Furgy
Banned
OCZ schrieb:All OCZ Technology memory modules have been thoroughly tested and, when shipped, are free of defects in material and workmanship. OCZ Technology, shall immediately replace this product, if any malfunction should occur, at no charge, provided the following:
Modules must have an original OCZ Technology Label, and an OCZ branded heatspreader, when applicable.
The product or any part thereof has not been abused, misused, damaged, neglected, replaced, repaired tampered with or modified.
The product was properly installed and used in its recommended environment. OCZ Technology shall make the final determination as to the existence and cause of any defect.
You have contacted support for proper instructions and an RMA number.
Darf ich jetzt nun die Headspreader ablösen oder nicht?
