RADEON WIN 2k/XP OMEGA DRIVERS 2.5.76
Jammer
Banned
W.Berlin
What's New? (2k/XP 2.5.76)
* Based on the official Catalyst 4.9 drivers.
* Removed ATITool from the package, it had many bugs and disabled a lot of
stuff, like DVI support and DDC. If you have it installed, I recommend that
you uninstall it before installing this set of drivers.
* Re-Enabled Overclocking Anti-Protection, it was missing from last release, sorry.
* Modified the ATI CP, now the Omega Drivers will use a built-in, special RadLinker
version with the following features: (some new, some old)
> Uses NO resources.
> Some new settings for both D3D and OGL.
> Can set Automatic Per-application profiles for OGL & D3D applications.
> Desktop Gamma is working and NOT resetting to default after exiting a game.
> Integrated Overclocking.
> No need for Gamma Hotkeys anymore since you can now set an individual Gamma value
for each game in their profile and done.
> This new CP was made in conjunction with ChrisW, maker of Radlinker, as an
exclusive feature for the Omega Drivers and we will keep adding features in
future releases.
* Modified driver installation/uninstall procedure with several new automatic features.
* Since RadLinker is now a vital part of the Omega Drivers, it will not be an option
to select during setup anymore, it will now automatically look for and uninstall ANY
previous version and replace it with the new one.
* Now, when uninstalling the Setup tools from the Omega options in the Start Menu, you
will also have the option to uninstall the Display drivers in one pass.
Known bugs:
* Laptop video playback problem still here, see notes.
* Hibernation and Standby are not working properly, I'm working on a fix.
http://downloads.driverheaven.net/omega/ati/rad_w2kxp_omega_2576_7z.exe
spz:d
Hm bin mir nicht sicher ob ich den neuen Omega testen soll. Beim 4.8er Omega hatte ich bei CS, wenn eine Smoke geworfen wurde starke Frameschwankungen , wobei beim Original CAT alles ok war.
Naja testen kann man es ja. Obwohl ich bezweifle das sich da viel getan hat :).
