[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Wenn beim Hochfahren von XP der blaue Startbildschirm erscheint steht dort „Windows wird gestartet“. Dann vergehen weitere 20 Sekunden bis „Willkommen“ zu lesen ist. Und genau diese 20 Sekunden sind durch das SP3 hinzugekommen.
Hatte früher BootVIS unter XP.Das ist ein ganz feines Tool zum Optimieren des Bootvorgangs. Mit SP3 läuft es leider nicht mehr. :( Habe schon alle Mögliche probiert – incl. das Löschen von „ %systemroot%/Prefetch“ .
Welches Tool/Tweak wäre denn optimal?
Habe gehört, dass unter XP 32Bit von 4GB RAM nur 3,5 angezeigt werden. Stimmt das?
ca.!
Etwa 3,2-3,5. Das hängt unt anderem davon ab wie groß der Speicher deiner Grafikkarte ist. Je kleiner er ist, desto mehr Ram kannst du nutzen.
Es kann auch möglich sein das du nur 2,8GB oder noch weniger nutzen kannst.
Je nachdem wieviel Speicher dein Computer adressieren muss.
32 bit os bleibt 32 bit os
also mehr wirds nicht, aber vista geht in der tat anders bzw. besser mit dem speicher um
also bei mir hat sich nichts geändert als ich sp3 bei xp installiert habe
Ja Vista nimmt sich den "leeren" speicher wenns sonst kein prog braucht und wenn ein spiel gestartet wird gibt es den speicher frei. deshab is der speicherverbrauch auch so "enorm weil auch bei mir ca 40% immer voll sin.(vista 64x und 4GB)
Bei meinen 2 GB RAM wird unter XP (32Bit) die volle Größe angezeigt (Okay, es fehlen! 2 MB :haha:)
Wenn ich es jetzt richtig verstanden habe, wäre das unter XP (32Bit) mit 4GB RAM nicht mehr der Fall. Normalerweise müssten dann 4096 MB erkannt werden. Es werden aber nur 3500 MB oder weniger ausgewiesen, oder?
Bei Vista werden jedoch auch 4GB RAM in voller Größe dargestellt, richtig?
Wer also volle 4Gb RAM unter XP nutzen will, muss die 64Bit Version nehmen, die ja eine noch bessere Speicherperformance bringen soll.
Wie sieht es denn bei euch mit dem Performance Level aus?
Beim RAM- Multi 4 kann ich bis auf PL2 runterstellen. Bei Multi 3 und 3,3 geht nur PL5.
hab alles auf auto was timings angeht
hab in der vergangenheit gemerkt das es nicht viel bringt und bei 8gb bzw. vollbestückung ist es eh wieder anders denke ich
hab meine gskill schön bei 1066 laufen und gut ist :)
das bei 1,8v :)
jop hab auch alles auf auto. bei 1066
aber am volt dreh ich grad ein bissl
Also ich bin Glücklicher Windows XP x64 nutzer!
8GB Ram - alles läuft Prima - bei knapp 1150Mhz kein Problem. :)
XP64 Bit hatte ich mal kurzzeitig drauf. Da aber einige Anwendungen nicht richtig unterstützt wurden (Drucker, Skype Kamera), hab ich mich doch für die 32Bit Version entschieden. Mittlerweile habe ich die Logitech Pro 9000, die wohl 64Bit tauglich ist.
Jetzt reizt es mich doch die 64Bit Version testweise nochmal zu installierten, um die Speicherperformance zu testen. :banana:
Also ich habe für alles Treiber gefunden.
Tach Leute, seid mir bitte nicht böse, dass ich nicht jede Seite einzeln durchgelesen habe. Ich wollte mal hören, ob und wie ihr mit dem Board hier im Thread insgesamt zufrieden seid, ob es irgendwelche bekannten, sehr nervigen Bugs gibt und ob ihr das Board insgesamt empfehlen würdet. Thx :d.
also ich bin sehr zufrieden !!
keine bugs kein gar nichts, selbst speedstep geht wenn man multi / vcore / fsb ändert !
und keine vcore droops !!
Bin auch sehr zufrieden.
Sehr stabile, flotte Plattform.
Einziges "Manko": Nach dem Trennen des Rechner vom Netz geht er ein Mal aus, nach dem Einschalten, ehe er wieder angeht. Vermutlich aber kein typischer Bug des Boards.
bin auch zufrieden mit bis auf das er eben nach netztrennung beim ersten mal anschalten wieder kurz ausgeht dann aber gleich wieder selbst anschaltet.
mmh könnt ihr beim undervolten c1e und EIST anmachen?
ja klar! Die VCore geht dann bei reduzierten Multi noch mal runter. Kannst du auch in meiner Signatur sehen.
laufen auch alle Computerspiele (sonst beschwert sich mein Sohn)?
Habe bisher ALLE installiert bekommen. Irgendein spiel (ich glaube es war Battlefield) hat bei der Installation eine Meldung ausgegeben "Dieses Spiel wurde in einer 64bit Umgebung nicht getestet", lief aber trotzdem super. :cool:
Ein Bekannter hat seit zwei Wochen ein Asus P5Q pro mit p45 Chipsatz und die E8400 . Ein erster Speicherbenchmark mit Werkseinstellungen in Everest ergab schlappe 6500MB/s Lesedurchsatz (PL10). Also haben versucht, den Rechner @ FSB default RAM- Performance zu bringen. Leider nur mit mäßigen Erfolg. Höher als 7700MB/s (PL5) geht es offenbar nicht.
Mit meinem Foxconn Mars unter dem E4400 (333x9; 1000Mhz) ging es locker auf 8200MB/s.
Läuft vielleicht aufgrund des kleineren Straps ein E4400 @ 3,0Ghz schneller als ein E8400 @default 3,0Ghz? Oder liegt es daran, dass nicht die vollen 4GB RAM unter XP32 Bit beim Asus berücksichtigt wurden? Oder ist das Board ne` Gurke?
@Tobi:
Könntest du vielleicht mal ein Benchmark mit dem Mars + E8400 @3,0Ghz@1000Mhz posten – also mit analogen Einstellungen des folgenden Bildes?
Hat der Prozessor tatsächlich schon das neue E0 Stepping???
also wenn beide mit 9x333 ram 1000 laufen ist der strap gleich !
tests werde ich heute versuchen zu machen, sonst eben morgen abend
Ähnliche Themen
