammelthread
Review von Ninjalane.com: klick
V. Sonstiges
VI.Impressionen
VII. Layout
[UT790FX M2R/M2RV LT]
VIII. OC Liste
IV. Downloads/Links
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
mmh komisch. k.a... aber warum nutzt du den SIL?
Hatte mal irgendwo gelesen, dass man besser am Sil anschließen sollte, damit die SB ein bisschen entlastet wird.
Hab auch mal mit HD-Tune getestet und der Sil hat nen viel gleichmäßigeren Datendurchsatz.
Am AMD hatte ich zwar im Schnitt 140MB/s, aber der hat immer totale Einbrüche gehabt.
Sil hat 120MB/s aber viel gleichmäßiger und mein Sys is in ca. 25Sek gebootet.
AMD hat schon mal so 60Sek gebraucht, weil er immer wieder gestockt hat ...
Wo ist der neue Thread?
EDIT:
Problem gelöst!
Der Sil gibt die Größe der Laufwerke nicht in GB sondern in GiB an!
Nee, liegt am BIOS!
Ich bekomme ja schon beim erstellen des RAIDs nur 465GB angezeigt.
Da is der Treiber noch nicht aktiv ...
joa stimmt..
Stimmt, der selbe Fehler ist mir gestern in meiner OC Session auch aufgefallen.... und ich wunder mich, warum 3,9GHz im Windows abstürzen :fresse:
Naja, taugt halt nix, das Programm :d
Jo, probiers aus ;)
Hat jemand ne Ahnung wie die CPU Stepping Funktion (P0-P3) im CPU Menü zu verstehen ist? Ich kann mir denken, dass es was mit den P-States zu tun hat, aber wie nutze ich die Funktion im BIOS genau? Vielleicht gehts ja damit sogar angenehmer als mit K10STAT... ^^
nee, man kann nur mit abgesenkter spannung und takt booten. kann nützlich sein, um erstmal ins win zu kommen (für benches u.ä.)
im win wird dann der p-state normal gesetzt, der cnq-einstellung entsprechend...
Die Platten am Sil anzuschließen war aber ne gute Entscheidung!
Chipsatz-Temps sind nicht mehr so hoch und wie bereits geschrieben, laufen die Festplattenzugriffe irgendwie schneller und gleichmäßiger ab.
3,9 :d lool da muss ich schon 1,6V auf die cpu geben damit ich da ins windows komm :(
hab mal 2 fragen zu dem bios
wo stellt man dort 2.0 bei den grafikkarten ein bekomme immer nur 16/16 angezeigt
und was hat es mit dem CPU p0 p1 einstellungen auf sich
Yari
hat wer von euch das smart dings von DFI da unter win7 zum laufen gebracht?
Yari
1: pcie settings -> gen 2.0 setting auf autonomous switch stellen. und dann zweimal booten..
2: ist ein p-state den du wählen kannst während des boots. man kann damit "mit handbremse" ins win booten und dann erst "startet er durch".. so oder so ähnlich.. cnq fürs bios...
wow nicht schlecht was der da hinzaubert
siehe pm.. das fxb ist die sb750-version.. dafür gibts nen separaten thread..
krank klasse preis hey
Ich hab mein Sapphire für den gleichen Preis von Pixxum bekommen!
War ne ebay-Auktion und is schon sechs Monate her!
Eins ging sogar für 56,- weg ... :fresse:
echt übel. erst super lange nicht lieferbar und jetzt das ;)
Und ich hab mir das Sapphire im April für 99€ gekauft und mich gefreut^^
