[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
naja dann ich habs mal versucht aber 50 posts sind ja gleich zusammen
hmm hat von euch schon mal einer nen q9550 mit über 500fsb stabil zum laufen bekommen
so ab 495 geht bei mir garnichts mehr
hat jemand eine Idee warum ich immer Prime95 Blend Errors kriege @400FSB?
An den Speichern liegt nicht, die laufen.
Klar dank Gedankenübertragung ist das recht einfach geworden. *Ironie aus*
Bei welchen Tests kommen die Errors und kommen sie immer auf dem selben Core oder verteilt?
Nen bissel mehr Info wäre nicht schlecht!
Ich schmeiße einfach nur den blend Test an und innerhalb von 20 Sekunden steigt min. ein Kern aus. Obs immer derselbe ist weiß ich nicht, müsst ich noch testen wenns entscheidend ist.
Einfach nur 400FSB eingestellt, hab sonst kaum was umgestellt. Wenn ich alles so lasse und auf 333 runtergehe läuft es.
Was braucht ihr denn für Infos?
Ist ein Q9550 mit 4GB 1600er Corsair, die aber auch schon auf 1333 Errors produzieren (aber eben nur mit 400FSB).
Versuch doch erstmal Large FFT mit 1024-6xx K, damit du den FSB ausschließen kannst. Vllt dann auch noch SuperPI 32M, Memtest und Small FFT (für CPU) :)
hi Alle,
hab jetzt auch die 2x2 GB OCZ XTC Platinium 2000Mhz bestellt.
berichte dann wenn ich sie hab!
web
System ist ein Q9550 und eben das Rampage Extreme + 4GB Corsair 1600er C9DHX.
Das seltsame ist mit 266FSB läuft alles, bei 400 FSB (oder 399/401) steigt ständig Prime95 blend aus.
So instabil ist das System jedoch nicht, da der 3DMark immer durchläuft. Hab nur die Prime95 Probleme.
Kann man da nicht was an Spannungen verändern? Hab mal ein bisschen getestet aber leider ohne Erfolg.
Hast du vorher schon mal Overclocked? Kann es schon sein, dass Prime nicht mehr läuft, jdf. nicht ohne Optimierungen deinerseits. Möglicherweise reicht die Vcore für den höheren Takt nicht, möglicherweise stimmen die Ram Timings nicht, NB Voltage oder ähnliches, halt dich am besten an einschlägige OC-Guides und geh erstmal die Prime FAQ durch die ich eben verlinkt habe!
Deines ist zwar ein Quad aber HIER könntest du auch mal schnuppern und mal einiges davon verwirklichen, ein FSB Sprung von 133 MHz ohne weitere Veränderungen ist schon ziemlich heftig...
Mein Quad macht zum Beispiel keinen FSB von 400 bei Standardsettings mit!
warum läuft es mit 333FSB ohne Probleme?
Stell ich auf 400 und den Speicher und die CPU per Multi auf das 333er Niveau oder noch weiter runter gibts sofort die Probleme.
Ist eigentlich nicht so schwer zu verstehen. 333FSB rennt 400 steigt Prime ständig aus.
Ich habe schon so viel probiert, nichts macht es stabiler, immer nach spätestens 20 Sek. Errors.
ganz ehrlich ich habe dir einiges zum lesen (zur hilfe!) gegeben, du dagegen gibst kaum Infos die wirklich was wert sind zur Beschreibung deines Problems, wie soll man dir da helfen, ausserdm glaube ich nicht, dass du innerhalb der letzten 10 minuten auch nur annähernd den Prime FAQ durchgelesen hast.
da steht alles drin
Und JA, es kann sein, dass ein CPU mit FSB 266 und 333 läuft und mit 400 MHz nicht.
Wer versteht hier eigentlich wen nicht?
Alternativ kann ich dir noch vorschlagen: da du so ein Fachmann zu sein scheinst, ich habe hier nen defekten Pentium 4 620 liegen, reparierste mir den? Wir tauschen einfach direkt, ich nehme deinen defekten Q9550 am besten schickste das defekte scheissboard gleich noch mit! für meine Adresse PN!
Das deckt sich aber nicht mit meinen Erfahrungen. Ich hatte schon so einige Quad/Mainboard Konstellationen die bisher entweder gar nicht auf 400 wollten oder eben out-of-the-box stable waren.
Das aber NUR Prime blend sofort abschmiert, und ALLES andere läuft, ist für mich was neues.
Prime small FFT läuft ohne Witz locker 3 Stunden durch und parallel der 3DMark. Schmeiße ich blend an, gibts direkt Errors. Was soll ich mir seitenlange Prime95 FAQs durchlesen? Ich overclocke schon seit RAMBUS Zeiten wenn dir das was sagt.
Ich habe schon P5E Deluxe, Striker II Extreme, Rampage Formula, EVGA780i etc. gehabt, und sowas seltsames noch nicht erlebt.
Das RE ist das erste Intel Board, bei dem ich auf einmal groß herumexperimentieren sollte - stimmt, gerade das kostet ja nichts und wird auch nicht explizit als OC-Board angepriesen. :stupid:
Ist das letzte Bios vielleicht fehlerbehaftet?
Also das Board macht auch die 480 mit nem Quad wie Du weist.
Die Frage ist was macht die CPU mit ?
Schreib mal deine Bioseinstellungen hier rein.
PS:nicht mehr am i7 Testen ?
Im Prinzip habe ich ich alles auf Auto bis auf den FSB, der ist manuell auf 400 gestellt.
Spannungen habe ich bei der CPU 1.25v und Loadline Calibration aktiviert. Die Speicher sind auf 1.8v gestellt.
OnBoard Sound ist aus wg. der X-Fi und die unnötigen Controller aus. Naja und eben QFan aktiviert.
Aber ich habs auch schon ohne probiert, ändert nichts.
Ich glaube immer mehr das Board ist defekt, hatte das auch mal bei meinem ersten Striker II da wollten 400FSB auch nicht, allerdings komplett nicht mit noPOST etc.
Spannungen auf Auto ist doch no way bei Asus.
Also Hopp alles auf den kleinsten Wert stellen, Vcore,Ram usw. anpassen.
NB Probier es mit 1.5V und die VTT auf 1.30 für den Quad, den Ram würde ich erstmal 1.9 geben.
Ich Spreche hier von ~FSB430.
Wenn Prime gleich bei 1024 abbricht kannst Du von Ram/NB ausgehen.
sorry will jetzt nicht ausfallend werden, aber schick es mir doch einfach zu, ich glaube ernsthaft du bist irgendwie in RAMBUS Zeiten stehengeblieben wenn dir das was sagt...
Mit "alles auf Auto" läuft sone Kiste halt nicht, aber mach mal nen RMA Fall draus dann haben die bei ASUS auch mal wieder was zu lachen auf taiwanesisch. "Hung wangchiquaia ton deutscha idiota" oder sowas dürften die sich dann erzählen.
Ich halte mich jetzt aus deinem Problem einfach mal raus. Ist mir ehrlich gesagt zu doof, das Problem oder du!?
kann mir jemand sagen wie sich die wasserkühlung auf dem board macht? ist sie gut, kühlt sie vernünftig und sinnvoll, oder ist es eher spielerei?
@ MiniMe1978
wenn Du ein gutes erwischt reicht die Lukü vollkommen aus.
werd ich gleich mal testen, danke.
EDIT:
Prime läuft so leider keine 5 Sekunden...
Schade, dass du mir auf meine Frage scheinbar keine Antwort geben kannst: :d
Warum läuft dann mein P5E Deluxe, das Rampage Formula und das EVGA 780i einfach so ohne Gefummel auf 400FSB obwohl das ja unmöglich ist mit "alles auf Auto"? Mein erstes Striker II Extreme hatte auch einen 400FSB Knacks, als das neue kam, ging alles wunderbar mit 400FSB und dem QX9770. Ich bin da nicht der einzige hier, Snoopy hier aus dem Forum kann das bestätigen:
Bei mir hat sich mein Problem nun entgültig erledigt. Mein SIIE ist einfach nur Schrott (FSB-Gurke)
Hab mir heut ein neues SIIE gekauft und benche gerade 450fsb mit dem QX9650. Ich denke, du weisst, dass das mit einem Quad schon ganz gut ist.
Einen Absolut-FSB hab ich noch nicht gefunden (ich teste weiter). Fakt ist aber, dass ich selbst bei 450MHz keinerlei GTLs verstellen musste. Genau so muss das sein
Bei meinem "Alten" erreichte ich (hakt dich fest) nur magere 350fsb und das nur mit hohem Aufwand (stundenlange GTL-Spannungs-Suche). Ich hab dafür gut EINE WOCHE meines Urlaubes verballert. ich dachte halt, dass das MB einfach nur kompliziert ist. Nein, es ist Schrott!!! Es schafft keinen FSB1600 (400) wie auf dem Karton angegeben.
Soviel zu unberechtigter RMA. Wenn 400FSB nicht laufen wie auf der Packung angegeben, dann sind die "Idioten" (um mal deinen Wortschatz zu nutzen) diejenigen, die das herstellen. Ende.
Mein P6T Deluxe packt 200 BCLK (falls dir das überhaupt was sagt) ohne auch nur eine einzige Spannung zu verstellen.
Das einzige was ich an Spannungen explizit einstelle, sind lediglich die RAMs.
Ich gerade einen QX9650 auf dem Board.
Also 400FSB stellen gar kein Problem dar.
So richtig zickig wird das Board ab 475 mit dem Quad.
Komme zwar bis 510 FSB ins Windows aber es wird nicht stable.
Habe allerdings auch 2x2GB drinne.
Für 467x9 mußte ich schon 1,64VNB geben.
GTL´s sind auf Auto restliche Spannungen für die CPU mußte selber anpassen.
Bei Auto haut das Board bei OC die FSB VTT auf 1,49V und die CPU PLL auf 1,69V.
Das meinte SGD02 damit.
Könnt ihr noch ein letztes mal drüberschauen:
Es läuft einfach nichtmal auf 400FSB.
sorry, ich will hier mal mit meinem Laienwissen versuchen zu antworten.
Ich meine, so wird das auch nix.
1) glaube ich, das fast jedes Board im mV-Bereich anders reagiert.
2) habe ich fetsgestellt, dass das neue Bios (vielleicht mag es super gut sein) irgendwie emfindlich reagiert auf alte Settings und alte Zustände des Boards.
ich musste, um es erstmal einigermasen zum Laufen zu bewegen, einen echten clear_cmos machen.
Vergleicht man auch die eingestellten Werte im Bios und die der Voltanzeige im LCD-Poster so sind hier shcon ganz schöne differenzen zu sehen.
Das wäre mal sehr sehr interessant zu wissen, was beim User A, B, C und D ... bei gleichen Einstellungen, bei gleicher Hardware usw, das LCD-Poster meldet.
Weiter glaube ich auch, dass alles nochmals vom Netzteil abhängt. So bringt das Netzteil A wohl eine andere stabile Spannung als das Netzteil B.
3) Die Speicher, selbst wenn die gleichen Chips verbaut sind, können wohl anscheinend durch unterschiedliche SPD-Programmierungen andere Einstellungen notwendig sein noch dazu wenn verscheidene Hersteller andere Fertigungen für ihre PCB's haben.
Wenn man alles nun in einen Topf wirft, so scheint es für mich fast unmöglich zu sein, Bios-Einstellungen 1 zu 1 vom Board 1 auf Board 2 zu übertragen.
Für mich sind es zumindest Anhaltspunkte um zu sehen was geht und in welche Richtung man es probieren könnte.
Wahrschenlich ist dies auch einer der Gründe wieso absolute OC-Freaks mit dem Voltmeter daneben stehen, da sie wissen dass man dem Board mit den Voltangaben eh nicht trauen kann!!!
ich weiss nicht wie ihr das sieht.
Das würde mich mal interessieren
Gruß achim
Danke dir, ich probiere mal einen CMOS Reset.
Andere RAMs hatte ich auch schon drin, blend schmiert immer sofort ab.
