Self made COSMOS II Clear Panel
arg-ist
MY friend wanted to buy a plexi sidewindow for cosmosII
It costs 160 USD . and shipping 184 USD (UPS). A great summe.He asked if ı can make his window.
I had seen a lot of selfmade Windows , but their quality was not sufficiently.
Max. 5mm plexi or with ugly hinges. Or some hard mods at he case..
This is original side panel from mnpctech
He sent the original CosmosII window to me with original hinges
and I made him a clear sidewindow panel. With original hinges.
Nothing must be modified at the case.. if he wants he can mount the original door too.
First the dimensions..next drawing at corel , and laser cut…
I used 10 mm plexi (original is 12mm thick (it was diffucult to find 12mm plexi in goog quality..)
This is 10 mm lasercut sidewindow with protection foils.
The hinges and locking mechanism mounted to the plexi
I have send the door with post to my friend and this are some photos from the Cosmos II case with the new clear side window ,That he send me… becouse I was wondering result..The is result…
I have paid for laser cutting and for 10mm clear plexi only .
Of course a little effort …
A new version of Clear panel made for my friend. 16.04.2016
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/community/f143/playdoh-silverstone-tj-07-acrylic-pipe-1012476.html
Worklog http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-900-d-case-p1-1002736.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/jumbo-case-997157.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/4-way-hdd-switcher-1033308.html
