[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
ja klar! Die VCore geht dann bei reduzierten Multi noch mal runter. Kannst du auch in meiner Signatur sehen.
jo die vcore senkt sich bei mir auch. auch der ulti aber iwie kann ich EIST nich aktivieren wenn ichs aktiver und dann in den ordner davor wechsel seh ich grad noch so wie sich das blöde EIST wieder disabled
p.s endlich ne neue seite^^
@°Leon°:
Mit den Optimized Defaults bleiben die eingestellten Werte im BIOS bei mir stehen. Übertakte ich den RAM, verstellt sich EIST immer auf Disabled.
In der Praxis hat das aber keine Bedeutung. Denn wenn sich der Multi reduziert - egal bei welchen Einstellungen (FSB, RAM, VCore,...) - geht die VCore auch runter. Abstellen kann ich das nicht.
Soll eine konstante VCore dauerhaft anliegen, muss man eben seine CPU auf dauerhafte, volle Frequenz einstellen, dass sich der Multi eben nicht mehr reduziert.
Habe jetzt XP64 Bit installiert. Dabei bin ich auf einen ersten BUG gestoßen: Wollte gleich die AHCI- Treiber über F6 mit einbinden. Dazu muss man vorher im BIOS auch AHCI einstellen. Jedoch wird die Windows Installations CD dann nicht mehr mit dem S-ATA Brenner gebootet. Also kann man keine AHCI- Neuinstallation durchführen. Auch kann Windows dann nicht in ein RAID eingebunden werden. Es liegt eindeutig am Board, weil es mit demselben Brenner auf einem Gigabyte- P35 Board ging.
Hier ein erster Eindruck der RAM- Performance mit XP 64 Bit. Es ist wirklich unglaublich. Performance Level 1 habe ich bis heute überhaupt noch nicht gesehen. Da freut man sich wie ein kleines Kind!
:banana::banana::banana::banana::banana:
Ein Bekannter hat seit zwei Wochen ein Asus P5Q pro mit p45 Chipsatz und die E8400 . Ein erster Speicherbenchmark mit Werkseinstellungen in Everest ergab schlappe 6500MB/s Lesedurchsatz (PL10). Also haben versucht, den Rechner @ FSB default RAM- Performance zu bringen. Leider nur mit mäßigen Erfolg. Höher als 7700MB/s (PL5) geht es offenbar nicht.
Mit meinem Foxconn Mars unter dem E4400 (333x9; 1000Mhz) ging es locker auf 8200MB/s.
Läuft vielleicht aufgrund des kleineren Straps ein E4400 @ 3,0Ghz schneller als ein E8400 @default 3,0Ghz? Oder liegt es daran, dass nicht die vollen 4GB RAM unter XP32 Bit beim Asus berücksichtigt wurden? Oder ist das Board ne` Gurke?
@Tobi:
Könntest du vielleicht mal ein Benchmark mit dem Mars + E8400 @3,0Ghz@1000Mhz posten – also mit analogen Einstellungen des folgenden Bildes?
Hat der Prozessor tatsächlich schon das neue E0 Stepping???
wollte deinen test eben machen, wo finde ich den ??
edit:
schon gefunden :)
hab ähnliche werte wenn ich alles auf auto lasse mit vollbestückung
@Tobi:
nur 7700 MB/s Memory/read??? Welches Performance Level hattest du?
@fuz2z3l:
Die Everest v4.50 XXXX beta sind alle gleich - was die Benchwerte angeht.
das unterstreicht jetzt doch dieTheorie, dass kleinere Prozessoren z.B. @3,0Ghz bessere Werte haben als ein E8400 @default 3 Ghz.
Folgende Speicherbenchmarks habe ich @333x9 @1000Mhz beim Lesedurchsatz beobachtet:
E8400: ca. 7700 MB/s
E4400: ca. 8200 MB/s
E4300: ca. 8400 MB/s
Wenn man FSB 333x9 einstellt, muss dann zwangsläufig der Strap 333eingestellt sein? Man kann sich ja die Straps 200, 266, 333, 400 wie Übersetzungen einer Gangschaltung vorstellen. Wäre nicht ein 266er Strap bei einem 333FSB denkbar?
Folgende RAM- Einstellungen laufen bei mir mit Windows XP Prof. x64 Bit, die mit der normalen 32 Bit Version nicht machbar sind:
200x10 Mhz @800 Mhz Cl4 Performance Level 1
266x10 Mhz @1066 Mhz CL5 Performance Level 2
Bin damit sehr zufrieden. :)
hab heut mal meinen e6750 getestet (at Work) und hab 8500 @ 2GB 800 MHZ CL5, allerdings auf einem n650i ultra
Das ist ja unglaublich! Bei RAM @1000 Mhz wären das ja etwa 1000 MB/s schneller als mit dem E8400er auf dem Mars. Wie kann man das erklären? Welches Performance Level?
Welche Everest Version hast du verwendet? Es gab da mal eine, die erheblich mehr angezeigt hat!
Performance Level steht in Everest unter Motherboard Chipsatz.
Ich weiß nicht, ob mit Everest 4.10 und 4.50 gleiche Resultate gemessen werden. Ich werd mal nach älteren Versionen schauen.
Habe XP32Bit über Laufwerkimage zurückgespielt und plötzlich geht damit PL1 doch. Habe keine Ahnung warum. :hmm:
@Tobi:
Warum ist der n650i ultra soooo gut? Kommt da nicht der Gedanke das Board zu wechseln?
Hi ho!
Hat schon jemand von euch mal nen E5200 auf dem Board laufen lassen?
Habe mir heute einen zugelegt und werd das Stückchen morgen mal aufschnallen...
Naja, mit dem neuesten Bios sollte es wohl kein Problem sein, oder?
@Tobi:
ich kann mich noch an dran erinnern das damals die nvidia boards einen besseren speicherdurchsatz hatten, in der gesamtperformance allerdings hinter den intel chipsätzen lagen
Hi ho!
Der ist klein aber fein, könnte mir auch gefallen. Das BIOS- Update muss aber vor dem Wechsel erfolgen. Kannst dann ja mal berichten, wie der so rennt.
@Tobi:
Hast du in Sachen CR1 schon das andere Board getestet?
Klar, Bios Update kommt vorher druff, und dann mal schauen...
Habe bisher hier im Forum eher nich so dolle OC-Ergebnisse gesehen.
Bei dem Multi hätt ich schon gern annähernd die 4GHz.
Naja, mal schauen, vielleicht hab ich ja wat schickes bekommen.
mir geht es erst einmal nur darum, die Speicher mit CR1 zum Laufen zu bringen. Die Frequenz ist erst einmal egal. Zwar lässt sich im BIOS CR1 einstellen, aber in Windows läuft alles wieder mit t2. Auch MemSet will CR1 nicht.
Habe beim Foxconn Support Service um ein BIOS- Update gebeten, weil S-ATA Brenner im AHCI und RAID nicht booten.
Foxconn meint, sie hätten verschiedene DVD- Brenner getestet und könnten kein Problem feststellen. Ich solle es doch mal mit einem anderen Brenner probieren.
Nun mal eine Frage in die Runde: Kann den jemand mit einem S-ATA Brenner, angeschlossen am internen ICH9R- Port, eine Windows Installations CD booten, wenn im BIOS AHCI oder RAID eingestellt ist (Integrated Periphals/OnChip IDE Device/SATA Mode/ AHCI oder RAID)?
Dann habe ich noch darum gebeten die Performance Level 1-3 ins BIOS zu inplementieren.
Sie sagen, das sei nicht möglich. :shake:
Zufällig habe ich auch einen Pioneer 212 und kann problemlos über CD booten. Du musst beim beim Biospost die Druck-Taste drücken und dort den Pioneer auswählen.
indem du nen bootfähigen USB Stick erstellst (Anleitungen per google), da die BIOS files draufpackst und dann davon bootest.
Versuchte dies gestern wie behämmert :mad: aber es funzt einnfach nicht. Wollte mein Grakabios modifizieren.
Corsairstick mit HP_USB_Boot_Utility & usbdos formatiert, old/new Bios & nvflash draufgepackt, aber das Ding bootet nicht ab diesem Stick. Im Bios alle USB aktiviert und Bootreihenfolge versucht nix !!! Hat da wer einen TIP. Ach ja Stick hing direkt am Board nicht über einen HUB oder so :confused:
Wie geht das denn?
Du besorgst dir entweder ein Bios aus dem Netz oder ziehst es mit einem entsprechenden Tool (bspw. GPUZ) direkt von der Karte, modifizierst es (Takt anpassen usw.) und flashst es zurück.
Wie geht das denn?
Hast du schon versucht dein Stick über das Auswahlmenü anzuwählen, das man nach dem Start durch Drücken der Print- Taste erhält?
jup habe ich auch versucht, das volle Programm, no way................ keiner eine Idee ? Habe gesehen dass hier einige schon sowas machten, mit erfolg
Ähnliche Themen
