testergebnisse aus dem vista rc2 sammelthread:
32 bit:
The benchmark started at 10.10.2006 00:29:58
System Information
Operating system: Windows (TM) Vista Ultimate
System memory: 1,0 GB
CPU: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
CPU speed: 3200 MHz
Sound system: Lautsprecher (High Definition Audio-Gerät)
VGA Information
Graphics card: RADEON X800 XL (Microsoft Corporation - WDDM)
Memory: 508 MB
Current VPU speed: 0,00 MHz
Current memory speed: 0,00 MHz
Driver version: 7.14.0010.0443 (English)
Resolution: 1024×768
Ultra quality option, Direct3D renderer
Level: Pier, demo: 1.tmd
Pixel shader: default model
Antialising: None
Anisotropic filtering: 1×
HDR: disabled
Geometry Instancing: disabled
Normal-maps compression: disabled
Score = 100,90 FPS (Run 1)
Score = 102,72 FPS (Run 2)
Score = 104,41 FPS (Run 3)
Score = 104,27 FPS (Run 4)
Score = 104,57 FPS (Run 5)
Average score = 103,37 FPS
64bit:
The benchmark started at 10.10.2006 00:38:25
System Information
CPU speed: 3200 MHz
VGA Information
Memory: 508 MB
Antialising: None
HDR: disabled
Score = 101,78 FPS (Run 1)
Score = 103,31 FPS (Run 2)
Score = 104,22 FPS (Run 3)
Score = 103,55 FPS (Run 4)
Score = 102,82 FPS (Run 5)
Average score = 103,13 FPS
also im grunde kein unterschied.
edit:
32 bit winxp sp2 mit catalyst 6.9
The benchmark started at 10.10.2006 01:04:07
System Information
Operating system: Microsoft Windows XP
CPU speed: 3200 MHz
Sound system: Realtek HD Audio output
VGA Information
Graphics card: RADEON X800 Series
Bustype: PCI Express x16
Memory: 256.0 MB
Current VPU speed: 398,25 MHz
Current memory speed: 492,75 MHz
Driver version: 6.14.0010.6635 (English)
Antialising: None
HDR: disabled
Score = 109,19 FPS (Run 1)
Score = 107,93 FPS (Run 2)
Score = 108,64 FPS (Run 3)
Score = 108,28 FPS (Run 4)
Score = 107,71 FPS (Run 5)
Average score = 108,34 FPS
also mit winxp und einem optimierten treiber und dx9c grad mal 5% mehr leistung als vista rc2 und einem beta treiber und x10
hab aber auch leider nur eine karte die max shader 2 unterstützt. ich denke aber trotzdem das der test repräsentativ ist.
